03-19-2015, 08:02 PM | #51 |
Re: Granny smith, 71 2wd build
Rear is all done
03-19-2015, 08:03 PM | #52 |
Lays down nice.
06-15-2015, 11:20 PM | #53 |
very nice
06-25-2015, 10:15 AM | #54 |
Do you know of any more near you
06-25-2015, 02:25 PM | #55 |
With a gas tank on you'd be scraping it on the ground. Any plans to tuck the gas tank any deeper under the truck? Looks good by the way.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
06-30-2015, 09:53 AM | #56 |
This is ride height, stock tank has about 4" of clearance.
06-30-2015, 09:56 AM | #57 |
Thanks for the kind words! It's coming along slowly. No work/life balance gets in the way.
06-30-2015, 12:09 PM | #58 |
Just looks like it I guess
06-30-2015, 02:38 PM | #59 |
That looks Great! Man, I need to bag mine...
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
06-30-2015, 04:48 PM | #60 |
It has a perfect Stance. Looked much lower from the frame pic. Low but not so low you grind the frame on speed bumps. But then drop to ground to park. Cool.
06-30-2015, 08:31 PM | #61 |
Thanks, yes it will go down another 2-3". I need to put some smaller tires in the front. These pics are with 40psi in the front and 20 in the rear.
06-30-2015, 11:43 PM | #62 |
Truck is looking awesome! I have been seriously considering bagging my 72,2wd. And you are just helping make the decision easier.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
07-01-2015, 08:26 AM | #63 |
07-01-2015, 01:21 PM | #64 |
What's your plans for compressor and tank do you have drop spindles also on the front
07-02-2015, 07:22 AM | #65 |
I was thinking about the airlift autopilot, but have not decided yet. It has mcgaughy 2" spindles.
07-08-2015, 02:45 PM | #66 |
2wd FTW!!!!
That thing looks cool as hell just like that!
07-08-2015, 07:13 PM | #67 |
Thanks man
07-09-2015, 04:35 PM | #68 |
Nice work, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
07-19-2015, 02:17 PM | #69 |
Have you made anymore progress also how does your rig ride on air
07-20-2015, 09:18 PM | #70 |
No recent progress, just been cruising it and ordering parts. Even at the much lower ride height the bags ride better than the old springs. There is a sweet spot though. If I ride around with it too low, it develops a vibration. I'm guessing shaft angle.
07-21-2015, 02:26 PM | #71 |
def got it looking *****in
07-21-2015, 02:27 PM | #72 |
looking cool
07-21-2015, 03:21 PM | #73 |
Driveshaft angles are probably just as fun dropped as it Is on a lifted truck. Just watch the slipshaft isn't bottoming out. That can kill the tait shaft on the trans.
07-21-2015, 03:33 PM | #74 |
Nice build
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-19-2015, 04:27 PM | #75 |
how is granny progressing
