01-23-2012, 02:23 AM | #51 |
MOTORHEAD!
Re: Engine?
This car is an iron headed (781 I think) 496. It's making 657hp and 675tq. It's a daily driver.
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph Last edited by 69GMC910; 01-23-2012 at 02:36 AM. |
01-23-2012, 12:36 PM | #52 | |
Re: Engine?
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
01-23-2012, 01:12 PM | #53 | |
Re: Engine?
Thank you for the honest example. You can get an ls2 with trans and harness, put headers on it, put a cam in it, add injectors and get it tuned. For about the same amount. Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
01-24-2012, 01:48 AM | #54 |
Re: Engine?
That's the price for a used motor right?
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car |
01-24-2012, 11:05 AM | #55 | |
Re: Engine?
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
01-25-2012, 01:41 AM | #56 |
Re: Engine?
Yeah, the LS engines are cool but, you can get more torque out of a BBC than an LS from the articles I've read. My 496 also is going to have, forged Scat crank and I beam rods as well as, forged SRP pistons for a grand total of $1700 for the rotator kit.
01-26-2012, 10:57 PM | #57 |
Re: Engine?
01-29-2012, 10:49 AM | #58 |
Re: Engine?
In regards to 69 910 GMC, I could see no problem with a 700 HP pump gas 496 running very easily into the 10s in the same conditions you run your LS in with power adders. Mid eighties 1/2 ton, 4000 pounds, 3.50 gears, pump gas normally aspirated hyd roller 700 HP 496 driver, 10 sec truck at Sacremento easily, heres an honest example of a 9000.00 power plant.
01-29-2012, 09:45 PM | #59 |
Re: Engine?
I would hope a 496ci motor would run as good as my little 347ci motor did on a 100 shot, it has 150ci on it. Now as my cubic inches get closer to that 496 mark (418ci) I would suspect I would need less bottle.
Again, I am not saying you can't make big power on the BBC platform. With any NA motor, if you have comprable heads for the ci (flow enough for the ci), the right cam and combo, a bigger cube motor should make more power, period. I just see too many bad big block combos to be an advocate of the big block craze. I'm not drinking the cool aide, but then again a lot of you big block guys aren't drinking the LS cool aide.. To each his/her own. That's what makes this sport fun!!
01-29-2012, 10:50 PM | #60 | |
Re: Engine?
01-30-2012, 12:07 AM | #61 |
Re: Engine?
If I put a big block in it, it wouldn't be light weight anymore at some point I will change the combo, go with a solid roller in hopes to go 9's. And please correct me if I am wrong, and I do respect his truck, but I believe dj never went 9's NA with his big tired big block truck with less weight than me.
01-30-2012, 12:12 AM | #62 | |
Re: Engine?
01-30-2012, 07:40 PM | #63 |
Junior Member
Re: Engine?
I went 9.8o's with number one rod trying to come out...and my truck is all steel no power adders. The best motor for him is what he can afford and what he is comfortable working on. IMO
68 GMC 565 BBC Abruzzi super pro glide 9.85@135.00 |
01-30-2012, 09:55 PM | #64 |
Re: Engine?
I look at what an engine can make per cube. that 496 is making 1.44 per cube,.. very nice ,..a 376 CI LS engine will make 1.46 very easy.
I have owned BB, SB and yes the LS as well. Dollar for dollar you can not beat them ,... facts are what they are. If I did not have the parts I had from the 383 that went south. I would have went LS all the way. There was a great write up a while back on a 6.0 that they bought a cheap stroker kit and went at it. Heres the link,http://www.carcraft.com/techarticles...d/viewall.html now take that same bone yard engine that you start with say 1500 bucks another 1500 in the stroker kit, swap the cam intake carb, ign and you are making well into the 575-600 range and all in money wise you can spend about 5000-6000 buying all new parts and have a engine that makes killer power is is extremely tough and will still handle the juice for the extra power I built a el cheapo 413 stroker for the junk yard engine. With some looking around we where able to pick up a few used parts here and there. Once done with a E bay pro form carb and PP intake it laid down 612 hp that 1.48 per cube. Total budget 4100 bucks. Gotta love a BBC for running on 7 TOO funny
62 long box with a little SBC http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
01-31-2012, 12:15 AM | #65 | |
Re: Engine?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
01-31-2012, 01:23 AM | #66 |
Re: Engine?
Kevin, I hope you weren't thinking I was bagging on your truck, not at all. Your truck has always impressed me. I used you truck as an example as it is/was lighter than mine, more cubes etc. It's not as easy to go 9's let alone 10's NA in one of these trucks, yet some make it sound like they grow on trees.
01-31-2012, 01:45 AM | #67 | |
Re: Engine?
Sorry to hear about the home front and truck delays! lord knows I have been there. If I can help I am just sitting on the couch recovering from surgery I'll take a road trip if need be.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ Last edited by bigboybodry; 01-31-2012 at 08:06 AM. |
01-31-2012, 08:19 AM | #68 | |
Re: Engine?
01-31-2012, 08:45 AM | #69 |
Re: Engine?
I haven't made any more yet. Hopefully will have time in the next month or so.
01-31-2012, 09:26 AM | #70 | |
Re: Engine?
01-31-2012, 11:05 AM | #71 |
Re: Engine?
I would hope a 467ci big block would get my truck in to the 10's. It would be rather sad if it didn't. You should go in to the big block building business and show some of these other cats how to make some power. Again, I am not saying big blocks can't make power.
01-31-2012, 11:13 AM | #72 |
Re: Engine?
DJ that is a killer ride, Not junk from what I see..
I understand how hard it is to get to those time. Thumbs up in my book
01-31-2012, 12:03 PM | #73 |
"Where were you in '62?"
Re: Engine?
Teehee..............
You fellas have a little Outlaw 10.5 Blood in ya.... Just let it out and go all out! PLR 670ci 4000+ HP - Pro Line Racing Engine http://www.prolineracing.net/ This is what 1Bad wants to be..........Fast Freddy But for now I currently running Poor/Street Class - (Poe/Street) (Poe/Street class is for the high class fellars & thier trucks.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
01-31-2012, 05:33 PM | #74 |
Re: Engine?
Incase some of you dont know, Vortecpro, Mark Jones, is in the BBC business. He ports old iron that have flow numbers equal to or better then AFR CNC ones. He knows what he is doing.
01-31-2012, 06:04 PM | #75 |
Re: Engine?
Most of you fellars are in the CA area or out west, but if anyone is located in SC or NC area.
Gene Fulton of Fulton Competition is one of the best engine builders around. Fulton Competition specializes in large cubic-inch aluminum Chevrolet engines and custom nitrous systems. CHEVY ONLY RIGHT http://www.fultoncompetition.com/Ful.../About_Us.html http://www.shop.synergycafe.net/mm5/...re_Code=fulton From Street Racers, Nitrous Quick-8 and 10-inch Tire to Sportsman and Pro-Modified, Fulton Competition constructs custom engines that lead every racer to the Winner’s Circle. Everytime I'm in there I just love to druel over those massive Big Blocks...... 820 cubic inches...Can I touch it fellas... 1Bad it's time to leave.
