Old 03-14-2012, 05:05 AM   #51
C-10cutty
C-10cutty's Avatar
Re: 1960 k-20
Originally Posted by j.kirn View Post
Color iis neptune green with bombayivory white cap, bumpers
That's what I'm painting my '62, love the color.
C-10cutty is offline   Reply With Quote
Old 03-14-2012, 05:53 AM   #52
j.kirn
Re: 1960 k-20
Originally Posted by argonaut View Post
j.kirn,
I love your pickup! It is the one of the main "inspiration" trucks for my 66 K10 build. I really like the stock-ish look of your pickup. I wouldn't change the wheels/tires unless you plan on driving it a lot at higher speeds. What size are your wheels/tires now?
I will probably go with a radial tire on my truck because it will see a lot of socal highway. Thinking of a 33x10.5R15 or a 285/75R16 depending on what rim diameter I end up with. Most likely an 8" wide rim. Not sure on offset yet, might keep the offset similar to stock, or keep the backspacing similar to stock for a wider stance.
Thank you,7.50by 16, i dont do much highway with a 4.57 gear ratio
j.kirn is offline   Reply With Quote
Old 03-14-2012, 11:48 AM   #53
61K10
61K10's Avatar
Re: 1960 k-20
j.kirn---your rear shocks look mounted the same as mine. ft can't really tell. do you have any part # for your shocks ft and rear? thanks------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-14-2012, 03:39 PM   #54
j.kirn
Re: 1960 k-20
Yours should mount the same way, i had to meausure from mounting location top, bottom then go to a place here where i live and give them the meauserments and they figured out what shocks i should have for the right travel of the shocks.TONY SMITH on stovebolt might be ab le to give you a correct part no for shocks.4-5-6-chevy trucks is what he goes by. If you need help with any other thing or if i can help with parts pm me,ill give you my phone no.
Old 03-15-2012, 11:44 AM   #55
61K10
61K10's Avatar
Re: 1960 k-20
thanks j.k--- thats what i was thanking to do. (just looking for the east way out) and thanks for the offer for your wisdom. Im old and set in my ways (rather do it myself type) but you never know!
1961 chevy K10
Old 10-16-2012, 02:11 AM   #56
steven.burns
steven.burns's Avatar
Re: 1960 k-20
Your truck is exactly what I was thinking of doing with my '62 GMC. Same color, Stock look. It looks better than I could have pictured in my head. Amazing truck!
steven.burns is offline   Reply With Quote
Old 10-16-2012, 07:11 AM   #57
j.kirn
Re: 1960 k-20
Thank you , i am currently working on my 62 k-20 and i an gonna paint it blue and white
