12-04-2011, 10:03 AM | #51 |
Re: Battery draw issue
It is for a condenser. It is not critical, so don't worry about it for now.
12-04-2011, 12:56 PM | #52 |
let us know how it goes, we would like to see you have some fun before you have to leave and Pappy takes the truck back. Get it done right and Pappy can have some fun too till you get back.
12-04-2011, 01:15 PM | #53 |
Thanks guys . the help is much appreciated
"Its better to burn out than it is to rust!" '70 GMC C10 2wd. 2.02 aluminum heads. TH400 trans. 450WHP '04 Nissan 350z DD, Twin Turbo, 600whp, drag beast! |
12-04-2011, 02:08 PM | #54 |
12-04-2011, 02:25 PM | #55 |
No, oddly enough it didn't fix it. The blue wire on the plug in to the alt is still hot.
12-04-2011, 03:23 PM | #56 |
Pull the plug out of the reg and see how many wire are hot
12-04-2011, 03:34 PM | #57 |
.okay
12-04-2011, 06:12 PM | #58 | |
Make sure the red and brown wires aren't swapped on the regulator plug.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
12-04-2011, 07:09 PM | #59 |
Msgt USAF Ret
Internal alternator conversion.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-04-2011, 07:39 PM | #60 |
12-04-2011, 08:32 PM | #61 |
In order for blue to be hot... doesn't brown have to be hot first? Am I looking at this wrong?
12-04-2011, 09:39 PM | #62 |
Why not just switch to a one wire alternator ? 10 gauge wire to battery positive from large terminal on alternator and you're done . Eliminates all of the old wiring and becomes a stand alone charging system. I've run these on many vehicles with great results. Most are 60 amp or more. A lot of the older vehicles didn't have that big of alternator from the factory. Lights are brighter, fan blows better,etc.
12-04-2011, 09:57 PM | #63 |
12-04-2011, 09:58 PM | #64 |
If i convert it, will it solve this problem?
12-04-2011, 10:02 PM | #65 | |
If he wants it I can build one for him for $40.00 + shipping 60 amps. Let me know. I would rather he found the problem, but it is another option. |
12-04-2011, 10:05 PM | #66 |
Well I'm ok with converting it, but I'll need help. I can get an alternator that's no problem, I just have no idea what to do. I'm tired of the stupid thing having this problem. I've got a flex plate on the way for it and I'd like to have this problem solved before I put it in so I can go back to daily driving. I just want to make sure this will solve the problem FOR SURE.
12-04-2011, 10:13 PM | #67 |
Call me tomorrow with a volt meter at the ready and we will figure it out in 10 min. And that is because I like to talk a lot. 5 min if we just do it. I would hold off on the 1 wire till we go over the wires.
12-04-2011, 10:15 PM | #68 |
That's a problem, during the week I'm busy until 6 p m here every day because of work and school
12-04-2011, 10:19 PM | #69 |
There's so many things going on with the electronics in this truck it's ridiculous, my grandfather didn't know much about it, and I'm suspecting neither did my great uncle (whom my grandfather acquired the truck from)
03-25-2012, 10:32 PM | #70 |
sorry to take this off topic. (1970 c20) My alternator is not grounded, the back of that alternator has the red single connection, and the blue and white together but no ground. Just got the truck and replaced the battery as tests showed if wasnt good. However my new battery just died after two days of driving.
