Old 01-30-2012, 10:48 PM   #51
85burb
85burb's Avatar
Re: Guaging Interest
I hope these are right. The packing slip says thy-323y-c 67-72 gm c10 ls-swap headers. Is that what it is supposed to say?
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 01-30-2012, 11:01 PM   #52
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
looking at your 1st pic....I'd say yes....those mounts look like they have the motor a bit forward. looking at it imagine the sbc mounts further forward on longer LSx brackets/plates...the motor would be further back.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-31-2012, 09:20 AM   #53
Shon
Originally Posted by 85burb View Post
I got mine in today. Very happy but they are not long tubes. Mid length at best. But for the only option i have they are perfict!
U will be glad they redesigned them, the original 1 5/8" dumped right at the trans and made for little to no clearance to hook up the trans 'stuff'
And the 323Y-C is the correct part number.
As for the adaptor mounts that everyone can use; make sure they are put on correctly. I made that mistake and headers would not fit and I got really discouraged but in the end I realized I had the adaptor plates on incorrectly- as seen in this pic *NOTE: The adaptor plate is on WRONG*
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 01-31-2012, 06:23 PM   #54
shearjs
shearjs's Avatar
This looks eerily similar to the issue I was having. Using those adapter plates, I had to use the rear 6 cyl mounting holes for the perches, and my headers were hitting the perches. I recently found some stock and made some new adapter plates that should allow me to move the perches to the front holes and keep the engine roughly in the same location as your pic. I used info from this post and created some plates that resemble #1. Unfortunately, I haven't installed them yet, so I can't say for sure it's going to work out just perfect. Hope this helps.
http://67-72chevytrucks.com/vboard/s...70&postcount=1
shearjs is offline   Reply With Quote
Old 01-31-2012, 06:45 PM   #55
bman67
bman67's Avatar
Shon,
How long do you anticipate the Group Buy will last?
bman67 is offline   Reply With Quote
Old 01-31-2012, 08:28 PM   #56
66ChevyMax
66ChevyMax's Avatar
Got the new adapter plates in and thing are much better. Thanks again to SHON and DT.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 01-31-2012, 08:31 PM   #57
66ChevyMax
66ChevyMax's Avatar
These headers are very nice IMHO. Take a look at the DT vs Sanderson LS10's.
Thanks a million Shon!
Craig
Old 01-31-2012, 09:39 PM   #58
66ChevyMax
66ChevyMax's Avatar
Stock Dip works
Craig
Old 02-01-2012, 12:25 AM   #59
85burb
85burb's Avatar
Thanks for clearin that up for me. I cant wait to get them installed at least for a test fit!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-01-2012, 04:39 AM   #60
chevy-fun
chevy-fun's Avatar
Got mine this afternoon, prob be a wk or 2 before I put them on though. Thanx again Shon
chevy-fun is offline   Reply With Quote
Old 02-01-2012, 09:39 AM   #61
Shon
Originally Posted by bman67 View Post
Shon,
Just a few more days so be sure to get yours while they are in stock and you do not have to wait!!!
Thanks to you guys for making this happen!!
Old 02-01-2012, 09:41 AM   #62
Shon
Craig and others, if you wanted a little more space btwn the tube and coil you can get a longer bolt and a 'spacer' to get the tube away from all that slightly.
I did this on the coupe, I can post pic if you wanted. I had some various bolts sitting around and some misc 'spacers' I had from another venture and it worked..
Originally Posted by 66ChevyMax View Post
Stock Dip works
Old 02-03-2012, 07:45 PM   #63
BigShoe24
True Addiction
BigShoe24's Avatar
Received mine today. Thanks again. Hopefully I'll be able to install tomorrow.
RCC
BigShoe24 is offline   Reply With Quote
Old 02-04-2012, 10:50 PM   #64
BigShoe24
True Addiction
BigShoe24's Avatar
FYI all, these do not fit with a Porterbuilt dropmember.
RCC
Old 02-05-2012, 02:25 AM   #65
c10seconds
c10seconds's Avatar
Crap!!! I wonder if they'll fit with the mild dropmember?
c10seconds is offline   Reply With Quote
Old 02-05-2012, 11:47 AM   #66
dkauffman05
dkauffman05's Avatar
I have my coils on the rear of my heads and wanted to rout my wires down using 90 degree plug boots and behind the headers against block and up to my coils. Hard to tell in epics but you guys think there is enough space to do so between tubes and engine?
dkauffman05 is offline   Reply With Quote
Old 02-05-2012, 02:52 PM   #67
BigShoe24
True Addiction
BigShoe24's Avatar
The issue is on the passenger side. The rear tube hits on the firewall.
RCC
Old 02-08-2012, 12:51 PM   #68
bman67
bman67's Avatar
Ordered mine last night. Looking forward to see how well they fit.
Old 02-08-2012, 12:55 PM   #69
shearjs
shearjs's Avatar
Finally got mine mocked up. They fit quite well.
Old 02-26-2012, 10:36 PM   #70
85burb
85burb's Avatar
Got mine istalled to day. If you have the dirtydingo adjustable mounts in a 73-87 make sure you have motor really far forward. I had mine guite a bit back and they hit firewall. Slid motor forward and adjusted pinch weld and they fit pretty good. Driver side fits like a glove. Passenger side i never want to do plugs again.....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-08-2012, 11:35 PM   #71
rmvlt1100
rmvlt1100's Avatar
SHON; do you have any of these DT 323Y-C headers in stock. If so I will take a set.
Thanks,
Robert
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 03-09-2012, 09:22 AM   #72
Shon
Thanks,
Robert
DT has 5 waiting to go out
http://www.herronperformance.com/sto...&productId=457
Old 03-09-2012, 11:31 AM   #73
rmvlt1100
rmvlt1100's Avatar
That sounds good, do you know when they would ship out? And do I order them through your web site or can I call to order them?
Thanks,
Robert
Old 03-09-2012, 11:39 AM   #74
Shon
Thanks,
Robert
Order thru my site, it takes PP or CC (even if you do not have a PP acct) and you get an order number/etc.
They would ship out by Monday, if we get the order early enough they might go today but within 24hrs of purchase they should go out if not on the weekend or holiday.
IF they happened to have sold alll 5 within the past 3 days I will get an ETA on a new batch being ready....
Old 03-09-2012, 11:59 AM   #75
rmvlt1100
rmvlt1100's Avatar
Thank you for the quick response I will go to your web site and order them right after this post. Also I have read that the DT 324Y-C headers fit the same years, can you get these? If by chance they are gone, can you another header that fits that fits the same years? If not an ETA would work.
Thanks again,
Robert
