06-05-2013, 03:12 PM | #51 |
Re: 1966 chevy truck engine swap to LS1
A/C is charged and now working great! Thanks to Old Air Products.
more pictures of my truck. http://67-72chevytrucks.com/vboard/s...d.php?t=467956 Last edited by 1966chevy; 01-03-2017 at 05:36 PM. |
07-18-2013, 09:02 AM | #52 |
VERY nice work! I feel silly asking a question about your clock when there is so much other good stuff going on here, but I have my dash cluster apart right now and that thing intrigues me. How does the time get set on the clock? Both initially and if it should ever get out of whack? Also, how did you go from having what appears to be the time set knob in the middle of the hands to a smooth appearance? Just grind it off with a Dremel or something?
07-18-2013, 09:26 AM | #53 |
64-66 CHEVY JUNKIE
That Ls1 Looks Really Good in that Bay!!!! Sweet!!!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
07-18-2013, 10:45 AM | #54 |
Very nice build.
08-23-2013, 02:05 PM | #55 |
Awesome swap I dont know how I missed it. I just got a 66 and am in San Jose as well. What area are you in?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
08-23-2013, 02:26 PM | #56 |
quality work all around!!
08-24-2013, 12:38 PM | #57 |
08-24-2013, 12:51 PM | #58 |
Here are some pictures of the jig I built to create the Fresh air vent covers behind the speaker kickers. This seals the outside vent off from debris coming into the cab. I used a gasket between the metal and plastic. On the kicker, I moved the speaker holes up to the vent opening and closed up the old speaker holes at the bottom. You can see a very little bit left of the circle which I didn't use enough filler in the picture on the drivers side.
See the pictures above for the Cowl Vent closed of as well. |
08-24-2013, 12:52 PM | #59 |
08-24-2013, 01:20 PM | #60 |
Cool. I'm near campbell. When I get mine going again we will have to meet up
08-24-2013, 01:50 PM | #61 |
Nice job on all the details! It looks very tidy considering how much of it is customized.
08-24-2013, 09:35 PM | #62 |
08-24-2013, 09:48 PM | #63 | |
Posted via Mobile Device |
08-25-2013, 09:23 AM | #64 |
Oh, wow, I can't believe I didn't see that! Almost makes me look like an idiot, but not the first time for that, haha. Thanks for the information.
08-26-2013, 06:02 PM | #65 |
I really like the clock it looks great, in post 24 you said the clock came from a 73 volvo and then in post 63 you said it came from a 80's model, I really want to find one of these do you know for sure which one it came out of, and also what is the tach out of.
Thanks for any info you could pass along. |
08-26-2013, 07:18 PM | #66 |
Who Me?
What seats did you use?
BTW, The build looks great!!
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
09-11-2013, 10:00 PM | #67 | |
09-11-2013, 10:07 PM | #68 |
2001 Dodge 1500, 2500 Truck. I believe they are still using them in the same truck today. Just have to spend more for the newer ones. My are none powered but it would have been cool to use a set that were powered and heated. I had to modify the frame mounts a bit (shorten the legs & weld on new mounts) for a level install.
09-11-2013, 10:23 PM | #69 | |
09-12-2013, 10:55 PM | #70 |
Thanks for the info on the clock, what did the clock come out of.
Thanks |
09-12-2013, 10:56 PM | #71 |
Sorry about that last post, I meant what did the tach come out of.
Thanks again. |
09-13-2013, 10:56 AM | #72 | |
09-14-2013, 09:33 PM | #73 |
Thanks for that information.
10-14-2013, 11:36 AM | #74 |
Here is my custom door panels to cover the work I did to get the one piece glass installed. I built them out of Plastic PVC purchased at Tap Plastics. Glued together with PVC glue purchased at OSH, sanded with a belt sander and hand sanded. I added side to flare the edges like a new vehicle today. I also foamed the inside of the panel to build up the backing and sound. This pushed the panel out to make the door panel flat, due to the door having a slight bow. The Handle cranks lineup and work great. NoteL: The window crake is power using the stock handle, to give it that factory looks. Here are the pictures.
10-14-2013, 12:19 PM | #75 |
Here are some pictures.
