Old 11-12-2012, 09:27 AM   #51
tjmeadows
Re: 3 speed overdrive questions
Mid rpm range, start,idle and wide open are running great. So a.little more adjustments are necessary but its coming around. As for the od it must be stuck in overdrive because it coasts very bad while driving and letting off on the gas. The overdrive cable is froze up, not sure if its in or out but I'm going to disengage it at the tail shaft and see what happens... if carb issues continue i am debating going aluminum intake and 4 barrel, just curious how much this takes away from being a strictly original truck??
tjmeadows is offline   Reply With Quote
Old 11-12-2012, 08:26 PM   #52
tjmeadows
Got her running better today, but with choke nonfunctional right it takes a while to warm up, gotta get that figured out next..
