#51 |
Re: 1971 custom 20 w/ camper
No crank yet, which is odd because everything else seems to be here. Maybe I can use a crank off the other winch and try that. And thanks again for the key Leon, it works great. I tried your trick of removing the door locks to get a key code but nothing on either one. Just took one to the local locksmith and he cut me a key, works in the ignition too. Had her running briefly but wont stay running, time to pull the carb.
Posted via Mobile Device |
#52 | |
The Older Generation
Be sure and check the filter where the fuel line goes into the carb. Take the fuel line off, then loosen the large nut. Be sure and note which way the filter is inserted, it will only work one way. You can get them at any auto parts store. When you put it back together be sure you don't get the large nut cross threaded. The threads are really fine and it is easy to do. LockDoc
