Old 06-29-2017, 09:01 PM   #51
Afirehawk1
Re: Post your pics of 60-66 BIG BLOCK only trucks / engines
Originally Posted by 60-66 View Post
Some guys like cutting or beating in the firewall to use stock mounts , lots of pros and cons on this. In 1968 they started putting BB in these trucks and designed a frame mount to move the engine forward just enough. This is a picture of my 63 with 454 and 68-70 BB mounts, no firewall modifications and TH400. Everything bolted in. This is the exact setup ,( and engine) as the GMC I did above.
What exhaust manifolds did you use with the 396?
I have the exact setup now and I to figure that one out.
Did you have to notch the frame?
Afirehawk1 is offline   Reply With Quote
Old 06-30-2017, 08:12 AM   #52
60-66
60-66's Avatar
Yes I cut the top lip of the frame back, I measured and cut it back just like a 1968-1972 truck is, so the frame mount would sit properly . The exhaust manifolds ( I used Sanderson Headers ) are the same as 1968-1970 Impala and 1968-1972 Truck. I think the same manifolds were used into the later 70s also.These mounts I used are dished to clear the manifolds.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 06-30-2017, 02:50 PM   #53
contagious102
contagious102's Avatar
540 ci making around 800hp
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 06-30-2017, 08:58 PM   #54
Magic Bus
Has anyone used the 1973 and up cross member and the same year big block mounts?
I have a 74 3/4 ton and was going to use all the parts for my 65 C30. Or is it best to update the stock C30 and use the 68-70 mounts
Magic Bus is offline   Reply With Quote
Old 07-01-2017, 01:08 AM   #55
Captainfab
60-66 Nut
You can use the '73+ C20 engine mount brackets as they fit the early frames better than the engine mount brackets from a C10. IMO the clamshell mounts are one of the better engine mount designs.
Old 04-06-2018, 01:48 PM   #56
Afirehawk1
got the engine and Sanderson exhaust manifolds on.
any suggestion on a DIY exhaust system?
thanks in advance
Old 04-06-2018, 02:51 PM   #57
The Rocknrod
Moderator
The Rocknrod's Avatar
Those pictures are too small, can you make them bigger so we can see them.
Old 04-06-2018, 03:50 PM   #58
Afirehawk1
that photo is from 60-66's engine. i was hoping he may know a good exhaust.
i went with the same engine and manifold setup.
Old 04-06-2018, 11:12 PM   #59
Pinball Chris
Here's my 64, 454, 4L80E and 9" ford Rear
Pinball Chris is offline   Reply With Quote
Old 01-24-2019, 04:11 PM   #60
COCONUTS
COCONUTS's Avatar
Really nice looking trucks in this thread and a lot of good bb advice.
Subscribed
COCONUTS is offline   Reply With Quote
Old 01-25-2019, 04:34 AM   #61
mfm3
Someday, i'll pull the motor, restify the engine compartment and rebuild or replace the 454. For now, it runs well with an Edelbrock EFI installed 20 years ago that came with the truck when I bought it 7 years ago.
mfm3 is offline   Reply With Quote
Old 09-05-2019, 10:11 PM   #62
shsahs
shsahs's Avatar
Just got it sitting in there tonight. What a difference. Looks like these trucks should have came this way. A lot of small stuff to go but looks like headers are a good tight fit and the valve covers clear with no notching at all on firewall. Fan on long water pump is as close as you can get but the good news is no spacer necessary.
Going from this
to this.
shsahs is offline   Reply With Quote
Old 09-06-2019, 10:43 AM   #63
The Rocknrod
Moderator
Looks great. Wish I was ballsy enough to put a big block in mine. I had a 502 in 56 big window back in the day. Total heat pump, but I did work out the details and cruised it quite a lot.
