Old 11-23-2012, 01:33 AM   #51
Mr. 250r
Mr. 250r's Avatar
Re: My "New" 1991 2500 Burb
The inner pads are for newer trucks rear spring bump stops they shouldn't need to be removed or at least i didn't have to remove them and as far as the lug nuts i wouldn't say they're 'special' lug nuts since they are just newer truck lug nuts but some people find it a problem and i might eventually change them
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 07-24-2013, 01:02 AM   #52
Patch
Patch's Avatar
Waking up my project! Been dozing for a while on this.....updates soon!
Patch
Patch is offline   Reply With Quote
Old 07-24-2013, 09:46 PM   #53
Patch
Patch's Avatar
I know it doesnt look like much...but it took a few damn hours with the cut-off wheel and grinder...but I got all 4 of the perches off the new rear axle!! I have the new perch kit...now I just need to go get some angle thingys......lol and get it set up...Sweet!
Patch
Old 08-07-2013, 06:23 PM   #54
y5mgisi
Second Chance Program
y5mgisi's Avatar
Sweet truck! I have been wanting to pick up a late model 14 bolt like that for a while!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 08-12-2013, 09:26 PM   #55
Patch
Patch's Avatar
Thanks! So.....for those of you that have done this before.....let me see if I have this straight.....
1. single u joint at each end of my drive line..so more than ...7-10 degrees of angle?
2. pinion angle parallel to output shaft of t case or slight nose up?
3. Do any tack welding of new perches with vehicle weight on the springs and axle
4. frame of vehicle at 0 degrees while doing all of this
5. going to tack weld...then remove and take to buddy's house who is a professional welder to burn in the new perches and gussets.
Missing anything????? Thanks in advance....Patch!
Patch
