Old 12-29-2012, 12:06 AM   #51
Square_78
Square_78's Avatar
Re: Issues with CPP tubular upper control arm
You will probably be fine with those shorter springs. You dont really run into Camber problems on these trucks until you take more than 4" out of the stock spring height.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 12-30-2012, 02:22 PM   #52
mahanian
C10 addict
mahanian's Avatar
Originally Posted by Hart_Rod View Post
Now you got me worried, . The only reason I installed the CPP arms were to be able to get a good alignment without a bunch of shims. I've got 2.5-3" drop springs so hopefully it will work out.....
You will be good, I pulled down on the front end about a 1/2" while it was on the alignment rack and I was able to get negative camber so 2" drop or more should suffice.
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 12-31-2012, 12:37 PM   #53
Hart_Rod
Hart_Rod's Avatar
Cool and thanks! I'll get it re -aligned in the next week or so and let you know how it goes.
Hart_Rod is offline   Reply With Quote
