Old 03-21-2015, 11:14 AM   #51
Mjminino
Re: Travis' Tribute Truck - 65 Chevy C-10 Camper Special
Same as mine
Mjminino is offline   Reply With Quote
Old 06-12-2015, 11:47 AM   #52
scottofksu
scottofksu's Avatar
Man, I missed your post, MJ! They look like twins! Other than wrestling on the 1.25 inch sway bar, I'm finally finished with the front suspension! Now time to bend some brake lines and get back to body work!
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 03-27-2016, 09:45 PM   #53
scottofksu
scottofksu's Avatar
Rear cab support? Gone! Motor assembly commencing soon...
Making progress at glacier speed, but making progress nonetheless!
Old 03-27-2016, 09:50 PM   #54
scottofksu
scottofksu's Avatar
Inside of what remains of the rear cab support. Good metal. Might try to clean it up and only patch in the outer piece with new metal. Slowly backing into replacing the inner and outer rocker.
Old 03-27-2016, 09:55 PM   #55
scottofksu
scottofksu's Avatar
That Christmas wrapping paper is custom... Good for at least 48 HP.
Old 05-24-2017, 12:07 AM   #56
scottofksu
scottofksu's Avatar
Progress! Engine is coming together:
http://67-72chevytrucks.com/vboard/s...=1#post7950504
Transmission purchased and rebuilt with Viper internals and front shift.
Old 05-24-2017, 08:47 AM   #57
ChrisV
ChrisV's Avatar
Good story. Good luck on progress
ChrisV is offline   Reply With Quote
Old 06-09-2017, 10:02 AM   #58
scottofksu
scottofksu's Avatar
Thanks! Obligatory motor pick. Valve covers coming today!
Old 07-22-2017, 10:57 PM   #59
scottofksu
scottofksu's Avatar
Engine nearly done!
Old 07-23-2017, 06:24 AM   #60
Mjminino
Old 07-23-2017, 07:54 AM   #61
northern 85
northern 85's Avatar
Nice
northern 85 is offline   Reply With Quote
Old 06-21-2019, 10:54 AM   #62
scottofksu
scottofksu's Avatar
Engine Ready. Transmission Ready. Patched and painted firewall.Installed disc/disc 12” double diaphragm brake booster from a 2002 GMC Sonoma, and CPP master with disc/disc prop valve. Installation was a breeze with Captains bracket for converting to hydraulic brakes! On a related note, I now have all the hydraulics for the T56 clutch! Oh, and washed the windshield!
Old 07-19-2019, 11:03 AM   #63
scottofksu
scottofksu's Avatar
Turning some attention to the interior.
The speaker is shot!
Old 08-03-2019, 05:56 PM   #64
scottofksu
scottofksu's Avatar
Ready for new speakers!
Old 08-03-2019, 05:58 PM   #65
scottofksu
scottofksu's Avatar
Drivers front cab support is done. Working on the passenger side. Making small holes into big holes only to discover about a pound ofJefferson County dirt!
Old 08-03-2019, 06:00 PM   #66
scottofksu
scottofksu's Avatar
Only one section of the stock cab support has been eaten by the rim worm. Patch cut, and welded into place.
Old 08-11-2019, 11:05 AM   #67
scottofksu
scottofksu's Avatar
Firewall painted inside and out!
Old 08-12-2019, 08:58 PM   #68
scottofksu
scottofksu's Avatar
From little holes to big holes to no holes! Entire cab floor nearly done!
Old 08-18-2019, 12:23 PM   #69
scottofksu
scottofksu's Avatar
Finally have the patches in place! Lesson: it is so much easier to buy patch panels - even I’ll fitting ones - and cut out what you need! Forming my patches to match the stock contours of the floor took more time than anything else! I didn’t weld all the way to the wall as rockers will be replaced soon and I wanted to keep some flexibility for removing the heavily rusted inner rocker panel.
Old 08-18-2019, 08:00 PM   #70
likaroc13
Rollin' Old Skool
Good to see you plugging away. Keep up the good progress. If you didn't already, I'm sure you hate rust now!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 08-19-2019, 10:20 PM   #71
scottofksu
scottofksu's Avatar
Thank you, Sir!
After failing to make significant progress for some time I started trying to just do a little work on her every day (30 minutes to an hour). This has helped massively in comparison to waiting for big chunks of time that never materialized... I hate rust, but it helped me become a much more confident welder! That said, this is why I’m painting everything in tons of POR15! I don’t want to do this again in 50 more years when I’m 90!
Old 08-24-2019, 09:29 AM   #72
scottofksu
scottofksu's Avatar
Pinholes filled, weld ground down. Cab floor = DONE!
Old 08-25-2019, 08:03 PM   #73
scottofksu
scottofksu's Avatar
2/3 of the inner cab floor and firewall painted!
Old 09-25-2019, 10:50 AM   #74
scottofksu
scottofksu's Avatar
Scored a 67 deluxe seat to rebuild!
Old 09-25-2019, 11:07 AM   #75
scottofksu
scottofksu's Avatar
