Old 11-18-2011, 10:11 PM   #1
X24
Re: WHAT did you pick up for your truck today
5.01 quarts of mobile1, oil filter, fuel filter, yep its time.
X24
1964 chevy c10 step side
230ci straight six
Auto power glide
X24 is offline   Reply With Quote
Old 11-18-2011, 10:43 PM   #2
ctumbler
ctumbler's Avatar
picking up a new driver door for the 66 C10
ctumbler is offline   Reply With Quote
Old 11-25-2011, 05:49 PM   #3
losthope
losthope's Avatar
went to the pick-n-pull today since its thanksgiving 1/2 price weekend and picked up a 1 1/4 front swaybar with all the brackets(need new bushings)and also pulled a rear sway bar off a camero with all the brackets and bushings to put on the rear of my truck dont know if it was the bigger iroc one but its better then nothing this measures about 7/8"...I also pulled some bumber braces for my front bumper all came out to $34.95! two days left of sale i might head back out. There was 4 chevy and gmc 60-66 trucks at the antelope yard.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 11-25-2011, 06:59 PM   #4
chevytrucknut61
chevytrucknut61's Avatar
Got my engine and tranny set in now to button every thing up. Wishing I had more time to work on it.
chevytrucknut61 is offline   Reply With Quote
Old 12-31-2011, 05:38 PM   #5
cb1965
cb1965's Avatar
just picked up a brand new american autowire kit for $300.00 off of craigslist. saved like $150.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 12-31-2011, 07:13 PM   #6
neto
Got 2 warlock racing mufflers 50551 for 10 bucks. For my 66 chevy truck.
neto is offline   Reply With Quote
Old 02-01-2012, 09:21 PM   #7
XtechX
XtechX's Avatar
I cut 1 1/2 coils from my extra set of front springs and installed them...WOW what a difference!! Some where on here I read to just block up the truck and to remove the lca u bolts with a floor jack under the arms to get the springs out/in. Instead of messing with the ball joints etc. That's definately the way to do it...45 minutes...Tops...and I was done with the spring swap. I have to cut the bump stops off yet, do I need to cut the bump stop stands off flush at the lca or just the rubber stop? I would imagine the whole thing needs to come out, but thought I would make sure.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 02-01-2012, 10:21 PM   #8
jonathan-m
I cut mine off flush. No sense in leaving them on, really.
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 02-02-2012, 01:57 AM   #9
XtechX
XtechX's Avatar
Cool... I'll cut 'em off. Thanks Johnathon-m
Old 02-02-2012, 02:46 PM   #10
1963c-10
1963c-10's Avatar
Dropping the rims off to get powder coated today...finally ready. Last of the parts prepped to do the disk brake swap
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-06-2012, 09:01 PM   #11
cb1965
cb1965's Avatar
finally picked up the wheels from powder coating and installed the tires
'66 chevy lwb c10
'65 chevy lwb c20
Old 04-06-2012, 11:11 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
Very nice!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-06-2012, 11:22 PM   #13
cb1965
cb1965's Avatar
Originally Posted by markeb01 View Post
Very nice!
thanks!
'66 chevy lwb c10
'65 chevy lwb c20
Old 04-06-2012, 09:25 PM   #14
krazy_texan
krazy_texan's Avatar
Got the engine ready to pull it's coming out next week and to the machine shop to be cleaned then back home for a rebuild and back in the truck hopefully with a th350 bolted to the back
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 04-06-2012, 09:27 PM   #15
RAYDAY
RAYDAY's Avatar
Got 4 235/70/15 Michelin tires like new, 8 to 9/32 of craigslist for $40!
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
Old 04-07-2012, 12:57 AM   #16
junk4cash
junk4cash's Avatar
Douched off the inside of the valve cover today so I picked up a new Felpro gasket as well as a oil pan gasket and oil pick up. Cant wait to see what the oil pan looks like when i drop it.
junk4cash is offline   Reply With Quote
Old 04-07-2012, 12:31 PM   #17
tincan1966
tincan1966's Avatar
Bought a 1964 LCF cab and front clip w/steps to put on the 1970 C-30 Chassis I have. Got a great deal and should make a cool "lowered" looking truck.Sorry about pic quality and size.
tincan1966 is offline   Reply With Quote
Old 04-07-2012, 01:21 PM   #18
weaintscared
weaintscared's Avatar
Picked up some new Auto meter Ultra lightgauges for my 69, Got the amp, water, & oil from a local guy for $ 125.00
Now need to buy the 5" speedometer & tach and Fuel gauge
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=468622
weaintscared is offline   Reply With Quote
Old 04-07-2012, 03:47 PM   #19
oldgoalie
New weather stripping, sill plates, cleaned up some rust on the roof. Scuff pad and comet worked good. You can see the diff in the pic. Some day that sunroof is going. Made an ashtray delete. A PO cut the dash up pretty bad for a stereo in the ashtray hole. I didn't want to replace the dash section so I made a delete plate from a couple of old ashtrays. Put a little paint on it and it will look pretty good
oldgoalie is offline   Reply With Quote
Old 04-07-2012, 04:11 PM   #20
MisterC
MisterC's Avatar
That delete plate looks awesome; just like it was that way from the factory. Well done!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 04-08-2012, 06:45 AM   #21
a37lesalle
a37lesalle's Avatar
Yesterday got the primer on and end of the day got it wet sanded. Should get her colored coated today.
a37lesalle is offline   Reply With Quote
Old 06-10-2012, 11:54 PM   #22
DoubleL
DoubleL's Avatar
My wife (God bless her) and I drove about 80 miles to get this combo: A Clifford 6=8 manifold with a 4 barrel Holley carb. bolted to engine but never saw gas, long tube dual headers, HEI distributor and new wires. I got the whole package for $700. I thought this was pretty good
DoubleL is offline   Reply With Quote
Old 07-08-2012, 07:25 PM   #23
cb1965
cb1965's Avatar
Brand spankin' new grille off craigslist
'66 chevy lwb c10
'65 chevy lwb c20
Old 04-08-2012, 05:52 PM   #24
suzq044
Resident Photoshop Nerd
suzq044's Avatar
we were going to pick up engine paint.. but alas, almost everyone is closed. lol
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline   Reply With Quote
Old 04-13-2012, 10:09 PM   #25
Vics63Chevy
Vics63Chevy's Avatar
Drove to CPP and picked up 6 lug rotors to convert my 85 5 lug front end to 6 lug. Also picked up an automatic shift linkage arm kit while I was there. And lastly scored some 15x8 deep dish 6 lug steelies from craigslist only to come find out it was chopper_john from this forum! small world hahahah he hooked me up with the wheels and I got to check out his new 65 shortfleet bbw project, truck is badass!
1963 Destiny Build Log
Vics63Chevy is offline   Reply With Quote
