#51 |
Still Learning
Re: 68 camaro vs. 06 GTO hybrid
Awesome work on everything. Can't wait for the next update
#52 |
little more progess to update... got the interior re-upholistered, reoved the 'GTO' script on the front seats and inplace put a chevy bowtie.. also on the steering wheel, removed the pontiac emblem and replaced it with a embossed chevy bowtie...got the dash covered in leather, and carpet installed....then put the guages, radio, dash controls, etc. in...
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
#53 |
#54 |
added the door switches, so the dome light, radio (will turn off when the door is opened, and key off), and theather lighting, etc.. will all be controled as intended
and installed a set of LED tail lights ![]() ![]() ![]() ![]()
#55 |
#56 |
also moddified the stock camaro door latches/ handles to work with the GTO door striker assy. that got retro fitted in the door, so the power door locks, power windows, would work as they should... here is a picture story, kinda...
#57 |
#58 |
![]() Join Date: Nov 2004
Wow... going to be an amazing car. I love it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#59 |
GEARHEAD
Wow!
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#60 |
Still Learning
Awesome work as always. Keep the pics coming. I really like where you have taken this project.
#61 |
This has got to be one of the most bad ass cars I have seen.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
#62 |
ok everyone, here is a sneek peak of the progress of this camaro... got it back from the paint shop (still needs to be rubbed and buffed out), and the interior shop (they put the new convertable top on, and a sound system in) anyways here are a few teaser pics
#63 |
Still Learning
AWESOME!
More pictures..... Posted via Mobile Device |
#64 |
Plenty more comen soon
#65 |
Wow...
#66 |
Beautiful. Love the color.
Ulysses |
#67 |
![]() Join Date: Jul 2007
Looks awesome!!!!!
#68 |
ok here is a little update, iim wrapping up all the "little" things, but time consuming....
first on the list was making the trunk open with the GTO key, so i robbed the key cylinder out of the GTO door handle, then i proceeded to moddify it to work, using the GTO and camaro parts, and some scrap metal i had... ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#69 |
now due to the positioning of the HVAC unit, the stock GTO air ducting didnt fit anymore, so i had to make some adaptor pieces so i could make the vents actually blow air through them...once i had them made, i blasted and painted them.... there is also a rod that connects the temp control knob to a lever thats on the HVAC unit, this rod was about 1.185" to short, so i got some round rod slightly bigger then the HVAC rod, then i drilled holes in both ends, and tacked the orignal rod to it, now it works like a champ....so here is the process of makeing them, and the install
#70 |
now for the driver side, there wasnt much realistate to work with on the dash for a air vent, so borrowing the idea off of 70's firebirds, i made use of the empty space under the column... this is what they call a crotch, or knee cooler....i started off with a vent that kinda match the width i needed, then with the use of a hammer handle and a heat gun, i molded it into shape...
and then more of the same on the adaptor plate to the HVAC unit.... ![]() ![]() ![]() ![]() ![]()
#71 |
now with every mod to a car like this there seams to be more and more things you gota make work, the problem i then ran into when mounting the new crotch cooler was that the vent interferred with the lower column cross brace, so i had to fab a new one to clear the new added round vent/ hose... here is the new one, i dubbed the "bat-wing"... once the bat-wing was made, it got the same blasting and painting treatment.... once all that was done, i simply connected the HVAC adaptor piece to the crotch cooler with a/c flex hose....
#72 |
Awesome work so far!! keep it up and keep us in the loop
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#73 |
Oh my god! This car is coming out so beautiful and you are doing such an awesome job. Keep up the awesome work, man.
#74 |
I do believe this is a 67. Pic 16 shows the fun, I cut a Horizon in half and drove the front half around the shop. It was for my daughter's first car.
#75 |
6>8 Plugless........
![]() Join Date: Sep 2007
This car has came a long ways! Great work! Is it done now?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
