Old 12-27-2012, 05:08 PM   #51
frmula505
frmula505's Avatar
Re: 1969 C10 build "La Trokita Project"
Trimmed the bed to fit over suspension. Here is how it will sit.
Now I have to brace and block things up a bit. Also need to get some tubs for it.
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
Old 12-27-2012, 05:39 PM   #52
ChevyFreak60
ChevyFreak60's Avatar
Dam bro you made a lot of progess from the other day I was there.....Looks good!!
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 12-28-2012, 07:40 PM   #53
frmula505
frmula505's Avatar
Ordered the wheel tubs from Jeg's, they should be here soon. Meanwhile I boxed the cross beams, and made the edging around the cuts.
Then I will spray some bed liner, and the inside of bed will be done. Not gonna get to much into body work on the inside of bed. The liner covers a lot. I had good luck with Al's liner. It's what I have on my 60, and it's paintable.
Going to start with some of the plumbing next. Brakes lines, fuel lines, and air system.
2006 Cadillac XLR-V
Old 12-28-2012, 07:50 PM   #54
67cheby
67cheby
67cheby's Avatar
nice work , finishing the edges !
67cheby is offline   Reply With Quote
Old 01-05-2013, 06:46 PM   #55
frmula505
frmula505's Avatar
Got a chance between snow storms and cold weather to get the tubs installed. All that I have to do is radius the area where the axle sits. And rivit the tabs I left on the inside of tub. That will straighten them out a little. Then hammer the corners more smoothly.
I'll look around for some metal I can use for the axle radius holes. Should be ready for the liner soon.
2006 Cadillac XLR-V
