Old 11-25-2011, 10:08 PM   #51
niterider65
niterider65's Avatar
Cool Re: 1965 chevy truck one piece @a time
Originally Posted by McMurphy View Post
Ahhhh to be on the road this summer... !!!!
I look out the window at the falling snow and gotta thank you Alan for that nice warm thought.
MMMM looks like from where you are McMurphy winter comes early there
North pole watch out for that Red Hot Rod Sled
niterider65 is offline   Reply With Quote
Old 11-26-2011, 03:08 AM   #52
McMurphy
McMurphy's Avatar
Yeah almost 6 months of winter up here, snow from October to April.
It has its limits and its challenges living up here for sure!!
I got into my project so I would have something other than World of Warcraft to do all winter long.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 11-27-2011, 09:13 PM   #53
niterider65
little stuff i did its the corners that are needing the sanding now should i use paint stripper oae take the hand sandinf trip ummm ..
Old 12-03-2011, 11:22 PM   #54
niterider65
drilled and mounted the passanger side sunvisior mount and got the rear sway bar today and striped the hardware down for powder coating next week
Old 12-03-2011, 11:54 PM   #55
allaboutchevelles
allaboutchevelles's Avatar
what are you using to strip the paint on the inside of the roof?? Looks good!!
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 12-03-2011, 11:54 PM   #56
niterider65
here is more from what i striped and sanded on will take the sway bar in next week to get it coated lik the front and then mount it up
Old 12-04-2011, 12:07 AM   #57
niterider65
im using and 1/4 air grinder and scoth brite sripping wheels and a sandpaper 1 1/2 flapper wheel to get in the corners of the ribs of the roof and around the raido
will post the pics tomarrow it took a little bit of time to strip it down to and then last I'm using an d a sander with 180 to get t read for primmer and then paint ..
Old 12-04-2011, 12:11 AM   #58
allaboutchevelles
Thanks. I was thinking the same thing, I bought a whole box of the scuff disc for my 1/4 angle grinder so I guess ill be doing it that way also.
Old 12-04-2011, 09:29 PM   #59
niterider65
Sunday a little wett out side was able t get the corners done in side the cab on the radio and on the roof rails .. also blasted the rest ofthe stuff under the hood for powder coating .
Old 12-04-2011, 09:45 PM   #60
niterider65
a few more pics
Old 12-04-2011, 11:26 PM   #61
Joemomma1
Joemomma1's Avatar
I like where you're going with this build. I used the same rear bar on my truck but have yet to drive it. They look to me as if they belong. How do you like the wilwood calipers? Where did you pick up those rotors? Keep it up.
Joemomma1 is offline   Reply With Quote
Old 12-05-2011, 09:42 PM   #62
niterider65
Hi Thanks joe it' takes time but i like the fun of working on the old truck .. and getting ideas from other members here onthe board. Joe i bought the d-52 calipers from willwood as a direct replacement for the single piston to an duel piston caliper fits the stock caliper bracket mine are off and 70 chevy 1/2 ton . the only down side is ive got spacers on he frnt to keep the outer edge of the rim from rubbin the caliper.. They my no rub after seting the brakes.
will see im going to get new rims but if the rub 15in wheels I'll step up to 16in.the rotors i got from lmc . there for an 71-72 chevy truck .if you use them on 70 you need the bigger bearing ?? i had to change i couldet use the new ones they sent in the kit .
Old 12-11-2011, 09:58 PM   #63
niterider65
Did a little more blasting today on the stuff for the fire wall . bought an deluxe
blower box cheap 10.00 . but the pics will tell the story for if it was an good
deal.
Old 12-11-2011, 10:05 PM   #64
niterider65
more pics
Old 12-11-2011, 10:15 PM   #65
niterider65
some of the pics of the clean up on the box from the media blaster
Old 12-11-2011, 10:18 PM   #66
niterider65
Then we found the holes from blasting all the rust out of the inside the box ..
on to the wire welding the holes up and hammering the dents out of the corn and under neath .. I KNOW ITS NOT SEEN FROM THE BOTTOM
But i want it looking right ... po must have had some issues
Old 12-11-2011, 10:36 PM   #67
niterider65
here is what it looks like after some twiking on it with and hammer still have a hole or two to fill and then smooth the in side with some metal filler or jb weld not sure yet or start lookin for another lower housing
Old 12-11-2011, 10:46 PM   #68
niterider65
here is the last few pics the blue box is my recyclebles that are going to the powder coater this week
Old 12-15-2011, 10:36 PM   #69
niterider65
just a little update .primed and por 15 the inside of the blower box today..
had to turn the heat on in the shop to get the primer to set up ...
and took the sway bar and things to the powder coater today.. should have the stuff back next monday or tuesday .. will see no rush .
Old 12-15-2011, 10:44 PM   #70
niterider65
just a couple more pics
Old 12-15-2011, 11:35 PM   #71
allaboutchevelles
heater box looks real good! Are you just brushing on the por-15. Looks like your getting good results with it.
Old 12-16-2011, 10:55 PM   #72
niterider65
Hi i did brush it on i went a little heavy on the inside to cover up the pitting
and brushed it on the outside ill scuff it up and prime it an paint it and build the box to get ready to put back on when i paint the fire wall
it will be on there for ever unless i restore the tuck AGAIN in 30 years
Old 12-18-2011, 03:49 PM   #73
niterider65
little more pics of the heater box primered and paint waiting on the core to come back from the red shop sand blasted the srews for the box also all before lunch
Old 12-18-2011, 04:01 PM   #74
niterider65
afew more of the box lunch is over back to the shop going to work on the cab pics to after after dinner
Old 12-18-2011, 09:56 PM   #75
niterider65
here ia what i did untill the vac on the media blaster died .......
looks like i need an new electeic motor or i my be able to ge parts to fix it its an 1970's dry vac from dayton . did start the old air file on the inside the cab to fix a couple of ruff spots on under the window. the last two are from the media blaster i hope i can by the fan. the moter and brushes look ok but being 30 something years old .. it might be cheeper wirh an new dry vac . will see
