10-26-2011, 07:52 PM | #51 | |
Tripple Five Fanatic
Re: The beginning, my 57 LS powered streetrod
Post #29 The stock height is ~10.5" Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
10-26-2011, 08:23 PM | #52 | |
10-26-2011, 10:06 PM | #53 |
thanks jjjmm56, I had thought of that ,but just had hoped my initial measurements were correct (don't we all) these bags have internal stops built in so was hoping to avoid adding them ,but I may anyway.
Learn to deal with reality, or reality will deal with you. |
10-26-2011, 10:10 PM | #54 |
Thanks Tri5nerd, I have been following your thread, I will need to see if my 18 gal. tank has enough depth for thee stock type pump set up.
10-27-2011, 07:48 PM | #55 |
Well, a new problem, since the ball joint angles are too steep and the track too wide I am in search of different control arms(shorter) I want to be able to turn lock to lock when she's sitting low. If I had done my homework better I would probably went the mustang 2 route, anyone ever ran aftermarket control arms for the Camaro clip to get a narrower track on 55-59 trucks? guess I could sell my front wheels and get a different offset also??? Hey Kabwe your friend 55Eddie with the black truck ,do you know if he can actually drive his truck? I ordered the same wheels he has.
Learn to deal with reality, or reality will deal with you. Last edited by ZR2RICK; 10-27-2011 at 08:03 PM. Reason: info to add |
10-27-2011, 09:56 PM | #56 | |
Tri5
10-27-2011, 11:12 PM | #57 |
so do you have the same problem? too wide in the front?
10-28-2011, 12:12 AM | #58 |
I'm not as low as you when aired out, I have about 3" to the ground with stock spindle and the shockwaves and am running 18/40/225 tires on 8" Boss rims.
I plan to add some drop spindles I have here that should drop it down lower so we'll see if that develops the same issue you're having. Tri5
10-28-2011, 07:07 AM | #59 |
This is depressing,If I try and turn it at any height other than about 1" of tire under the fender the tire rubs, I have dropped spindles and am running 18x7 with 3.75 backspacing wheels (235/40/18 tire) Anyone interested in a new set of American racing torque thrust 2s, chrome inners w/ polished aluminum outer rims on new Hankook Ventus tires??
10-29-2011, 04:02 PM | #60 |
Anyone narrowed their camaro/nova clip or know of someone else who's done it, I saw over on the HAMB forum that it has been done a lot but cant find a thread anywhere showing it being done? from what I can see I will have to narrow the tie rods, make new motor mount frame stands and because the heater hose outlets are already so close to the right upper control arm ill have to modify those also, any other ideas,concerns, inputs??
10-29-2011, 10:06 PM | #61 |
These guys sell a set of A arms that are narrower than stock.
About 3/4 way down on this page are the specs for their GM arms. Kim http://www.fatmanfab.com/gmctrlarmdrpspdl.php |
10-30-2011, 07:24 AM | #62 |
Thanks Kim57, I have seen those but being the do it myself guy I am (READ THAT CHEAP) I would prefer to either narrow my own or I may split the crossmember and remove 2-3" there.
10-30-2011, 09:23 AM | #63 |
I was once told that s 10 arms will work on a camaro sub. You might want to look into that. I set my ride hight at 4" from the ground to the bottom of my rocker and have no problem steering, but I also have more backspace on my rims.
10-30-2011, 12:42 PM | #64 |
^ beautiful truck
10-30-2011, 03:30 PM | #65 |
Yes, that is a beautiful truck, thanks JJJM56 ,I think I'm leaning toward narrowing the clip.
10-30-2011, 05:32 PM | #66 |
Are you going to run shocks,and sway bar ?
10-30-2011, 09:40 PM | #67 |
Yea , gonna run shocks, don't know about the sway bar yet.
10-30-2011, 09:46 PM | #68 |
Still searching for any info on narrowing a clip, a lot of references that people have done it but no build type threads, guess I will have to do it myself. I have been working on an idea for the jig .
10-30-2011, 10:06 PM | #69 |
I am sure S10 control arms will not swap on 71-up Camaro frames.
Posted via Mobile Device |
11-04-2011, 07:23 AM | #70 |
Well, I ran across a thread over on the HAMB site talking about narrowing a Camaro clip for use in early fat fendered cars, one of the posts mentioned a tech article in a 1991 issue of street rodder magazine so using the magic of the web I now have a copy of that rag in my hands, and it is a great how to article, so here we go ,got a bunch of new cut off discs and am itchin' to cut something up,will post pics as I proceed.
11-04-2011, 10:51 AM | #71 | |
Kim |
02-19-2012, 08:24 PM | #72 | |
58 Apache short fleetside ona 64 chassis: |
02-21-2012, 09:40 PM | #73 |
chevy runs deep
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
03-06-2012, 12:05 PM | #74 |
still working on a plan for narrowing the clip, I was able to obtain a copy of the article mentioned earlier but still as we all know, when you change one thing it leads to other problems, i can probably get 3" out of the X member but it will require i move the engine up, so then the tunnel will have to be modified (it's already close), I can bring the engine forward to avoid that but the LS1 oil pan will need to be cut because it is close to X member now, sooo still doin some head scratchin'
03-06-2012, 02:53 PM | #75 |
I cut the 69 camaro clip on my 38 coupe. An old rodder friend came over and we just put a piece of 2" tape around the center of the crossmember, took a cut off wheel, cut on bout sides of the tape, slid it togeather and welded it up. Yes, new mounts were made, but the stock ones wouldn't have worked anyway. All lined up and drives good.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
