Old 08-08-2012, 03:21 PM   #51
DURG
DURG's Avatar
Re: DURG's Black 65 C10
I got seven tracking numbers emailed to me from Porterbuilt today. Estimated arrival next Tuesday. Then........It's on!
DURG is offline   Reply With Quote
Old 08-13-2012, 04:51 PM   #52
DURG
DURG's Avatar
Did some of the high hump install today. I cut out the old one and have the holes drilled for the mounting bolts. I ordered some 5/16" threaded square nuts to weld on the underside so it will be like a stock install. Once those are in and the bolts tightened, I will spot weld the forward firewall mating section in. I am transferring the gas pedal stud mount over from the low hump as the high hump had 1/4" nuts for the pedal studs and my stock low hump pedal mount studs are 5/16" thread. Pictures below:
stock low hump:
Hole after removal:
High hump in place:
Porterbuilt stuff is scheduled to arrive sometime tommorrow.
Old 08-13-2012, 05:14 PM   #53
rmvlt1100
rmvlt1100's Avatar
stock low hump:
Hole after removal:
High hump in place:
DURGS,
Very clean truck you started your build with. It's looking good. Have fun with the rest of the build.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 08-13-2012, 09:36 PM   #54
KombiMonster
Very nice Impala! Are the front wheels smaller than the back with bigger tires?
Solid truck!
KombiMonster is offline   Reply With Quote
Old 08-13-2012, 10:00 PM   #55
DURG
DURG's Avatar
Yeah the Impala has 18" on front and 20" on rear. Truck will have 20" on front and 22" on rear. Same Coy's C-5 Gray wheels. (If they ever ship).
Old 08-15-2012, 06:46 AM   #56
DURG
DURG's Avatar
Tuesday was a big day. Most of the Porterbuilt parts showed up. Few small items coming next week.
Look at the amount of work just in the Dropmember itself:
Old 08-15-2012, 07:05 AM   #57
Leadfoot Lambert
Leadfoot Lambert's Avatar
That's awesome! Cant wait to see it all come together.
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 08-15-2012, 07:38 AM   #58
coulter
coulter's Avatar
xmas in august!!!! bet you were stoked to open all those boxes!!!
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 08-15-2012, 06:45 PM   #59
DURG
DURG's Avatar
Still waiting on my rear bushings and heim joints and hardware kits for the rear stuff. I took my boy fishing today so will probably actually start putting some stuff together Thursday. Quality looks really nice.
Old 08-15-2012, 06:59 PM   #60
KombiMonster
definitly makes me want a PorterBuilt C-10!
Old 08-16-2012, 09:55 PM   #61
DURG
DURG's Avatar
I got started on the Porterbuilt install last night and today. Bunch of pictures, It is the Touring coilover version with four link and the weld in rear notches. Looks like the bed will need to be raised about 5-1/2" as expected. Everyhting is just installed loose so far. I also put the rear end housing mounts on the tubes but the are just tacked together and still rotate on the tube. I also plan on doing the crossmember bracing so I got a tabless PB truck arm crossmember too.
Old 08-16-2012, 09:57 PM   #62
DURG
DURG's Avatar
Pictures cont:
Old 08-16-2012, 10:00 PM   #63
DURG
DURG's Avatar
Moving to the front stuff:
Old 08-17-2012, 12:28 AM   #64
64shortc10
64shortc10's Avatar
Very Nice! Moving right along! Keep it going.
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 08-19-2012, 09:24 PM   #65
DURG
DURG's Avatar
Thanks. I put the front coilovers in, checked out the panhard bar on the rearend, and set the rear coilovers in their mounts. I need to trim a gusset of the rear bridge mount to allow the coilovers to swing inboard slightly. I did a bunch of welding on the rear notches today and cut out the original frame section.
Old 08-19-2012, 09:57 PM   #66
northern 85
northern 85's Avatar
Going to be badass nice work!
northern 85 is offline   Reply With Quote
Old 08-19-2012, 10:17 PM   #67
LowDown
Great work ! subscribed
LowDown is offline   Reply With Quote
Old 08-19-2012, 10:53 PM   #68
DIRTY HAIR
Very very nice!
DIRTY HAIR is offline   Reply With Quote
Old 08-20-2012, 05:54 AM   #69
mark 66
first time ive seen coilovers with a porterbuilt set up.gotta love porterbuilt.very nice.should handle like a go cart.
mark 66 is offline   Reply With Quote
Old 08-25-2012, 06:29 PM   #70
DURG
DURG's Avatar
I did some more work today. Goal was to finish welding up notch lower caps and get rear end hung in place on the trailing arms. Nate is making me another bridge assy as mine apparently was not the right one for the coilover upper mounting. Here are some pictures:
Old 08-25-2012, 06:31 PM   #71
DURG
DURG's Avatar
Warning: OFF TOPIC!
Picture I took along with these ones to post on a Vette forum of my 2011 Grand Sport with black chrome wheels:
Old 08-25-2012, 06:36 PM   #72
DURG
DURG's Avatar
It's like Deja Vu all over again here is my Impala a few years ago:
Old 08-31-2012, 05:22 AM   #73
northern 85
Nice work,you are going to have one sweet lineup of of black rides!
Old 08-31-2012, 06:16 AM   #74
DURG
DURG's Avatar
Thanks. I am getting the new Porterbuilt bridge assy. and some misc. hardware I also needed from PB today via UPS if the tracking numbers are accurate. Should get some more time this weekend to work on the truck.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
Old 08-31-2012, 08:38 AM   #75
coulter
coulter's Avatar
badass looking setup!!! nice work
