Old 10-23-2003, 04:10 AM   #51
jay-dawg
chevelito
jay-dawg's Avatar
woohoo 30mpg...man that's what i'm looking for. I get about 24mpg in my 99 4cyl s10. i get more neck snapping per gallon too.
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 10-23-2003, 08:19 AM   #52
minibike
minibike's Avatar
A buddy of mine has the LT1/4l60e in his 49 panel truck. The thing is heavy and not aerodynamic at all. He gets 18 mpg, but drives pretty fast (85-90 mph) on trips. This is with 373 gears and dual air conditioners blowing! I think that 18-20 is a reasonable guess for our trucks, if driving normally.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 10-27-2003, 12:20 AM   #53
jay-dawg
chevelito
jay-dawg's Avatar
bueller, bueller, ? Ok I'm thinking it's yes to my question
do I have to drill another hole to mount the bottom of the mounts to the crossmember? I want to use the 6cyl mounting holes.
jay
Old 11-15-2003, 10:14 AM   #54
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Tank solutions....
gimme a call on any needed tank solutions. I can build an 18 gallon aluminum cell with sending unit, pump, straps and necessary hardware for $480. Drop me a line. I am fixing to to the same swap to my truck. I bought a 50,000 95 Z28 LT1,4L60E for $1500. I can't wait to get started. Later, FuelCellGuy
FuelCellGuy is offline   Reply With Quote
Old 02-09-2004, 12:04 PM   #55
jay-dawg
chevelito
jay-dawg's Avatar
Hi guys,
I finally got to a point where I can mount the engine onto the frame. I got disappointed when my L6 250 engine mounts didn't fit in the configuration of the holes on the '95 LT1 block. Do I need to use the 350 mounts, or do I drill new holes onto the inline 6 mounts. I tried to see if I have a pic of it, but I don't. I thought that the 3 bolt holes would line up.
Can I get some help please?
(I also posted in the engine drivetrain section, but I thought I would get better results with the people already on this thread.)
tia,
Jay
Old 02-09-2004, 12:59 PM   #56
FuelCellGuy
FUEL CELL GURU
Mounts
I believe you may be better off using a 69 Chevelle 350 mount. It should bolt right on. I used these mounts on mine and built new engine stands. The circle shows the stands. In this picture I have yet to weld the side brace that runs from the top the frame to the pipe the bolt slides through. Hope it helps. Later, FCG
Old 02-09-2004, 01:32 PM   #57
lock
Insert funny comment.
lock's Avatar
I have a question about the AC. Im transplanting a 96 LT1 from an Impala into my truck. I currently do not have air and Im looking at the aftermarket kits like Old Air's. Do I use the compressor that came with the LT1 or do I use one that would come with the kit?
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 02-09-2004, 01:39 PM   #58
FuelCellGuy
FUEL CELL GURU
I am using..
the stock compressor. You will have to clearance the frame in order to do this.
Old 02-09-2004, 05:01 PM   #59
lock
lock's Avatar
Re: I am using..
What did you use for the rest of it like the condensor? Factory parts or aftermarket like Old Air?
- Mark
-My Build Thread...
-70 Camaro
Old 02-09-2004, 05:24 PM   #60
FuelCellGuy
FUEL CELL GURU
I used...
a stock condenser and a Vintage Air Gen II. It worked great. I say it worked, it worked when the big block was in there, I am sure it will work just fine with the LT1. Various fitting are available at your local parts store. Shoudn't be to difficult to setup. Later, FCG
Old 02-09-2004, 06:07 PM   #61
mcmlxix
Collector of Projects
mcmlxix's Avatar
I thought the 6cyl engine stands and the stock SB motor mounts were supposed to bolt right up to a SBC or a newer LT-1... I wasn't sure which 6cyl stands though... inline or v6 .. there were a couple sizes too (265/295?)... I'm still confused on that ... I was looking to get a set of mounts from one of the members but I dont know if they'll work ....
Rich
1972 K5 Blazer CST Click HERE
Old 02-09-2004, 08:11 PM   #62
lock
lock's Avatar
Thanks Mark. Makes sense to me. Just wanted to check. Ill be contacting you about a gas tank this summer as this project rolls on.
- Mark
-My Build Thread...
-70 Camaro
Old 02-09-2004, 09:17 PM   #63
jay-dawg
chevelito
jay-dawg's Avatar
Mark, do you know if the Chevelle mounts will bolt to the stock V8 engine towers?
oh...and same here with the gas tank Mark. Thanks for the info.
Jay
Old 02-09-2004, 09:25 PM   #64
jay-dawg
chevelito
jay-dawg's Avatar
Found my answer on the my other thread.
Originally posted by Don2
You probably need the 350 mounts. I already had the 350 mounts and my LT1 dropped right in.
Back to the parts board.
Jay
Old 02-10-2004, 01:18 AM   #65
mcmlxix
mcmlxix's Avatar
The purpose for using the 6cyl stands is to move the engine back in the frame for a couple reasons... beter weight distribution and when Ihave a one piece driveshaft, it will be just that much shorter .... I have a v8 now ...
I'll be in line for a fuel cell as well this summer....
Rich
Old 02-11-2004, 05:32 AM   #66
jay-dawg
chevelito
jay-dawg's Avatar
It's in....3 hours to wiggle it in.
Old 02-11-2004, 12:05 PM   #67
mcmlxix
mcmlxix's Avatar
CONGRATS ... What mounts did you end up using? In what location, two front holes or two rear holes? How is the clearance with the frame and the accessories? can you take some pics of the clearances and post them.....
Rich
Old 02-11-2004, 12:30 PM   #68
jay-dawg
chevelito
jay-dawg's Avatar
Lots of clearance. I used the stock 250 rubber mounts and bolted them right up to the engine, except for the driver side where only 2 bolts were able to match. I used the stock 350 engine towers in the forward holes. I still have th 250 towers just in case. I removed the A/C so that it would fit. I plan to use vette accessory brackets. I'll try and get day pics today.
Jay
Old 02-11-2004, 01:37 PM   #69
mcmlxix
mcmlxix's Avatar
I have Caprice brackets and I was wondering if the Camaro brackets fit ... I dont want to cut the frame if I dont have to... I guess I'll be looking for Corvette brackets as well .. you will also need the Hub/Balancer for the vette too as its a different offset then the F-body brackets...
Pics would be great ... how much clearance for the oil pan? I think I still want to use the I6 towers so it will move the engine back the extra 3 +/- inches. I will have a one piece drive shaft and the shorter the better.
Are you using the 4L60e trans from the F-body as well? I bought a shifter from a 94 Camaro and I'm going to build a center console to put it in.
Rich
Old 02-11-2004, 07:07 PM   #70
jay-dawg
chevelito
jay-dawg's Avatar
If you saw fuell cell guy's pick, he used the stock camaro brackets, but had to weld the towers to the front crossmember. The LT1 fits just fine using the V8 or L6 towers to mount. Lots of clearance for oil pan. I'll take some pics of that too. I don't think you'll need a new balancer, but don't quote me on it. I'm using the 4L60e from the same donor car. Hopefully I can get it cleaned up and bolted on as well.
Old 02-11-2004, 07:18 PM   #71
FuelCellGuy
FUEL CELL GURU
I used....
Early Chevelle motor mounts, the ones with the integrated torque stop. I didn't have any small block or L6 stands so, I made my own. At the same time, I raised my engine for maximum ground clearance. Hehehe, NOW I can drop the pan if I have to without removing the engine.
Old 02-11-2004, 08:29 PM   #72
minibike
minibike's Avatar
The corvette serpentine and the camaro do use different balancers. You can see some other options at Street and Performance www.hotrodlane.cc
You may have a difficult time finding the corvette setup, and it may be pretty expensive. I'm cheap, so I cut the top of the frame rail. It is in front of the crossmember, and I guess I made a crumple zone!
69 SWB
LT1/4L60E
Old 02-11-2004, 10:01 PM   #73
FuelCellGuy
FUEL CELL GURU
AMEN....
minibike. A little cut here, a little cut there (with the plasma cutter of course). Just a dab of griding and polishing and no one will ever notice.
Old 02-14-2004, 12:11 AM   #74
lock
lock's Avatar
Well brought home my new heart for my truck (in background). 1996 Lt1 from an Impala with 24k miles. Cant wait to get it running but I have many months to go.
- Mark
-My Build Thread...
-70 Camaro
Old 02-14-2004, 01:36 PM   #75
jay-dawg
chevelito
jay-dawg's Avatar
Nice Score.
