Old 04-22-2012, 09:29 PM   #51
79 blue monster
79 blue monster's Avatar
Re: project: 3/4 ton dropped
Originally Posted by 79gmcclassic View Post
now that sunflower is sweet. hahaha jk i love the stance of the truck! whatd you put smaller tires on the rims that came on the truck?
haha, yeah the tires are low pros from our van.lol
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
Old 04-22-2012, 09:41 PM   #52
79gmcclassic
79gmcclassic's Avatar
it actually doesn't look too bad! put some centers on those wheels and your set while you save for nice wheels!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 04-22-2012, 10:02 PM   #53
79 blue monster
whats all involved in conerting a 3/4 ton to a dually? ..........just thinking.........
Old 04-22-2012, 10:27 PM   #54
79gmcclassic
Dont do it!
Old 04-22-2012, 10:44 PM   #55
79 blue monster
Dont do it!
haha, i found a really sweet looking one, im keeping mine a single, i was just asking..lol
Old 04-22-2012, 10:44 PM   #56
Devillusion
Devillusion's Avatar
It's usually not hard........
I converted mine the other way around DRW to SRW and all it takes is to swap out your front discs, and rear differential. And if you want to run the semi wheels you should look for a rear cab and chassis differential which is only 63" WMS
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 04-22-2012, 11:56 PM   #57
74 stepside
74 stepside's Avatar
Blue Monster, I just measured the rear 12 bolt on my 73 and its 64" from outside of drum to outside of drum. How is it your 14 bolt is 61.5"?? I thought for sure a 14 bolt rear is wider.
74 stepside is offline   Reply With Quote
Old 04-23-2012, 03:18 AM   #58
Devillusion
I'm pretty sure your diffs should measure around 67.5" WMS no? My cab and chassis 14 ff is 63" WMS and it is the narrow one of the family of 14's.
1970 Chevelle
Old 04-23-2012, 07:34 AM   #59
79 blue monster
i didnt get an acurate measurement then. i measured from the outside of my drum to the inside, multiplied that by 2 for both sides. them i measured from backing plate to backing plate.so in the end it should've been correct. i'll have to remeasure....
Old 04-28-2012, 11:09 PM   #60
79 blue monster
update: i didnt get much done on the truck, but i just bought some fiberglass fenders for my truck.
Old 04-29-2012, 08:06 AM   #61
WillieloRidez
WillieloRidez's Avatar
I like it! Keep up the good work!
WillieloRidez Drive em in Drag em out!
Projects:
1956 Chevrolet 210 2dr post
58 chevrolet 2dr delray
58 chevrolet belair 4dr hardtop
1965 Chevelle big block 4spd
88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=388445
WillieloRidez is offline   Reply With Quote
Old 05-22-2012, 11:51 PM   #62
79 blue monster
Update, hopefully will have doors and fenders in primer by this weekend. im almost done with the fiberglass work! ok, so i'm thinking of getting exhaust, i know i already mentioned this, but i dont know where to route it? theirs not enough space to go to the back, and i hate it coming out in front of the rear wheels and it sounds like crap when its pointed twords the ground.?!?!?!?! what do i do? another question, what do you guys think of moto metal 961 chrome. without the red peices.
Old 05-25-2012, 07:53 PM   #63
AussieTruck
Can you tell me what the blue color of your truck is. I am going to paint my 79 a similar color
AussieTruck is offline   Reply With Quote
Old 05-27-2012, 12:04 PM   #64
Can't kech me
Can't kech me's Avatar
http://img.photobucket.com/albums/v6...9/PICT6290.jpg
this set up sounds just as good as out the back, but i know you dont want it to come out in front of the wheel, what about grafting the exhaust into the bedside infront of the wheelweel, that would be sweet!
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 05-27-2012, 12:24 PM   #65
79 blue monster
I honestly couldnt tell you the color, I bought the truck from a guy that owned it for about 2 weeks. He didnt know anything about this truck.
Old 06-07-2012, 11:36 PM   #66
79 blue monster
picked up a box tonight for a decent price. their is only surface rust. i'll just blast it off and fill it in. i'll post some pics tommarow.
Old 06-08-2012, 11:46 PM   #67
79 blue monster
truck too low? i went under the front of my truck to check the clearence i have from my a-arm too my bump stop, and their is none!?! i have no travel up front. my a-arms are 2in off the ground, so i cant get any shorter bump stops otherwise i'll hit on the ground. i cant get different coils because i'll have drop a**. what should i do?
Old 06-09-2012, 12:14 AM   #68
tinydb84
tinydb84's Avatar
If you remove the bump stops and the front drops then you can put new springs in to lift it back up to where it was when it was resting on the stops.
I bought an extra set at the junk yard for when I drop mine just in case.
Old 06-09-2012, 10:37 PM   #69
79 blue monster
yeah but if i put new coils in it then it wont be dropped in the front.
Old 06-09-2012, 10:43 PM   #70
tinydb84
tinydb84's Avatar
It's kinda hard to explain in text. Your springs are too short and might be even shorter. Cut out the bump stops and pull taller springs to match the current height.
Old 06-10-2012, 08:55 AM   #71
79 blue monster
Ohh I see What your saying. I'll have to cut my bump stops and see how much it drops
Old 06-10-2012, 02:49 PM   #72
tinydb84
tinydb84's Avatar
Exactly! If you want more clearance you could section your crossmember an inch and put in taller springs. You can also run taller tires.
Was the 9 inch drop in the rear all due to the axle flip? I got all my brackes but havent dont it yet and want to know what I am going to get into. I was thinking it would be closer to 7inchs
Old 06-10-2012, 06:55 PM   #73
79 blue monster
the drop was about 8in from the flip, and another 1in from the shorter tires. i just put 9in because that was how much it was from stock tires/suspension to shorter tires and suspention.
Old 06-14-2012, 10:29 PM   #74
79 blue monster
been working on my box, filling holes, and now starting to weld up stake holes. any tips on doing that?
Old 06-16-2012, 09:28 PM   #75
79 blue monster
welded up half of the stake rack holes, just need to sand down filler!
