#51 |
Re: Lets talk 1960-1961 cast iron mirror arms
Good example of a NOS 61passenger side short mirror arm.
As you can see in the pic there wasn't a lot of attention put into aligning the mirror arm shaft to the base. I have seen this on all the cast iron mirror arms I've come across. Some better than others...
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#52 |
Finally got around to painting the passenger side mirror arm. Its a 1961 model. Will use it until I can find a 1960 style passenger side version to match my driver side.
I used a sharpie to mark the casting numbers in case its useful to someone else.
#53 |
Found a 1961 passenger side 4" cast iron mirror arm on ebay if anyone needs one. The passenger sides are much harder to find.
I believe the 4" mirror arm would probably have been installed on the corvair greenbriar, but anyways figured I'd post it in case it'll help someone else out. Link: http://www.ebay.com/itm/321769036412...S:1123&vxp=mtr
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-01-2015 at 01:16 PM. |
#54 |
I have a passenger 60 cast iron mirrors with the same bend on it now I know it's a real 60 from what i have been reading
#55 |
I realize this is an old post, but is relevant to my question so thought I would post it here. I have what appears to be a 1961 LH (driver’s door) cast iron side view mirror - see attached pictures. I would appreciate if someone could confirm that or if this is instead a 1960 style?
Knowing which year this mirror arm is from will help me in my search to find the same style for the passenger side. Thank you. Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help. Last edited by razor62; 09-06-2022 at 06:59 PM. Reason: Edited out WTB |
