Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-05-2012, 11:54 PM   #51
Vortecpro
Re: 496 to be DYNO'D!
Originally Posted by 69GMC910 View Post
Short delay on the dyno.... Should be friday or saturday...!
Sorry for the delay on my end, having some problems with my dyno, I think we have figured it out and will have some numbers soon, the cam is 570 608 238/248, BTW my guess is 700, any way you want to look at it, your truck could run 10s with this very streetable engine.
Vortecpro is offline   Reply With Quote
Old 03-06-2012, 12:04 AM   #52
69GMC910
MOTORHEAD!
69GMC910's Avatar
my bad on the cam specs...
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 03-06-2012, 12:31 AM   #53
Super73
Super73's Avatar
I am always interested in modeling motors in performance trends. Mind sharing actual head flow data at. 300 .500 .600? Also. Is the motor set up with factory tolerances or a little looser? Factory widange or does it have a tray and good pan?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-06-2012, 01:17 AM   #54
Boogie_Man
Boogie_Man's Avatar
Ooo Emm Gee... That vid was sick! Looking forward to hearing your numbers dude!
'71 Short Stepper - One piece at a time!
Boogie_Man is offline   Reply With Quote
Old 03-06-2012, 01:28 AM   #55
Vortecpro
Flow @ 28 inches, 4.310 bore. .200 171 .300 233 .400 281 .500 317 .550 323. 270 CC runner. Deep pan. Very low drag bottom end. 600 HP by 4900 RPM, 700 HP @ 6300 RPM 238@.050 HYD roller.
Old 03-06-2012, 08:54 AM   #56
shawnt
shawnt's Avatar
Hmm, with flow numbers I change to 713 hp @ 6400.
All these 500hp guess wont get the virtual high five. It WILL be 665+ I guarantee that
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 03-06-2012, 09:53 AM   #57
ripdog28
ripdog28's Avatar
If Mark says 700 @ 6300, that is with in a few numbers. He has built more then enough and flowed way too many heads to know what itll make.
I want him to do my next build.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 03-06-2012, 12:38 PM   #58
hotrod 80
mini truck racer
hotrod 80's Avatar
662 hp
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 03-06-2012, 01:21 PM   #59
Super73
Super73's Avatar
Numbers PT gave are below running 91 octane and 165* coolant temps.
Adjusting windage and setting the bottom end to a lower drag set up netted a pinch over 30ftlbs and 30hp through out the full curve bringing 641ftlbs @ 4,600 and 629hp @ 5,600.
Adjusting headflow after adjusting the windage/friction netted 642ftlbs @ 4,500 and 630hp at 5,700. Keep in mind, I don't have updated flow numbers for the exhaust which could move things higher if I had them. Also, wish I had .600 numbers to use over .550. I have found the program to be most accurate using .300 .500 and .600. I know the intake side of the cam never sees that lift, but it just works better. Could be showing less power with that as well.
Also, Mark did not provide all the details on the cam. IE intake centerline and LSA. I am going off previously posted LSA and a 112 ICL.
Unfortunately the program is only as good as the info provided. It has proven itself time and time again when ALL the accurate data is given. But there is a lot of guess work here. I hope it is conservative and you get to that 640+ftlbs @ 4,900 and 700hp @ 6,300 Mark is mentioning. I know this isnt the first motor Mark has built.
Old 03-06-2012, 01:27 PM   #60
Super73
Super73's Avatar
One additional comment, If you take the power curve PT gave, move it up 300rpm which is closer to where Mark says it will make peak TQ
642ftlbs@4,900=599hp
580ftlbs@6,000=662hp
536ftlbs@6,400=653hp
Old 03-06-2012, 05:55 PM   #61
RatPwrd72
RatPwrd72's Avatar
I'll go with Mark over the air dyno any day. That is all.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 03-06-2012, 06:10 PM   #62
69GMC910
MOTORHEAD!
69GMC910's Avatar
My guess is 711hp, 684tq
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 03-06-2012, 07:23 PM   #63
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Not going there at all.
SBC forever!
Sounds like you'll have a beast no matter what the numbers will be.
Have fun.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 03-06-2012, 10:37 PM   #64
Vortecpro
My 9.5 compression 049 headed 496s with a 238 @ .050 HYD rollers go 670 @ 6200 RPM and 660 TQ.
Old 03-06-2012, 11:41 PM   #65
ripdog28
ripdog28's Avatar
69 c-10 BBC
Old 03-07-2012, 12:08 AM   #66
gearys 5600
gearys 5600's Avatar
sign me up for a steel headed 9-1 comp, small cam, 496 that makes 700 H.P.
Sounds like I wasted a ton of money bulding my 496 !! 13.5 to 1 comp, brodix cnc'd bb2 extras, big solid roller, super victor,1150 dominator that made a little over 800 h.p.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 03-07-2012, 03:06 AM   #67
Super73
Super73's Avatar
Again, I don't have the full scoop on the motor. Garbage in = Garbage out. The program has proven itself with in 2% on quite a few wild motors. Not saying this build won't make what you are saying, just using the info that I have.
Old 03-07-2012, 03:54 AM   #68
68Redhead
Wow Mark, do you have payment plans?
Can't wait to see the numbers, I keep going back and forth between a 454 and 496 for my 'velle!
68Redhead is offline   Reply With Quote
Old 03-07-2012, 09:59 AM   #69
Vortecpro
How about a 11.5 comp, 049 headed solid roller, 4150 carbed, 800 HP engine....
Old 03-07-2012, 01:52 PM   #70
gearys 5600
What did you have this engine in ?
What were the specs on the car/truck , weight, gear ratio, and what are the numbers at the track ?
Dyno sheets don't mean much to me, it's real easy to inflate the numbers.
1956 chevy nomad
Old 03-07-2012, 10:01 PM   #71
Vortecpro
Generally this is where I would go into defensive mode, BUT, I did see the picture of your beautiful L78 camaro and I do believe you do deserve some respect. The 800 HP oval port 11.5 compression engine has not been down the track yet, my customer will have runs on it coming up this spring. To me, I like to know the (racing background) of the people questioning my dyno numbers. So I think its only fair I state my background. I machine and build and test my own engines, everything is machined in house with the crankshaft as an exception. 1. Two strait hot street championships (550 inch NA 10 inch tire 3350 pounds) both ends of the records, won every race except for 1 over a two season span, as an engine builder. 2. The fastest full weight, small tire, oval port (GM) production blocked chevelles in country come out of my shop. 3. Just for you I have an example of a Vortecpro powered 468 NA camaro, I think you just might be able to identify with. NA 468 9.40 @ 142.40 1.28 60 on the foot brake @ 1670 feet DA @ KCIR. BTW on that dyno you questioned the HP of, it made (the 468) 45 less hp than yours, 795 HP. Happy reading
Old 03-07-2012, 10:42 PM   #72
mud.man.rj
mud.man.rj's Avatar
9.40 and foot braking is quite the wow factor.
mud.man.rj is offline   Reply With Quote
Old 03-08-2012, 04:21 AM   #73
smoknbarrels
Registered Mail
smoknbarrels's Avatar
Please make yer estimates for HP and TQ! Engine should hit the dyno this wknd or early next week.
496
10.2CR
AFR 265's
.578I
.608E
RPM Air Gap
850 Holley
Closest guess wins a virtual high five!
910
This at 700hp, (not saying it's not) but I must have really been low balled on my 496, at 630HP. my set-up:
Holley 850 DP 4150
10.7 CR
RPM Air Gap
Performer RPM oval heads
2 inch primaries headers
Roller rockrs/cam with a 304HR comp cams
looser bearings
Your AFR heads flow a bit better, would it make that much of a difference? eventhough I have more lift I still don't flow quite as good.
smoknbarrels is offline   Reply With Quote
Old 03-08-2012, 04:56 AM   #74
moggey01
What Hot street class are you talking about? I know NMCA had it and switched the name for the N/A class. Just curious we ran that stuff with a 318 engine and a 5 speed.
moggey01 is offline   Reply With Quote
Old 03-08-2012, 08:59 AM   #75
Vortecpro
Holley 850 DP 4150
10.7 CR
RPM Air Gap
looser bearings
Theres alot more to consider than just air flow, the AFR 265 does demoralize the RPM heads, esspecially when your only lifting the valve .570. This engine will peak @ 6400 RPM when its all said and done, thats something else to consider, I have not had much luck with the comp hyd roller lobes, remember Ive been developing these exact same engines for 7 years now. I dont think you got hosed, I just know what goes into my engine, and its a little more than an average rebuild. At this point Jarred I think I will ask Harold Bettes to come down and supervise these final tests and write a report on this engine and how it was tested. So stay tuned and lets see what we end up with.
