12-12-2011, 09:56 PM | #51 |
Re: 400-450hp 355 on a budget?
Block is in at the machine shop! Im letting him decide on the heads, what ever he thinks i need, this guy has been at building engines for a while so i trust his expertise. He seems to think i will be totally in the clear at 500hp...if that happens, with my 2 bolt main. I just hope all the stars align because with our conversation on the phone today he thinks i should easily have a 450-500hp combo. Im pretty excited to get my block back from machining along with the box of parts to get her together. Once i have it togather its going back to the same shop im getting the machining done at for some runs on the superflow dyno. Ill keep yall updated with progress as i here from the man.
12-13-2011, 10:47 AM | #52 |
Registered Truck Offender
Pete the $ spent on the dyno is not just for bragging rights,, the time spent tuning the motor is worth MANY TIMES what ever the dyno charge is. I've seen guys chase a tuneup with new carbs and plugs and jet kits, changing carb spacers, distributors, fighting it over and over and over,,,, when an hour on the dyno with a good tuner will START the motors life in the correct tune! it's money well spent.
i.e., I have a good buddy here with a very stout 434 that said he just didn't have the $ 550 to put it on the dyno. But over the 18 months he's been racing this motor I can count well over $2500 in parts and crap he keeps changing and tweeking to try and get it to run up to what he 'thinks' it's potential is. $500 would have told him what the potential is, and tuned it right before the motor ever went in the chassis. Then it's just jet changes for enviornment, not chasing yor tail throwing parts at it to try and find what is right.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
12-13-2011, 11:29 AM | #53 |
Totally aware its not for bragging rights. This isn't totally my first go round with a motor, just little different than previous go rounds. I'm use to building with rules for my street stock Monte circle track car though. This is my first one without following rules. But back in the day I never had the street stock motors dyno'd then last season I decided to and will never go without again.
Posted via Mobile Device |
12-15-2011, 11:26 AM | #54 |
You should be able to build a nice 454 for less than $5500.
12-15-2011, 12:36 PM | #55 |
Well I did it! Totally blew the budget! Everything is currently being ordered
12-15-2011, 09:49 PM | #56 |
Alright, now that im not posting off a phone ill spill the beans. She is .030 over right now so she will be going .040 over. I guess they ordered up new rods for me to play it safe for the power i want to make, not sure on the details, just know they ordered some. She is getting topped with 75cc chamber AFR 195's and the weiand 177 blower with a holley 750 cfm supercharger carb. Guess they are still decided on what cam specs to go with, apparently a custom ground comp cam is only a few bucks more than the one i picked out so that is the planned route. And when i saw i blew the budget i mean i REALLY blew the budget! Stuff happens, id rather have it right the first time than saying to myself i wish i did this or that.
12-16-2011, 08:32 AM | #57 |
Sounds like it should make plenty of power. In my experience having a cam ground for your specific application is better than just buying "off the shelf".
84 GMCummins 91 CCSB Dually american squarebody association |
12-26-2011, 11:46 AM | #58 |
Update is...still not much news on it. Hope everyone had a great Christmas! Hopefully i have to good updates to come.
01-20-2012, 09:12 PM | #59 |
Waiting on the finished product yet with much anticipation. Just have a few tranny questions if anyone sees it under this thread, if not i will start a new one. I do not believe the 4 speed saginaw that was in the truck will be satisfactory for what i want to do. I do have a couple of decent TH 350s laying around from the circle track days. Would it be wise to send one of them out to get looked over for behind this motor or should i be looking at other options? Truck will be a daily driver/street strip toy running both 1/8 and 1/4 mile. Also what will i be looking at to make the swap, cross member, tranny, torque converter, flex plate, shifter, and drive shaft, am i overlooking anything?
01-21-2012, 01:22 AM | #60 |
Smart move getting rid of the weak saginaw trans, manuals are nice but a built and stalled auto is a lot better for consistant performance, steet and strip, like the blower setup.
01-21-2012, 09:24 AM | #61 |
"Where were you in '62?"
Chevy 1969 Cast Iron 3970010 350ci 4 Bolt Main (.30 over)
Engine Works 135290H - Camshaft Hydraulic Dual Pattern http://www.engine-worksperformance.c...PartNo=135290H Lopey Idle - .445/.465 Lift Designed to suit the needs of entry level race classes Idle = Lopey RPM Range = 2200 to 5800 Torque Peak = Mid Adv. Duration = 288/289 Duration at .050 = 214/224 Lift = .445/.465 Centerline = 107/117 KB Pistons 1479H-030 - Silv-O-Lite Hypereutectic Pistons Crankshaft Nodular Cast iron 10.5:1 Compression Ratio 1968 Chevrolet Corvette 327 Double/Camel Hump 3917291 - 327 - 1968 Corvette - 350hp w/temp unit hole New Springs – 1969 – Z28 New Stainless Valves Manley 1.94 Int / 1.50Exh Hardened Exh Seats Setup to 490 Lift New Retainers and Locks New Guides
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 01-21-2012 at 09:31 AM. |
01-21-2012, 09:35 AM | #62 | |
01-22-2012, 05:41 PM | #63 |
Sounds great. Im going to tear down and check over one of my spare circle track th350's and get it set up for the motor. I do believe im going to go with this for a crossmember/motor mounts http://www.performanceonline.com/196...M6372-D-17818/
Anyone have any experience with this kit and what about polyurathane instead of rubber mounts? I know in my circle track car i used solid motor mounts and a poly tranny mount, any reasons not to used poly on motor or tranny? |
02-01-2012, 06:02 PM | #64 |
Had to head into my builder today to drop of some parts and had a seriously shocking update! Turns out my crank was shot and he figured he could build me a 383 for roughly the same amount of cash i was going to have into my 355 set up! Cant wait till it gets buttoned up and ran on the dyno.
[IMG][/IMG] |
02-01-2012, 06:39 PM | #65 |
Dang............
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
02-01-2012, 11:26 PM | #66 |
Dang,,, that is wicked lookin, wooo.
02-01-2012, 11:39 PM | #67 | |
02-02-2012, 12:40 AM | #68 |
NA 406 has long set sail...and so has my original budget and hp goal
But in all reality this isn't terribly over my original budget, its pretty bad @$$ in my mind, and by far meets and exceeds my expectations by far. Im loving it and cant wait to see it in my 69 |
02-02-2012, 01:41 PM | #69 |
Next big question will be how to get this to hook in a lwb truck
02-02-2012, 09:47 PM | #70 |
Easy, fill the bed with sand.
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car |
02-05-2012, 02:33 AM | #71 |
This is the build I was thinking about following. Seems to make good power and Tq.
http://www.chevyhiperformance.com/te...ild/index.html |
04-04-2012, 05:05 PM | #72 |
Well guys, she is finally done and dyno'd. I didn't get to talk to him long as i was at work so i don't have rpm or torque number but i did get to talk long enough to catch peak hp number and some details. Anyone want to take a guess at it before i spill the beans? With the afr 195 heads the blower was only make 1.5-2 psi of boost so he went with a different pulley set up and now its reading 3-3.5 psi of boost. Ill give ya a hint, the peak hp number absolutey blew my mind.
04-04-2012, 06:33 PM | #73 |
no cam specs, nothng but 3.5psi,,, I'm shooting in the dark and saying peak 540HP but up in the 6000range, torque numbers that are really dependant on boost and octane,, but I'd say 560 at 4300
hows that for a shot in the dark
04-04-2012, 06:39 PM | #74 |
Sorry, i really don't have any specs to give, i really know nothing bout this thing yet besides the rough general conversations i had with him when the build started. All i know is for a shot in the dark you are pretty awesomely close! I don't know torque numbers myself yet, i had to work all day while he was open so i really didn't have time to chat and get all the info i wanted. Not even positive at what rpm but she peaked 570 hp. Im hoping i get a day off of work here real soon to go pick this baby up and ill have some pictures and all the good info for ya then.
04-05-2012, 06:32 AM | #75 |
this may sound like a dumb question but why would you use a hydrolic lifter cam in blown or supercharged engine instead of a solid lifter cam?
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
