Old 08-05-2012, 11:17 AM   #51
mooseknuckles
mooseknuckles's Avatar
Re: 4l80e shifting ?
It's been this way for the last 3 months!....but I am a little worried.....checked all the tranny connections, could'nt find nothin...
mooseknuckles is offline   Reply With Quote
Old 08-05-2012, 08:26 PM   #52
clinebarger
Just because the transmission hasnt broke yet doesnt make it OK.
Do you own a Digital Volt/Ohm Meter?
clinebarger is offline   Reply With Quote
Old 08-05-2012, 08:27 PM   #53
mooseknuckles
yep...?
Old 08-05-2012, 09:10 PM   #54
clinebarger
Did you "Ohm" the two ISS wires, Did you "Ohm" the ISS sesor?
Old 08-05-2012, 09:21 PM   #55
mooseknuckles
no...it was too hot...what kinda reading should I be lookin for?
Old 08-05-2012, 09:35 PM   #56
clinebarger
In Post #40 gave you the ohm reading for the sensor, I also provided PCM pin locations/wire colors for the ISS sensor. The ohm reading when checking continuity will be close to zero is the wire is good & in the correct location.
Old 08-05-2012, 09:47 PM   #57
mooseknuckles
everything "looks" good...it's a brand new psi harness, all the pins are pushed in, connectors are tight...I should of switched the iss and oss connectors around and checked the codes.....
Old 08-06-2012, 02:31 AM   #58
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I think what cline's getting at is that he's given ya the info twice, and you still haven't gone out to the garage with the volt meter yet.
I'm breaking your balls, but it won't fix itself.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-06-2012, 08:51 AM   #59
mooseknuckles
...only prob is, my "garage" is 50km away....
Old 08-06-2012, 01:07 PM   #60
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
as an american, i assume that is a long distance? lol I'm kidding.
that kinda sucks tho....that would piss me off with the weather yall get up there.
Old 08-06-2012, 02:07 PM   #61
mooseknuckles
lol...yeah, finally got a break from the 100+ degree weather we've been having...
Old 08-06-2012, 11:54 PM   #62
clinebarger
100 degree weather???
Old 08-07-2012, 05:53 PM   #63
mooseknuckles
yep....my igloo is melting as we speak....
Old 08-16-2012, 10:06 PM   #64
mooseknuckles
pulled the wire off of the brake switch....now that codes gone.....?
Old 08-17-2012, 01:36 AM   #65
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
did you have the switch wired correctly?
Old 08-17-2012, 06:11 AM   #66
mooseknuckles
I wired it up the way as per cline's diagram.....brand new switch as well.....?
Old 08-20-2012, 05:40 PM   #67
mooseknuckles
I think the hard shifts are gone now as well.....wtf?
Old 08-20-2012, 07:23 PM   #68
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my 4L85e seemed to shift hard its 1st miles...now seems to have calmed down a bit?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-06-2013, 05:59 PM   #69
mooseknuckles
so I've fed with this problem for quite awhile, got very upset and forgot about it....it's still shifting very hard. after 20-30 mins of driving is when it starts, I can stop and shut it off, then its good again for a little bit...tried checking the resistance in the wires, not getting anything although Im not sure wtf Im doing either!.....still throwing this code...I know this is the problem, but no clue on what to do...I would appreciate any input.
Old 07-06-2013, 09:04 PM   #70
clinebarger
Swap positions with the speed sensors, If the ISS sensor is bad, It will now effect the OSS signal to the ECM instead of the ISS signal.
Swap sensors.....Drive till it acts up....If the sensor is in fact Bad, It will not want to up-shift at all.....Stuck in 1st gear.
Old 07-08-2013, 08:21 AM   #71
Hart_Rod
Hart_Rod's Avatar
Great insight and trouble shooting techniques Cline! Now I know who to come to if I have problems when I fire up my new setup .
Hart_Rod is offline   Reply With Quote
Old 07-08-2013, 04:00 PM   #72
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'll link this just because;
I can't stand this guys voice, but he is pretty good about "dummy" instructions on things like checking sensors and locating terminations. Its about the 717 on a saturn, but the concept of checking it is the same.
Old 07-10-2013, 06:38 PM   #73
mooseknuckles
thanks.....I bought a new ISS....I'll see what happens.
Old 07-16-2013, 04:03 PM   #74
mooseknuckles
well that didn't work....no reading on the wires either...
Old 07-21-2013, 12:02 PM   #75
mooseknuckles
....I spoke with jon at psi, he gave me the pins for the iss, says he checked the tune himself, some thing is wrong in the tranny...any idea of what it could be??
