Old 03-01-2013, 01:47 AM   #51
danw210
69 K20
Re: K20 Challenge
Originally Posted by Spicer View Post
I would say yes that will work if you replace the needle bearing on the 72 spindle with the Teflon bushing, because it has the built in flange as the bronze bushing from the 69 does, if you use the 69 shaft and on 72 spindle there's some differences in the flange/washer set up, the Teflon bushing they make for the 72 spindle is made with the same set up as the 69, just different size, and when you have the shaft turned down it will fit.
Also if you do end up turning down the 69 shafts you might try to find a third stub shaft to have a spare since they would be special pieces at that point, have them all turned down at once... But I would'nt worry about having the shafts turned down, Still Plenty strong!
I guess the bronze bushing did not fit in the 72 spindle?
The guy said that turning the axles down would be an easier option so I'm taking them in tomorrow. Thanks for the info on the teflon bushings and everything else on this subject. Great stuff!
danw210 is offline   Reply With Quote
Old 03-10-2013, 12:54 AM   #52
danw210
69 K20
Re: K20 Challenge
OK - front brakes on the closed knuckle are done! I had the outer axle shafts cut down to fit the 72 spindles and everything fits great. I hope to get the diffs and the leaf springs mounted by next weekend.
Old 03-16-2013, 07:56 PM   #53
danw210
69 K20
Re: K20 Challenge
I made some progress this weekend, got all the leaf springs on and the rear diff under the truck. Also started polishing up my old wheels that I'm probably going to use and painted up my brake booster/master cylinder for the disc/disc set-up.
Old 03-16-2013, 08:02 PM   #54
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: K20 Challenge
Brake cyl setup looks awesome, is it just painted or are there plated parts on there?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-16-2013, 08:17 PM   #55
danw210
69 K20
Re: K20 Challenge
Thanks! I painted the master and the brackets, clear coated the booster and prop. valve.
Old 03-24-2013, 11:04 PM   #56
danw210
69 K20
Re: K20 Challenge
I'm starting to do the engine now, dropped the block off at the machine shop to get some work done. I was just going to do a 350 punched .040 over but my block sat around for a long time and got rusty in the cylinders, we're going to have to go .020 more. So......... with me having to buy pistons and have the crank turned to clean up the rust on it, my guy is talking me into a 383 package. I've had one a while back in my Firebird so I do know the great torque they produce. I think I'm going for it.
Here's my Firebird that I ended up selling to my cousin -
Old 03-24-2013, 11:07 PM   #57
danw210
69 K20
Re: K20 Challenge
Cleaned up the manifolds with POR15 manifold paint. I'm not sure if I'm going to use them or headers.
Old 03-24-2013, 11:12 PM   #58
Dustydog
Dustydog's Avatar
Re: K20 Challenge
Go Big Block!! Order one of those nice GM crate packages!
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Dustydog is offline   Reply With Quote
Old 03-24-2013, 11:23 PM   #59
danw210
69 K20
Re: K20 Challenge
If only I had your money Dave.
I'm already waaaaaaaaaay over my budget on this truck and we've got a long way to go.
Old 03-24-2013, 11:27 PM   #60
Dustydog
Dustydog's Avatar
Re: K20 Challenge
Ha Ha!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I am too broke to even know it!
By the way, quick calculation shows you have about 3,840 hours until 9/1 so hurry up!
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Old 04-06-2013, 08:58 PM   #61
danw210
69 K20
Re: K20 Challenge
Well I decided to go 350 not 383, parts on order and block getting bored. The front diff is under the truck and it's starting to look more like a truck instead of just a bunch of parts.
Old 04-07-2013, 11:25 AM   #62
mjensen
mjensen's Avatar
Re: K20 Challenge
Looks like you're making some good progress! It's looking real nice!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 08-28-2013, 08:08 AM   #63
danw210
69 K20
Re: K20 Challenge
K20 Challenge update - I am going to miss my target, obviously. A lot has happened in the last 4 months, unfortunately nothing to do with the truck. I have relocated with my job and have moved to Kentucky, this has derailed the project and it has been put on hold. My budget for the truck had taken a huge hit with the expense moving and establishing a new household but I will continue to work on it when I can. Here is a recent picture of how far it's come. Name:  image.jpg
Old 08-28-2013, 09:01 AM   #64
Dustydog
Dustydog's Avatar
Re: K20 Challenge
Sad to see it leave the area but happy for you at the same time.
It will be a beautiful truck when it is done and I know it will get done!
I enjoyed the little time that I got to spend working on it with you.
Dave
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Old 08-30-2013, 09:54 AM   #65
danw210
69 K20
Re: K20 Challenge
Thanks Dave! It WILL get done for sure. I brought it to the new house in Kentucky last night. I just need to get the garage set and get back to work on the truck.Name:  image.jpg
Old 08-30-2013, 01:46 PM   #66
Vintage Windmills
Vintage 4x4s
Re: K20 Challenge
Keep up the good work, gotta feel good to have the drivetrain done!
Old 08-30-2013, 05:42 PM   #67
danw210
69 K20
Re: K20 Challenge
Yes it is nice having the drivetrain in. Now if it all works is another thing, lol.
Old 01-17-2014, 05:01 PM   #68
Dustydog
Dustydog's Avatar
Re: K20 Challenge
Hey Dan!
Anything new on the truck?
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Old 01-17-2014, 09:07 PM   #69
danw210
69 K20
Re: K20 Challenge
Hey Dan!
Hey Dave!
I haven't laid hands on the truck since I rolled it into the garage. I need to get the garage in order, need to organize and get some better electrical. My garage has only 15 amp breakers, can't even run the compressor.
Old 02-07-2014, 01:47 PM   #70
b.sharp
b.sharp's Avatar
Re: K20 Challenge
Man, awsome looking rig you have. I have a couple questions for you if you don't mind. I have a 64 k20 and would like to do the disk brake conversion. I believe we have the same d44 closed knuckle front axle. Do you know if any d44 with disk brakes will work or do I need one from a '72 as you used? Also in this swap what did you change from the original closed knuckle system. I know hubs, drums, just looking for a parts/shopping list I suppose.
Thanks you for your assistance.
b.sharp is offline   Reply With Quote
Old 02-07-2014, 07:39 PM   #71
danw210
69 K20
Re: K20 Challenge
Thanks! I think the D44 closed knuckle diffs from 60-69 are pretty much the same so I think you could use the disc brake parts from 71- mid 80's k20's.
Here is the link to my brake swap -
http://67-72chevytrucks.com/vboard/s...d.php?t=567022
Old 02-07-2014, 07:59 PM   #72
Dustydog
Dustydog's Avatar
Re: K20 Challenge
It is an awesome truck and I cant wait to see it done! Might even have to make a trip down to "Tucky" to get a ride & see it in person!
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Old 02-08-2014, 10:29 AM   #73
danw210
69 K20
Re: K20 Challenge
Sounds good Dave!
Old 02-10-2014, 10:05 AM   #74
b.sharp
b.sharp's Avatar
Re: K20 Challenge
So, if I read this right. You used '72 spindles, backing plates, disks and calpiers. All you had done was machined the '69 outer axles stubs to fit the '72 spindles. Is that correct? Do you have the '72 outer spindles for a measurement of the difference to be machined off? Thanks for the information. This will be a to do on my '64 closed knuckle axle.
Old 02-10-2014, 01:04 PM   #75
danw210
69 K20
Re: K20 Challenge
Yes. There is no machining to be done on the spindle, just the outer axle shaft. They need to be milled to 1.312 inches where they fit into the spindle. I would get a set of spindles first and mill the axle shafts to fit them. I would expect them to be 1.312.
