#51 |
Re: Mdo 69
I'd say that is a good deal. Newer motors sound like a deal when people pull them from the scrap yard, but parts for them add up much faster than a Gen 1 or 2 small block! Good deal! Now hurry up and put them on so I can see how you run the exhaust!!!
![]() Posted via Mobile Device |
#52 |
![]() Join Date: May 2011
Re: Mdo 69
Your right about the co$t adding up Lefty, as far as the exhaust goes I'm not sure yet. Thanks for wishing me a Merry Christmas, same to you and yours.
I hope to fire it up this week. Posted via Mobile Device |
#53 |
Re: Mdo 69
I got the tank intalled but not completed, I still need to modify the filler neck. The wiring harness is complete, atleast enough to fire up the motor.
I need to hook up the fuel lines and ground the motor. I put the Trailblazer SS manifold on the engine and had enough room between them and the frame that I was able to move the engine forward and use the old drive shaft. BIG PLUS. |
#54 |
Re: Mdo 69
I received my Trailblazer SS exhaust manifolds from gmpartsdirect.com $135 shipped they fit great had no issues with shipping or quality.
I bolted them up and I am very pleased with the way they fit, I might have to grind a little on the passengers side frame rail. |
#55 |
Re: Mdo 69
When I bought this truck it had an 89 tbi 350/700r4
I'm using the 89 model radiator, I looked at the upper and lower radiator hoses for a 2005 tahoe, since thats what my 5.3 came out of. I believe I can use those hoses with my radiator. Using the TBSS manifolds and the dirty dingo adjustable mounts, with late 70's early 80's motor mounts, I was able to use my new drive shaft that was actually made to work with the 350/700r4. |
#56 |
Re: Mdo 69
I got my motor started today!
#57 |
Re: Mdo 69
I might need a new cab, I'm running out of time and I need to finish this truck by June. If anyone knows about a good cab near NC let me know, mean while I'll keep working on mine.
#58 |
Re: Mdo 69
I got a line on a nice cab over here in TN. I am about an hour and 15 minutes from you. It doesn't belong to me, but I know the guy that has it. It has no title though. PM me for more info if you decide to go that way.
Bake “The Gunny” USMC 1990-2011-Retired 69 C10 Suburban 350/350 69 C10 SWB - project 66 Galaxie 500 - 460/5 speed 99 F550 Crewcab Western Hauler bed |
#59 |
Re: Mdo 69
I know of a man near Knoxville who says he has a lot of these trucks, is this the man your talking about.
Tell me about this cab. Posted via Mobile Device |
#60 |
Re: Mdo 69
Sent you a PM
#61 |
Re: Mdo 69
And no it's not Dean in Knoxville
#62 |
Re: Mdo 69
well decided to work on my cab, had to do alot of welding since the cab had been hit on the passenger side, and had tons of rust.
#63 |
Re: Mdo 69
door
#64 |
Re: Mdo 69
And on
#65 |
Re: Mdo 69
5.3L
#66 |
Re: Mdo 69
Filler neck
#67 |
Re: Mdo 69
The cab is now ready for some grinding, primer, body filler and lots of sanding.
#68 |
Re: Mdo 69
tank painted and installed using silver colored POR15 paint
#69 |
Re: Mdo 69
I lowered the rear 5" with CPP lowering springs, I used 4 degree shims and deluxe trac bar.
I used CPP rear shock relocator, I tried to used the factory ride height front shocks, they would not extend enought no even bolt on, I tried my stock rear shocks and they worked. I'm still working on the front suspension, I don't know what I'm going to do about the front shocks yet. Posted via Mobile Device |
#70 |
Re: Mdo 69
Rear shocks installed
#71 |
Re: Mdo 69
Rear
#72 |
Re: Mdo 69
I'm going to try copper brake lines, got them at advance auto $86
#73 |
Re: Mdo 69
Driver door
Posted via Mobile Device Posted via Mobile Device |
#74 |
Re: Mdo 69
Door ready
#75 |
Re: Mdo 69
POR15 one coat, may give it another
