Closed Thread
Old 10-01-2011, 04:25 PM   #51
alden
alden's Avatar
Re: What Did You Do With Your Truck Today ?
got the bumper mounted after cleaning it up and painting it over the past couple of days. Just little things these days but this made a big difference in the look of the truck.
I've really gotta get that hood replaced.
alden is offline
Old 10-01-2011, 05:16 PM   #52
FFredo
Originally Posted by Tchia65 View Post
I drove mine to Lowes to get materials to finish moving in and setting up the garage so I can keep her inside. Along the way I dropped it on the rockers to make a toyota look bad, and beat a mustang light to light because he was a punk and irritated me.
TJ, you cracked me up with this report. Hope all is well with you and yours.
FFredo is offline
Old 10-02-2011, 01:06 PM   #53
Coupeguy2001
Coupeguy2001's Avatar
I got the new engine on the run stand ready to install.
Added aluminum water pump, installed the serpentine belt drive, swapped the carb studs and installed the longer studs , spacer, and carb and air filter stud and K&N filter.
Installed the MSD billet distributor, timed it, and installed old plugs to keep out the dust but who cares if they get broken. Painted the rocker covers with the correct corvette "rocker cover paint". I just wish they were a little more silver. Too bad they are magnesium. IF they were aluminum I would get them polished.
Removed the run stand exhaust, disconnected the run stand battery and fuel supply, installed the truck's fittings in the fuel pump.
Swapped fuel lines.
I use a frantz toilet paper filter, so I installed the fittings and the lines, drilled and tappd the intake manifold for the return oil.
I am running an 89 corvette engine with a water/oil cooler, so ran the tubing for that and the short hoses. If that cooler doesn't do much, I will re-install my B&M oil cooler. I am betting It will be a mother to install next summer when it is 113 degrees outside.
Mounted the knock sensor as a block plug (for when the TPI gets installed), drained both sides of the engine so it will keep the floor dry when I'm installig the engine.
Installed the trans mount on the trans and installed the shifter mount and the linkage.
Drained the overdrive and drained the 4 speed part. Refilled the 4 speed, but will add the ATF when the trans is in for the last time and the trans cooler is connected.
Measured the original drive shaft, and it will fit!
started making the rear axle brake line clips.
I am beginning to think that lightening up the front of the truck only ofset the weight of the serpentine belt system. That stuff is heavy!
The firewall is still curing. I could smell the fresh paint all day.
I still have to buy some headers. The block huggers I have don't fit. so I will have to get rid of those. Too bad, they are brand new too.
Got a new optima red top for it, and set it in the battery box.
I'm thinking I will mount the MSD box on the bottom of the battery box out of the way. I will have to start making those brackets before I put the fenders on.
Coupeguy2001 is offline
Old 10-02-2011, 01:23 PM   #54
kgmunro
alden thats a sharp looking truck!
kgmunro is offline
Old 10-02-2011, 10:20 PM   #55
mknittle
mknittle's Avatar
I thought about it while I did some yard work
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 10-02-2011, 10:35 PM   #56
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
I let it sit in the garage all tore to hell collecting even more dust.
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline
Old 10-03-2011, 07:11 PM   #57
Atommik
Atommik's Avatar
Worked a little more on the BMW HID headlight idea...May have it figured out.
Atommik is offline
Old 10-03-2011, 08:55 PM   #58
Denee007
Denee007's Avatar
Installed the passenger side floor pan! Yahoo!!
Denee007 is offline
Old 10-03-2011, 11:13 PM   #59
Dan in Pasadena
Dan in Pasadena's Avatar
I had sanded and painted the upper dash last weekend then wiped it down with acetone before spraying - MISTAKE. It had flashed off and I thought all was well but it softened (I guess) the remaining paint some and the final finish looked bad in a few spots.
Color sanded w/220 wet/dry and resprayed today only to have a bit of alligatoring in a couple spots - DAMN! I waited, let it tack a bit then added a fairly heavy final coat and it settled out a bit. I'm hoping (fingers crossed) I can color sand with 1500 wet or dry in a couple days, clear it and all will be okay. I'll post pic's once I spray the bottom of the dash. I'm doing a two tone idea; I've gotta see if I like it before posting it.
Dan in Pasadena is offline
Old 10-04-2011, 10:26 AM   #60
mknittle
mknittle's Avatar
I use denatured alcohol for grease and wax remover{not to drink} acetone is ok for bare metal but like you found out too aggressive for primer I let paint problems sit for at least a week or longer before fixing them.My old DuPont book says 3 weeks.I still have a lot of the old stuff stuck in my head.
Mark
My GMC build.
mknittle is offline
Old 10-04-2011, 11:31 AM   #61
Dan in Pasadena
Thanks. Yeah, good advice. I get hotpants to get on with it and rush things. I'll let this problem cure fora couple days and go back and see what I can do. Its just rattle can stuff. It actually looks better than I have any right to expect.. I keep telling myself I'm just bulding a clean driver but then I see what so many other guys are doing here and I get carried away.
Old 10-05-2011, 02:51 PM   #62
FFredo
Sadly not very much for the past few days. On the up side I have been working to midnight every night to get a cpl of large leather orders out. Leather orders = money to be spent on "old four eyes". Tomorow is my B-day and my rule is never to go into work on my b-day, so I'm taking friday off too. Monday is a holiday so that gives me 5 days to show the apache a bit of love!
FFredo is offline
Old 10-05-2011, 05:22 PM   #63
alden
alden's Avatar
mounted the fenders that aren't made for the truck, they don't look pretty and I had to gap them up and in to prevent the tires from rubbing but they will keep the rocks down until I can track down some used factory fenders to refurbish.
alden is offline
Old 10-05-2011, 11:52 PM   #64
Dan in Pasadena
Originally Posted by FFredo View Post
...Tomorrow is my B-day and my rule is never to go into work on my b-day, so I'm taking friday off too. Monday is a holiday so that gives me 5 days to show the apache a bit of love!
Jealous
Old 10-06-2011, 12:42 PM   #65
OrrieG
OrrieG's Avatar
I have not done anything with my truck of substance for 6 weeks. Too many business distractions.
OrrieG is offline
Old 10-06-2011, 08:56 PM   #66
ZR2RICK
ZR2RICK's Avatar
finished my bag mounting,working on air line routing.
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline
Old 10-06-2011, 10:19 PM   #67
rawraw67
rawraw67's Avatar
worked on my new cross member and trying to fit and center front wheels. I think that I am going to try to run 26" 27" tall wheel.the wheel in the picture is a 29" tall wheel. it also looks like the wheel needs to be moved forward maybe 1" hoping to have 6 from the rockers to the ground.
rawraw67 is offline
Old 10-07-2011, 12:14 AM   #68
Lrall
Lrall's Avatar
Cursed at it....Oil Pressure gauge not working, problem with a relay that when jumped works but 2 separate relays don't work. Annnd before those problems came up I couldn't get the fuel injectors to fire.
Lrall is offline
Old 10-07-2011, 12:54 AM   #69
Dan in Pasadena
Indirectly I took a BIG step today. My old oil-less, nosiy-azz compressor finally bit the dust a couple weeks ago. I wanted a much bigger compressor so I could run a large standing sandblast cabinet I bought on CL awhile ago. Virtually all I'd seen were too expensive for my budget. The one I'd decided on was the standing U.S. General one from Harbor Freight. Over 14 CFM and $899, currently on sale for $799 and with 20% coupon it is down to $639 I think. Found a used one today for $265!! I'm pretty happy about it.
Old 10-07-2011, 11:00 AM   #70
55metalmonkey
I find the only way to keep from rushing when it comes to any painting or anything that needs to set up is to keep a couple of cases of beer on hand.
55metalmonkey is offline
Old 10-07-2011, 11:59 AM   #71
Dan in Pasadena
Originally Posted by 55metalmonkey View Post
...keep a couple of cases of beer on hand.
A universally accepted good tip, thanks!
Old 10-07-2011, 07:13 PM   #72
mknittle
mknittle's Avatar
that's why I am running on 66 gto technology.LOL
this is supposed to be fun
Mark
My GMC build.
mknittle is offline
Old 10-07-2011, 07:17 PM   #73
mknittle
mknittle's Avatar
I worked on replacing a bearing in my old outdated press brake does that count?
other wise I did some more measuring.
Mark
My GMC build.
mknittle is offline
Old 10-07-2011, 11:51 PM   #74
Daze57
Daze57's Avatar
workin on a change over - goin from a 12si alternator to a cs-130 - more amps -more power = more fun
Daze57 is offline
Old 10-09-2011, 08:59 PM   #75
flatbed51
flatbed51's Avatar
Worked on the frame.
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline
Closed Thread
