#51 |
Re: 1965 SWB BBW Build
Thanks! Trying like hell to get it done in time for Power Tour in June! I have time but parts and suppliers are taking their time. Wheels thus far have been on order for 2+ months.
I ordered the driveshaft a few days ago but can't get the body on until the wheels arrive. I have the body at my parents farm where there is a John Deere with a hay fork to assist with the cab. Hoping things go rather quickly when I get my wheels! |
#52 |
Just found out wheels are on the way! Only took a few months, so I ordered tires as well.
255/40R17 Front 275/40R17 Rear |
#53 |
Wheels and tires arrived. I'll have to get them mounted Thursday once I get back from Detroit. I also put some LED headlights (same that would fit my 65) on my CJ7. They totally blow the halogen leadlights out of the water and am thinking of buying them for my 65.
#54 |
Those are some slick rims
#55 |
I'm just glad to be here!
Looks good. What is the lastest on this truck? Still planning on Power Tour?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#56 |
![]() Join Date: May 2009
"7" love those Vintique wheels that will be a classic look...Vernski
#57 |
I like the headlights!
I could not help but notice on the back of the box though, that it lists "Military Grade Die Cast Aluminum"..........soooooooo..... that must mean it was made by the lowest bidder, and will take a ton of tax payer money to keep up?? Too bad more civilians dont realize the amount of junk the Military ends up buying. Sorry if that sounds sour, but in my head it is really funny !! ![]()
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#58 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Nice looking wheels
![]() The last time I looked those headlights were $200........each ![]() I hope they aren't obnoxiously bright for oncoming drivers ![]()
#59 |
Pro touring.... I'm trying. Just left the army in feb and took a job in Michigan. Left my truck at a buddy's in Texas and finished putting a new motor and trans in it. Didn't want to get stuck on the side of the road along the way.
As for the lights, ya they were pricy but they are much brighter than stock but not too bright for oncoming drivers. I hate those rice burners with HIDs that make you squint as they head toward you. I have to go back to Texas to pick up my project so I can finish or at least get the body on it. I really miss working on it! |
#60 |
Yeah, I ride the high beams for them in response.
#61 |
great thread. Hope to see some progress soon!
#62 |
Well HRPT started, Did you make it?
#63 |
Long story and no. I installed a new motor in my 66 for the HRPT and after 30 miles it threw a push rod.... Not happy but the machine shop that sold me the motor was great. Had a rocker arm stud come loose and push out letting havoc take its place.
I had to step away for awhile and focus on other things. Left the Army and went to work for a large company. Just now getting back to everything and seeing where I left off on the 65. |
#64 |
Long story.... threw a rod after 30 miles on the way to Dallas from Killeen. Not happy as a rocker arm stud came out of the head causing havoc. Figures this would happen as I didn't take the time to put a few hundred miles on the motor before parking.
The machine shop was great though and fixed everything for free. Helps when your family knows the owner really well. Will see about this years maybe. I had to step away for a while and focus on work. Spent some time this weekend with the 65 and body. Will post some pics but need some help on the fuel rail piece. |
#65 |
Cab going on today. Didn't think the 4L80e would fit well and its close. Will have to tie in the trans crossmember and see what room is left in the trans tunnel.
#66 |
Sorry to hear about the motor, at least they took care of it.
#67 |
More pics after getting the body set on the frame. I have to buy the bed mounts and radiator support as I can't find the ones I had bought before I moved. Started on the wiring harness and its not too bad to install since everything is labeled. Will try to finish that in two weeks along with some other stuff.
#68 |
The old grill that came with the truck had some other things fall on it and put a dent. I go most of it out but should work just fine. Have to order some convoluted tubing to finish the wiring harness with and secure it to the frame. This will be the next big project that I have in a few weeks.
#69 |
Post Whore
![]() Join Date: Mar 2013
Just ran across yer build! Looks killer man!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#70 |
Here are the vintage Texas plates that I found for the truck. I have my 66 registered with another set and its easy to do here.
#71 |
very cool build man,wiring will be on my list what pcm and computer harness did you buy thanks jon
#72 | |
If you haven't bought a chassis harness yet then check out American Auto Wire as they'll build a harness that has all the extra stuff you need for an LS motor to connect into. Just let them know what you need or plan to run and be as detailed as possible. My harness is going in pretty easy as everything is labeled (every wire) and is so easy to read. |
#73 |
I used a speartech harness on a ls swap myself.was a little pricey but very good quality. where did you mount the computer?
#74 |
Haven't mounted mine yet. I think it'll be in the engine compartment where everything is easy to get to. Should cross that bridge at the end of next month.
#75 |
BUMP.....For build updates...Nice wheels and truck. What size are the wheels (backspace)
