#51 |
Re: 4.5/6 Drop, Tire size rollin on 20's
My truck with 255/40/18 and 295/35/20 with Nittos.
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350 1966 Caprice 1968 Impala (Frame Off LSX Project) 2001 Tahoe LT 2013 Hyundai Elantra 2010 Kawasaki Z1000 |
#52 |
what does your rear wheel opening measure in height from the ground to the center of the arch 29 1/2"-30"?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#53 |
![]() Join Date: Jun 2011
[QUOTE=HotRod C/10;5921396]what does your rear wheel opening measure in height from the ground to the center of the arch 29 1/2"-30"?[/QUO i will ck for you will be sunday
#54 |
RAT1968 '68 Cab/'71 Parts
4.5/5 Drop w 2.5 spindles and 2" springs in front....5" spring drop in rear.
Wheels are 20 x 8.5 and 20 x 10 Boss' (don't know the BS...they were the only ones they made at the time). 1.5" spacer in the back and 1" spacer in the front. Tires are 245/40 in front and 275/45's in the rear. I would have liked more back spacing and a little more tire on the rear. But I'm running with these now.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#55 |
#56 |
you running a fleet side so you can do the 295/40 and 255/40. With my stepper I had to stop at 275/40 for rear. Its the widest the rear wells would take and still drop over the tire.
#57 |
#58 |
#59 |
your rear axle width will play a role on Backspacing as well....there were two different widths
#60 |
I have a 68 1/2 ton gmc with a stock 6 lug rear end. I'm looking to get centerline smoothie wheels. The only 20" wheels they carry are a 20x8.5 with a 5.4 rear back spacing. What do you guys think? Will these work for the front and rear? I would like wider in the rear but rather stay with a 20" and not a 22"
Posted via Mobile Device |
#61 | |
What size tire can you fit on the back?????? 295/40/20...? |
#62 | |
EDIT....never mind, saw another post where you said the bags were aired up in this picture.
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 06-17-2013 at 07:40 PM. |
#63 |
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
#64 |
Im hearing 245/45 & 295/40/20 because they are both almost the same size. something like 29" and 28.9". correct me if I'm wrong. I'm looking for a set of rims and tires also
#65 |
It all depends on personal preference, but I recommend the Nitto 420s, which have a 245/45/20 and 285/40/20. They come in at about 28.6 front and 28.9 in the rear.
The 295/40/20 you mentioned will work as well, as the height is basically the same. Each tire model will have different sizes. |
#66 |
I'm running a 4.5/7 with 255/40/20 and 295/40/20. I wish I would have went a lil shorter all the way around, but these will work for now.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
#67 |
![]() Join Date: Aug 2008
I am considering a set of used 20" MB Bruzer wheels with Goodyear Eagle GT II tires. P275/45/R20 tires. I prefer some torq thrusts coys or similar but i can fet these cheap! I am waiting to hear back on rim width an backspacing. Any input?
#68 |
I forgot to add they would be going on a 72 swb stepside with a 3/4 static drop
#69 |
Great looking truck RaceAGMC.
WIDESIDE72, a 20x8.5 w/ 5.25" BS, and a 20x10 w/ 5.5" BS would work well, but all depends on width of the wheel. Of course, anything close in this that area of backspace should work fine for you on a 3/4 drop. |
