12-04-2011, 08:06 PM | #51 |
Re: 454 no start help!
if u think timming is the issue unhook the positiv lead -ingitiinon on the distributor with no fire it should not have problem cranking normal or faster than just a little
12-04-2011, 08:08 PM | #52 |
also u might wanna disconnect the tachmeter wire on the distributor if it as one ive seen faulty tach making this kind of problem
12-04-2011, 09:01 PM | #53 |
I got it! Thanks you all very much!! I moved the ground from the frame to the block. It fired right up! I still dont quit understand but it works and driving it!!
12-04-2011, 09:54 PM | #54 |
Like I said, the ground was working through something not meant to be the ground and it finally gave up or got moved. I have seen shifter cables, linkages, smaller wires, etc. work for a while.
Be sure to ground the body to the engine or the bat negative or you will have another problem eventually, esp. headlights and/or AC, etc.
74 Longbed 76 Shortbed 87 Shortbed 66 Corvair Turbo 62 Chevy II Turbo 6 |
