Old 01-22-2012, 03:29 PM   #51
1958 burban
1958 burban's Avatar
Re: building 1958 chevy suburban
Bags in and panhard tacked in. Cycled it and everything works as it should except for shocks wont mount, lower bag bracket prevents them from bolting up. Justin will be calling you Monday to see if you can move upper mount holes.
1958 burban is offline   Reply With Quote
Old 01-22-2012, 08:23 PM   #52
1958 burban
Old 01-22-2012, 08:27 PM   #53
1958 burban
Picked up some fleetside bedsides for 40 dollars, going to use them to repair some of the rust and rot on the lower rear body panels.
Old 01-22-2012, 10:41 PM   #54
1959 Apache 3600
1959 Apache 3600's Avatar
I don't know about you, but I think you got a pretty good deal on those. They'd be a bit more pricey in my neck of the woods I'm afraid.
1959 Apache 3600 is offline   Reply With Quote
Old 01-22-2012, 10:47 PM   #55
1958 burban
I agree, I got lucky, got to love craigslist. They were pretty rough , but the sections I needed were good.
Old 01-22-2012, 10:58 PM   #56
Kim57
Kim57's Avatar
Looking good, great find on the bed sides.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-23-2012, 12:09 AM   #57
Flames97
Flames97's Avatar
Wow, this thing is killer. I just spotted this thread and read through it all.
I like where you are going with this build. I'm sticking around for this. Keep up the good work.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 01-25-2012, 03:45 AM   #58
Black Widow Customs
Black Widow Customs's Avatar
Thing Is Lookin Good Joe cant wait to see it Draggin Down the Street !!!
Black Widow Customs is offline   Reply With Quote
Old 01-25-2012, 06:28 PM   #59
1958 burban
Thanks BWC for all your help.
Old 01-26-2012, 10:02 PM   #60
1958 burban
Was finally able to roll it out of the garage and get the full view. I like it but debating on whether or not to Z the front a few inches, still not low enough in the front. ???????
Old 01-26-2012, 10:26 PM   #61
1958 burban
Sitting an inch from the floor in the back and 1 3/4 inch in the front. Is it worth all the work?????
Old 01-26-2012, 10:45 PM   #62
youngrodder
youngrodder's Avatar
I think that is looks great. Do you plan to drive it that low of just lay it out at shows? I would leave it alone but now would be the time to do it. I'm glad that I could help you make up your mind...he he he
Keep the pics coming.
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-26-2012, 11:01 PM   #63
jmedero
jmedero's Avatar
I'd put in 3/4 inch spacer in the rear and raise the rear up to match the front. It won't be noticeable once she's level. Just my opinion.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-26-2012, 11:10 PM   #64
yunkyarddog
yunkyarddog's Avatar
Originally Posted by jmedero View Post
i'd put in 3/4 inch spacer in the rear and raise the rear up to match the front. It won't be noticeable once she's level. Just my opinion.
posted via mobile device
x2
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time
94 s10 4x4 4.3/5speed (dd)
68 lwb GMC 350/4speed
52 5 window GMC I6/4speed 12v (8lugs and long bed)
53 bel air 235 I6/powerglide
yunkyarddog is offline   Reply With Quote
Old 01-27-2012, 09:03 AM   #65
duallyjams
duallyjams's Avatar
You won't notice it in the grass at a GG show. I think it's look great.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-27-2012, 01:12 PM   #66
_Ogre
_Ogre's Avatar
the way it is, you won't bottom out if you have an air line/pump/fitting/bag/solenoid/wiring/switch/nipple/ect... failure
if you insist put a 3/4 shim in back
shop air compressor timer
Old 02-04-2012, 09:40 AM   #67
1958 burban
Motor mounts are in ..
Old 02-04-2012, 10:04 AM   #68
1958 burban
Also got smooth dash piece in, and need to put in ignition hole.
Old 02-04-2012, 10:07 AM   #69
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 02-04-2012, 01:20 PM   #70
Daze57
Daze57's Avatar
^ x 2
Daze57 is offline   Reply With Quote
Old 02-04-2012, 02:37 PM   #71
Scottshotrods
Your new shock crossmember was sent out on friday by ups !!!!
Justin
Scottshotrods is offline   Reply With Quote
Old 03-08-2012, 10:08 PM   #72
1958 burban
Got air tank and compressor brackets made, they will be mounted in front of the rear axle , behind front seats , but under the floor.
Old 03-04-2014, 01:26 PM   #73
NEWFISHER
NEWFISHER's Avatar
Any progress since 2012? Did it sell or is it piling miles on it?
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-04-2014, 01:39 PM   #74
Scottshotrods
Was sold to a person in ca who is having it chopped now.
Justin
Old 02-23-2015, 11:26 PM   #75
Groyd
Groyd's Avatar
That's sad. I'd like to see more of these 55-59 burbs on here. Tell the new owner to start a thread.
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
