11-04-2013, 09:43 AM | #51 |
Re: What's your Winter Goal?
Install lt1 v8 (replace tbi 350)
install 4l6oe (replace 700r4) move rear axle back 1-2 inches notch rear frame install vintage air after engine swap |
11-04-2013, 07:50 PM | #52 |
Get some weight secured in the bed and do donuts with my new snow tires on. Also, front discs and lowering it a few inches. Maybe a nice exhaust too if I get to it.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel |
11-04-2013, 08:17 PM | #53 |
Put an engine and trans in it
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
11-04-2013, 11:09 PM | #54 |
get the new motor with the fuel injection in and running along with the new wiring harness, and hopefully get the inside of the cab finished up so its ready for paint first thing in the spring.
If you ain't living life on the Edge.... Your taking up entirely to much space!!!! My 64 Stepper Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586792 |
11-04-2013, 11:20 PM | #55 |
I wouldnt mind driving my truck sometime yet this year...
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
11-05-2013, 11:15 AM | #56 |
1962 C-10
I plan on pulling out my 327, resealing it... get rid of a leak...clean it up and go back to Chevy orange with it (currently yellow).
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
11-05-2013, 11:35 AM | #57 |
Get my trailer project completed so I can start using it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-05-2013, 11:47 AM | #58 |
Probably more than 1 mouthful to bite off, but we'll see. After pulling the 350/350turbo and installing a low mile 307 crate motor and a 700r, it's been a daily driver for 2 1/2 yrs while I accumulated parts and pieces. Sooooo:
pull front clip, motor and tranny clean and POR frame, patch inner fenders (456chevy) and Raptor line them and firewall. Install 82 c10 steering column and power steering gear box and power brake booster (Captainfab adapters). Staying drum/drum for now. Remove bed, clean frame and POR it. Install 3" drop springs. Shorten driveshaft. Blast and prep/primer bed while off. Back of cab as well. Detail 10000 mile 383 stroker and tranny ($600.00 for it as well as the 80 El Camino it was in. Had BW T10 with Hurst shifter. After selling/scrapping unwanted stuff, final cost of motor - $175.00) Reskin doors. Patch or replace fenders. Seems like a lot now that I wrote it down but target date is end of May. |
11-05-2013, 12:43 PM | #59 |
My goal is to be driving the truck by next summer, this will require the following work during winter and spring:
1) Finishing cab sheet metal work (Parts are ready) 2) Painting and sealing new cab floor 3) Completing front end disc/drop/power steering work (Parts are ready) 4) Assembling my engine (Some parts are ready; waiting on tax return) 5) Installing tank in rear 6) Runing new brake/fuel lines I'll then worry about patching my tailgate and fenders while driving it!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
11-06-2013, 08:12 PM | #60 |
To actually work on my truck once again....also try to stop my son from driving it once the snow hits the roads....
11-06-2013, 08:58 PM | #61 |
To crush my enemies, to see them driven before me, and to hear the lamentations of their women.
...but before that I want to get the Econoline 16" wheels I just got converted for 3/4 ton hubcaps, tires, get the heater working, and get an HEI for the V6. Some new wood for the bed would be nice also... |
11-06-2013, 11:47 PM | #62 |
Get the heater working! Tis the season to have heat.
Change the oil (eeeeasy.) Replace Passenger's door, get the big mirrors (drill holes for matching mirror on driver's side) repair, sand, bondo, primer and paint passenger's fender. also get some shims to position it correctly (this is about the same time as the door project) Cherrybomb it (or an actual muffler? thoughts?) Get a radio and stereo system for Christmas! Last thing is to meet someone who has a '65 or '66. It'd be fun to talk to someone who actually knows what they're doing.
White 1966 C10 LWB Fleetside 1983 Mercruiser Marine 305 V8/Chevelle 4spd "Ellen of Truck" |
12-08-2013, 02:57 AM | #63 | |
12-08-2013, 06:40 AM | #64 |
Finishing the dash wiring! and then mounting the bed
http://s1299.photobucket.com/user/jb...23904108567829 |
12-08-2013, 02:39 PM | #65 |
Finish up the sanding and lay on the paint by years end!
I want this on the road by the end of march.
65 burb On the road Mar 26th Finally |
12-08-2013, 03:13 PM | #66 |
I have to redo steering column, need to shorten the shaft still need to install 1 more floor support, work out the E-brake cables and stuff. Too much to do. Can't do too much as my truck is outside in open weather...
1964 BBC 402 4x4 |
12-09-2013, 09:26 AM | #67 |
Rebuild 292
Freshen up 4 speed with new gaskets and seals Clean up 4 speed steering column and get it ready to install Purchase heavy duty clutch assembly New U-joints and bearing support for drive shaft Paint steel wheels and have them mounted Convert from low hump to high hump Buy all necessary seals for inner fenders and hood, grommets for firewall, stickers for engine, etc for when I install engine and transmission. Install my overload springs Find a factory sway bar I have a decent laundry list for this winter (and into the spring)! I already got the 292 torn down and it looks excellent. Just saving the cash for the rebuild kit. Luckily, the truck runs and drives perfectly right now with the 283 and 3 speed, so no down time!
1965 C10 LWB SBW, 292, SM420 1963 Chevy II SS 1951 Chevy Business Coupe Gasser 1949 Willys Overland |
12-09-2013, 09:30 AM | #68 |
Install my CPP rear c-notch, get the bed back on and keep driving it!
12-09-2013, 09:44 AM | #69 |
Get the Big Back Window installed
Put a 50 chevy sedan gas tank under the bed and remove the in cab tank Install a new gauge cluster with working gauges not warning lights lower the stance fix a few small oil drips then drive it like I stole it when spring gets here.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
12-09-2013, 12:22 PM | #70 |
planning on making truck a c 10 picked up complete crossmember and rear ,now that other truck has blown engine (1991 w/t)need to get c20 road worthy a.s.a.p,maybe swap rear so i can have better m.p.g,but will have 8 lug front and 6 lug rear, oh well need to get to work.
12-09-2013, 12:39 PM | #71 |
Start getting it torn down to bare frame. Order..wait..wait..wait..Install Porterbuilt dropmembers front & rear. Get cab blasted and hopefully start on patch panels.
12-09-2013, 12:59 PM | #72 |
i dropped off a set of doors at chaotic customs in conroe, tx, along with patch panels. having the door handle and mirror holes shaved as well. install those at the begining of january, finish up the wiring for power windows and door poppers, and install those. already re-wired the entire truck, just little finishing touches here and there.
12-09-2013, 01:26 PM | #73 |
12-09-2013, 03:37 PM | #74 |
get my 64 Running A/C in and inside painted install LS
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
12-09-2013, 03:46 PM | #75 |
KEEP ON TRUCKIN'
I know what you mean. My work has been slow to non-existent. If my work pics up like my business partner says it will, I will get back to getting my frame stripped and powder coated and have the chassis rolling and ready for the body come spring time
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
