#51 |
Re: 66 GMC 4x4 Sub. Just got it!
#52 |
I had a 72 blazer that had a stick in it. It was the one with the granny low gear and in 4 low you could let the clutch out without even touching the gas.
#53 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
If you switch to a disc brake front differential, you will at least have to change your master cylinder to a dual reservior disc/drum master, along with the proportioning valve. This can be done as manual brakes or power brakes.
More than likely your differentials have 3.73 gears. But as said above, back then you could order most anything. When searching for a donor for the front differential, if you find a '76-'87 K5 or K10, the rear differential will have the wider 2-1/2" brakes. That would be worth purchasing for the brake upgrade IMO. Quote:
#54 | |
Doug Posted via Mobile Device
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
#55 | |
Hollister, CA.
![]() Join Date: Sep 2006
![]() ![]() ![]() Ladies, Ladies...Please ... LOL !! Nice Burban, looks to be really solid !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#56 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
He started it! I'm gonna tell Mom! LMAO.
#57 |
I was playing around with some colors. I like these. I know the pic isnt that good.
#58 |
Got some wheels on the burb.
#59 |
Dude you aren't wasting any time! Two tone? I think that looks awesome. The wheels don't look too shabby either. Nice work.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#60 | |
I only painted one door to see if i was going to like the colors. I also put a new shifter in, new side mirrors, backup light lenses, rebuilt the heater lever system on the dash, and put a stereo in. I was kinda bummed the dash was cut up for a stereo before i got it but oh well, made it easy to deal with a new one. Now that I know I like the paint Id like to do the whole interior so i can soundproof and carpet it ![]()
#61 |
Today I pulled the distributor out of the burb and put a different one in. I replaced the one in my '76 about a year ago with an msd hei unit. So, I used the perfectly good one I pulled out to replace the suspect one in the burb. It had a dead miss at start up but would go away after it warmed up a bit. I wasn't sure if it was a carb,,, ignition,,,, lifter,,,, issue but beings the dist. swap wouldnt cost a dime Id start there. Cured the problem and can tell a huge difference in performance. And it took like 10 minutes! Now the wife claims the saved $ should go should go into her clothes shopping fund.
#62 | |
60-66 Nut
Ah, now you see where you went wrong? You should have taken the MSD out of your '76 to try it out. Then you would have to say to your wife 'Well honey it looks like I will be needing to buy another distributor to put in the '76 now"
![]() Quote:
#63 |
Ridin' Dirty
Sweet rig!
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#64 | |
#65 |
![]() Join Date: Jan 2011
Looking great! Do you mind sharing the specific info on your interior colors?
#66 | |
#67 |
Got some new turn signals.
#68 |
![]() Join Date: Sep 2011
Hey man, my new burb is at the truck terminal in VA. About 50 miles away. I should be able to pick it up Monday. I bought a set of axles from an 87 Burb to give me front disk and the ability to raise it of I decide to.
You really inspired me to get 1 of these, so thanks! I guess ![]() Mike
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
#69 |
any updates
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#70 |
![]() Join Date: May 2012
i like it alot.....don't touch it....leave it just like it is.....great truck....
