Old 12-11-2011, 06:09 PM   #51
E911manager
Re: 64 chevy swb on a 94 chevy caprice frame w/ lt1
I boxed the frame in where the core support is going to sit. Went together pretty well..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline   Reply With Quote
Old 12-11-2011, 06:13 PM   #52
E911manager
I had some extra hands yesterday after a family Christmas dinner and put them to work. I set the bed in place do get an idea of how things will look. The body lines arent quite lined up but it gives me something to go off of.. it appears to be just about right. I measured another truck and may be 1/8 inch off..
Old 12-11-2011, 06:17 PM   #53
E911manager
Here is a shot inside the bed. I can squeeze 12 inch tires under it and the gas tank should fit.. I hope to start on mounting brackets before Christmas. But I need more tubing... Back to the pipe and steel yard....
Old 12-11-2011, 06:25 PM   #54
E911manager
I pulled the column out of the caprice. OK, maybe I am missing something but the column seems like it is going to work. There is a firewall cover that was welded to the column and it ground it off and moved it up. The placement is by using the caprice mount with the holes ground out a little. The electronics clear the pickup brackets. It looks like I may be able to use the caprice brake pedal too. OK all of you old school folks calm down and dont go off on me.. I intend to build an old school ride too..
Old 12-11-2011, 06:26 PM   #55
E911manager
OH and check out the caprice instruments sitting in the dash.. This is a glimpse of the vision....
Old 12-11-2011, 06:35 PM   #56
E911manager
I missed one of the pics of the column. I really think it is going to work. Also with some minor firewall manipulation It appears the brake booster will work also.
Old 12-11-2011, 06:36 PM   #57
E911manager
One more thing, yes that is rain... Cold rain... wishin I had Mesquite's shop right now..
Old 12-11-2011, 08:28 PM   #58
66ChevyMax
66ChevyMax's Avatar
Nice progress E911, feel free to send the rain my way we need it.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 12-12-2011, 12:01 AM   #59
Captainfab
60-66 Nut
You're making some good progress.
If that brake booster has a stud pattern of 3-3/8" x 3-1/2", it will bolt right up to your firewall with one of my brake booster brackets.
Old 12-12-2011, 12:21 AM   #60
E911manager
Thanks max and captfab. I need some better inner fenders so I can mount the front up and start wiring. I really can't do anything else up front till then.
Old 12-12-2011, 10:15 AM   #61
Bears63
...just another truck junkie..
Bears63's Avatar
Wow, you are moving along nicely on this. Interesting as all get out. I like the idea of using the Caprice instrument panel. Just fab up a nice filler and it should look really good.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 12-12-2011, 10:29 AM   #62
Pop's C-10
Pop's C-10's Avatar
killer..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 12-12-2011, 12:15 PM   #63
Dinos63
chevy only
Dinos63's Avatar
WOW!! i dont know how i missed this build !! cool idea and nice job!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-12-2011, 01:57 PM   #64
Dustin07
Stirrer of the Pot
very cool hybrid. looking forward to hearing how it handles!
Dustin07 is offline   Reply With Quote
Old 12-12-2011, 03:10 PM   #65
E911manager
Thanks Dinas63 and Dustin07, It has only been a month since I started so that could be why you may have missed it.. Dustin, it should do pretty well in a road course, the sway bars are huge on the police package!! But like I have said before, I just want to set the cruise at 75-80..
Old 12-12-2011, 03:27 PM   #66
firefighter736
firefighter736's Avatar
Seriously one of the coolest projects I've seen on this site. Fantastic craftsmanship - keep up the good work and post lots of updates!
"All anybody wants is a normal life and a cool car... most people settle for the car" - Christopher Titus
1966 Chevy C10 Pics
Rust to Riding - Pictures of my build
firefighter736 is offline   Reply With Quote
Old 12-12-2011, 03:59 PM   #67
Pop's C-10
Pop's C-10's Avatar
I forgot to say how cool it was tha wheelbase's match up...This frame was used under B-body's from tha early 70's - 96..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 12-12-2011, 05:17 PM   #68
E911manager
Woe!! Not sure about that compliment firefighter 736!! There are a ton of very nice rides that has has some great fab work. My skills were honed on the farm!! But I appreciate it.
Your correct pops. 78-96 b body frames were the same. There were some subtle changes in the technology but the layout is about the same. The 9c1 upgrades help with the fuzing of the pickup onto it. Like heavier springs, thicker frames, etc.
I will keep posting as I go!! Thanks again.
Old 12-12-2011, 11:25 PM   #69
allaboutchevelles
allaboutchevelles's Avatar
Cool build!! Looks like everything is lining up just right and fitting like a glove. Doing a great job, keep it up!!
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 12-13-2011, 05:07 PM   #70
E911manager
Thanks allaboutchevelles(and a 64 C-10 Shortbed), it has been really fun so far....
Old 12-13-2011, 05:11 PM   #71
firefighter736
Just curious what your plan is for the front bumper, E911?
1966 Chevy C10 Pics
Old 12-13-2011, 05:21 PM   #72
E911manager
I am going to use a factory bumper and mounts that I cut off of a salvage truck. I am going to weld another 1.5"x3" rectangle tubing to the bottom of the fabricated core support "mount" that is in the 3rd from the top picture on this page. I will put the 3 inch side facing forward. Then weld the center two mounts to that followed by some triangle backing plates behind to give some extra support. The outer mounts will be shortened and made to fit to the frame just in front of the front tires. I thought I had a pic of the bumper sitting in place on jack stands when I measured it all out but I guess I didnt take one. It SHOULD work. (Lost 3 hours of sleep on it...)
Old 12-13-2011, 06:12 PM   #73
winslowgoodwin
Very nice build! The dash and steering column idea with all the factory wiring works awesome. I did the same thing with my 91 dodge to 65 chevy swap.
winslowgoodwin is offline   Reply With Quote
Old 12-13-2011, 06:21 PM   #74
E911manager
Sweet that is in encouraging. This harness is huge and I think it will be the most difficult part of the build. I plan on just plugging it all in and ensureing my grounds are good. Then get it started before I pull any unused wiring out, like the power windows, airbag stuff, A/C and heater, etc...
Old 12-13-2011, 06:31 PM   #75
winslowgoodwin
that's exactly what I did I didn't cut anything until I knew it was right. I recommend you buy a factory service manual for the 96 caprice! It helped a bunch with the wiring.
