Old 12-11-2011, 08:05 PM   #51
made2drag
made2drag's Avatar
Re: 86 squarebody made2drag
made2drag is offline   Reply With Quote
Old 12-11-2011, 08:07 PM   #52
made2drag
made2drag's Avatar
Old 12-11-2011, 08:07 PM   #53
made2drag
made2drag's Avatar
Old 12-11-2011, 08:23 PM   #54
made2drag
made2drag's Avatar
to be able to drive it, and get enough lift to turn with these tires, i set up this temporary ball valve set up. i aired it up with a cig. lighter compressor and the fittings don't seem to be leaking even after 6 hours. i need to get some power cable for my viair compressor this week.
still need a tank and pressure switch, 8 smc 1/2 valves, avs 7 switch switchbox and dot air line. the clear line on my truck is made by parker but when i got it home i noticed the working pressure is only 90 psi. for some reason i thought i saw 250 when at the parker store. it is holding at 140 psi right now but need to be safe and get the parker dot air brake line.
probably will add another viair 380. already have plenty of easy street dual needle gauges
Old 12-11-2011, 10:45 PM   #55
KatFish
nice daily ride youre building. you really only need 6 valves unless youre trying to do s2s an all.
KatFish is offline   Reply With Quote
Old 12-12-2011, 10:34 AM   #56
made2drag
made2drag's Avatar
i was thinking i want 8 since the rear will handle better with 2 valves on each rear. that way the air won't transfer and i'll have less sway. i think thats gonna help. idk
thanks for checking my build out.
Old 12-18-2011, 09:29 AM   #57
made2drag
made2drag's Avatar
i sold my tires and wheels
put some spare steelies on until i get my 20's
Old 12-18-2011, 09:30 AM   #58
made2drag
made2drag's Avatar
1 inch of clearance
Old 12-18-2011, 09:34 AM   #59
made2drag
made2drag's Avatar
with 31's i measured 33 inches to the fender well.
bagged with 31's was 25 1/4 inches.
now with the 26 1/2 inch tires it reads 23 3/4 inches.
the tires i want are 255/35/20's, so just a little bigger than these tires. i think i remember them being 27 something tall.
Old 12-18-2011, 09:35 AM   #60
made2drag
made2drag's Avatar
Old 12-18-2011, 05:49 PM   #61
bbbc10
Diggin The SquareLife
kickass! u still have inner fenders in?
bbbc10 is offline   Reply With Quote
Old 12-18-2011, 06:05 PM   #62
luifer76
luifer76's Avatar
looks really good man nice job so far.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 12-18-2011, 07:23 PM   #63
made2drag
made2drag's Avatar
thanks man.
i took the inner fenders out because the bigger tires wouldnt clear.
they were easy to take out...just unbolted them
Old 12-18-2011, 08:48 PM   #64
bbbc10
cool..looks real clean man...makin want to start on mine right now haha
Old 12-18-2011, 09:59 PM   #65
made2drag
made2drag's Avatar
man i checked out your 84 and its sweet too. you gotta do it like the photoshop....for sure
Old 12-18-2011, 10:41 PM   #66
bbbc10
thanks...im goin to,still geting parts should be sometime after the first when i start.
Old 12-22-2011, 10:21 PM   #67
made2drag
made2drag's Avatar
got my front wheels
20 x 8.5
5.25 backspace
since i have the 1 inch light duty rotors...i think they should go on with no trouble, i think people just take off their dust caps and put the boss cap on
not sure if i'll get the 20 x 10's or 8.5's for the rear yet
Old 12-22-2011, 10:21 PM   #68
made2drag
made2drag's Avatar
Old 12-22-2011, 10:22 PM   #69
made2drag
made2drag's Avatar
Old 12-22-2011, 10:26 PM   #70
made2drag
made2drag's Avatar
Old 12-22-2011, 11:33 PM   #71
Devillusion
Devillusion's Avatar
looking good.......will stay tuned for the finally.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 12-23-2011, 07:45 PM   #72
mcboomport
mcboomport's Avatar
Go for 22x10s on the back!! You're making great progress!
Keep it up!
mcboomport is offline   Reply With Quote
Old 12-23-2011, 08:15 PM   #73
lolife99
67-72 parts collector,…
lolife99's Avatar
Get the 20x10's for the back.
Keith
Convert to disc brakes.
Old 12-24-2011, 11:12 AM   #74
made2drag
made2drag's Avatar
cant wait to get my 255/35/20's
they should tuck in there nicely. they are the same size as my whitewalls
Old 12-24-2011, 11:19 AM   #75
made2drag
made2drag's Avatar
hmmmmm...this would put my axle thru the frame and an inch higher...but it would have to be exact to get the axle perfectly to the center of the peak...idk maybe i should do it the boring way......
