Old 01-24-2013, 04:42 PM   #51
widewhite70
widewhite70's Avatar
Re: The BCC No Limit build
Looking good!
-Calvin
http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2
How I keep the truck shining, Detail thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=697902
widewhite70 is offline   Reply With Quote
Old 01-28-2013, 09:25 PM   #52
aggie91
I'm just glad to be here!
aggie91's Avatar
I like this one. Looked like a nice truck to start with!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-31-2013, 10:16 PM   #53
fatgump
fatgump's Avatar
Originally Posted by robnolimit View Post
I modified these headers. We tried a few others that we had here, none were really right. We put the coil-overs in it to check the RH and spring rates on scales. Then the RideTech Shockwaves went in.
Did you take any photos at ride height? If so, can you post them? I would like to see for a comparison.
Thanks,
Gump
fatgump is offline   Reply With Quote
Old 02-04-2013, 12:38 PM   #54
robnolimit
robnolimit's Avatar
The back of this truck was treated to one of our new rear rail kits. For suspension, we chose our FatBar 4-bar with a bag/shock. We have done six or seven rear rail kits in the shop now, but this will be the first with a FatBar, so we did some prototyping here. As the new rails fit over the stock rails, it is a very tight fit. We sanded the stock rails nice and smoot, that helps. The 'top-front' bolt lines up. The rails are set level, and the remaining holes are drilled.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-04-2013, 12:43 PM   #55
robnolimit
robnolimit's Avatar
We have learned that they easy way to assemble this is to set the crossmembers in place, and then loosely bolt them to one rail (drivers). Then, start to align and bolt them to the other rail. Two large drift pins and a ratchet strap will help. DO NOT drill the holes out to fit. They fit, just work the parts into place.
Old 02-04-2013, 12:45 PM   #56
Rusbuilt
Rusbuilt's Avatar
Wow looking good!
Rusbuilt is offline   Reply With Quote
Old 02-04-2013, 12:48 PM   #57
robnolimit
robnolimit's Avatar
The FatBar install is straight forward. The front bar mounts use two holes from the rail install, then use the mount as a guide to drill the rest. With the axle in place, the rear bar mounts are set. The axle should be at Ride Hieght, centered, level, with the pinion angle set. A tie strap pulling the axle forward into the bars and mounts will help to stabalize the housing.
Old 02-04-2013, 01:00 PM   #58
67cheby
67cheby
67cheby's Avatar
Nice work !
67cheby is offline   Reply With Quote
Old 02-04-2013, 11:39 PM   #59
robnolimit
robnolimit's Avatar
Originally Posted by 67cheby View Post
Nice work !
Thanks. I gotta say, seeing your truck at SEMA was a treat. There are just too many cars to look at, and some I'm not realy interested in, but it's nice to see projects that show the commitment and planning like yours does. As the builder I'm sure you have a mental list of the things that should be, or could be different to make it perfect, but don't let them get to you too much. I know that a LOT of people saw it the way I did, as a bad ass piece of american iron.
Old 02-05-2013, 04:46 PM   #60
aggie91
aggie91's Avatar
Very nice, I like how you continuously develop new parts!
Very Cool!
Karl
The LST Challenge:
Old 02-07-2013, 01:03 PM   #61
robnolimit
robnolimit's Avatar
In the rear of the truck we are using a bag & shock set up. This has a bit more travel than a shockwave, so it may be a little more versitile for this truck. Our FatBar 4-bar kits have an indexed bag mounts that fit around the 4-bar mounts. These should be level at ride hieght. With everything installed, the rear suspension is complete. Note that the link bars, bags and shocks are outboard of the frame. This provides a wider suspension base, and makes the truck more stable. Our new rails are set at 34" outside to outside, slightly narrower than stock, so even with the suspension outboard, there is room for up to a 12" wide rim and 335 tire (wheel tub mods required.)
Old 02-07-2013, 01:14 PM   #62
robnolimit
robnolimit's Avatar
With the rails raised 4", we have more room for the fuel tank. Here is a look inside the tank for this truck. We will have these tanks available to fit the rear rail kits. The bottom of the tank is appx 1/2" higher than the bottom of the bed side, no clearance issues, this tank holds 20 gal. The center fuel trap is for an EFI pump, if added.
Raising the rear rail 4" forces you to raise the bed floor to go with it. This project has a wood floor, so it is a bit different than the steel floor trucks. We decided to 'float' the wood floor back in, hiding the side rails. So instaed of raising the side rails 4" (to go back over the top of the wood) we made risers that are 3 1/8" (this will now fit under the wood. The side risers are .090 alum. For the front and back, the riser is a standard 4". We used 2" x 4" x .065" tubing, cut to length and drilled to match. The large holes are for hardware access. This step took a little time, but it's not really difficult.
Old 02-07-2013, 05:02 PM   #63
higXtech
higXtech's Avatar
This is great. There is a lot of interest in raising the bed floor. It's the best of both worlds. getting the stance people want but still have a functional (and flat) bed floor. I bet you will sell a bunch of these kits.
1968 fleetside - nolimit wide ride front and rear + ridetech
higXtech is offline   Reply With Quote
Old 02-07-2013, 08:56 PM   #64
jlaird
jlaird's Avatar
Is that a sway bar end link I see in this picture? Have any better pics of the setup?
jlaird is offline   Reply With Quote
Old 02-07-2013, 09:19 PM   #65
67cheby
67cheby
67cheby's Avatar
Thanks man I really love Hell Boy also ! You killed it !
Old 02-08-2013, 10:16 AM   #66
aggie91
aggie91's Avatar
I thought the same thing, but as I looked at it again, I believe it is the upper shock mount since you can see the lower mount just below the bag mount.
Karl
The LST Challenge:
Old 02-08-2013, 10:42 AM   #67
knomadd
knomadd's Avatar
I wish my project started out that nice. I love the progress and can't wait to see the end result!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-08-2013, 11:09 AM   #68
Rusbuilt
Rusbuilt's Avatar
I love the tank! Nice work sir!
Old 02-08-2013, 05:31 PM   #69
LEEVON
Moderator
LEEVON's Avatar
This truck is going to look sweet on the ground without the grandpa wheels! I can't wait to see it finished.
That bulkhead fitting is simple and effective, like it.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-08-2013, 06:30 PM   #70
jlaird
jlaird's Avatar
Oh yeah, you're right
Old 02-09-2013, 08:32 PM   #71
higXtech
higXtech's Avatar
Old 02-09-2013, 08:33 PM   #72
Rusbuilt
Rusbuilt's Avatar
Nice wheels!
Old 02-10-2013, 12:09 AM   #73
knomadd
knomadd's Avatar
I was skeptical of the gold line tires when I read about it, but they look awesome on those wheels!
-Duane
Old 02-12-2013, 04:15 PM   #74
robnolimit
robnolimit's Avatar
Yes, we have the wheels and tires!!!! and yes, they are BAD A$$. Here are a couple more shots of the rear suspension. Yes, the shocks are outboard, in front of the axle. The only trick here is getting a shock with a sleaved 5/8" eyelet to work in place. This mount shares the same bolt as the lower 4-bar, so it has to have a metal sleave to tighten up to. Fitting the exhaust was pretty easy, just be carefull to check the travel as you build.
Old 02-12-2013, 04:21 PM   #75
robnolimit
robnolimit's Avatar
Fitting in the exhast is easy, until you get to the axle. On the passenger side, where the panhard bar imoves with the axle, the exhasu passes through the gap between the axle and bar. Going over the bar is do-able, as long as the fuel tank is in the stock location, but with the new tank there isn't enough room. For the hieght at the top, check the axle with the suspension fully compressed. For the exit behind the axle, check the fit with the suspension at full droop.
