Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-14-2013, 11:19 PM   #51
wyomech
wyomech's Avatar
Re: 63 Chevy SWB converting to 4x4
I shouldnt need cab corners ,but both front fenders need repaired
wyomech is offline   Reply With Quote
Old 06-22-2013, 07:20 PM   #52
wyomech
wyomech's Avatar
Well I finally got the brake lines in and the brakes bled.Then I put in the gas tank and cut down the fuel lines.I spent the last week getting the rear pinon angle set and the pads welded also had to move the right shock mount from the front to the rear of the axle.I used the original panhard bar and built brackets out of 2 inch by 1/4
Old 07-16-2013, 11:34 PM   #53
wyomech
wyomech's Avatar
I got the truck running and brakes working and got excited that I can move it ,so I drove it up the road and back a couple of blocks now I cant wait to get this thing on the road.Next I would like to get the cluster and dash wiring hooked up .Im not sure if anyone has tried this but I would like to hook up the cruise control as all the wiring and switches are already there but I need the optical sensor that went to the speedo on the 87,I think I can cut a hole the back of the 63 speedo and make it fit.
Old 07-18-2013, 12:58 AM   #54
wyomech
wyomech's Avatar
got the hole drilled in the speedo for the sensor and filed off the threads so i can use the cable from the 87
Old 08-19-2014, 06:25 PM   #55
RANDY COX
RANDY COX's Avatar
Any updates...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-28-2014, 01:31 PM   #56
wyomech
wyomech's Avatar
Hoping to have it on the road soon I will get some more pictures taken and try to post some photos and updates soon
Old 10-13-2015, 12:29 AM   #57
wyomech
wyomech's Avatar
It's been awhile since I have posted anything but the truck is now licensed and I've been driving it to work. I removed the original rusted bumper and I am going to use a 10 inch dropped one,it was chrome but a little rusty so I will spray with bed liner after making mounting brackets.
Old 10-13-2015, 12:38 AM   #58
wyomech
wyomech's Avatar
so I have a new smart phone and it turned the image sideways,guess I will have to figure that out.
