#51 | |
Re: Anybody running lower then 12s QM?
If I'm seeing 200r4s going 8s in regales and still driven street dutie week in week out its good enough for me lol Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#52 |
12.5 on my 68 c10. All motor. Next year will be 11's on spray
Posted via Mobile Device |
#53 |
It seems that 12s in our trucks is using motors that usually have passenger cars doing 11s.
Weight and aerodynamics play into our factors here A fiberglass hood and a tonneu cover can help a lot as well as just getting rid of meat all around. Our front "girder beam" suspension is built to destroy anything it hits but is also a good 250lbs! Our bumpers and hoods are silly heavy and the tailgate is 80lbs itself. No consider we are shaped like a brick hous or the side if a barn. The odds are against us. Our engines have to be bigger and stronger. A chipped newer silverado will give us all a run for our money these days. Posted via Mobile Device
#54 |
The squarebodys are heavy, but not as bad as I would have thought. My 85 longbed weighs 4020 without the spare tire and about 5 gallons of gas in it. Iron head smallblock with a/c, and all the other accessories.
85 Scottsdale LWB 383 227/235 105 lsa Howards Roller TH350 by Jakes Performance, Sanger TX |
#55 |
Always a work in progress
200r4 are not the same as 700r4s. I have seen too many 700r4 issues to even consider running one(personal experience). The amount of money it takes to get a 60e up to the task of handling big power is better spent on a 80e in my opinion.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#56 | |
Are those factory colors for these trucks? I really like 'em. |
#57 | ||
I really like the 6.0 liters. They can connect to a TH350 with no problems, and it has the GM corperate 4.00 inch bore (I know it gets annoying about the 4.00 bore engines) but if i turbo charged the iron brute and throw 500 ft lbs and 500 hp stock block then i say me and ole quick silver acomplished something easy ![]()
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play ![]() |
#58 |
I like the way you are thinking. Yes they bolt up to a th350 just fine, I have done it in my truck.
My advice is to look for a 2004 or newer iron block because they came with a little bit better rod. If you are going to replace the internals then it doesn't matter what year.
#59 | |
#60 | |
#61 |
At the body shop.
A 6.0 is 366" a 383 would be less $ and fabrication
" That didnt make it any newer " " Dont antique the equipment " |
#62 |
i just found me a LQ4 all together for $450, another for $650 at the same salvage yard near by out of a Silverado 2500 series, not bad
#63 |
dang. then our rigs from short bed to long shouldnt have that big of difference
#64 |
A LS swap is on par as far as $$$ with a 383 build.
#65 |
At the body shop.
The engine yeah.
But i was thinking accesory drive, ignition and related bits and pieces Posted via Mobile Device
#66 |
6.0 powered square
mines a baby cam lq9 with full bolts and tune 373s makes 370 to the wheels and runs roughly 12.7s with a very tight stall on drag radials, I will be running a 4000 stall cal tracs, slick and 150 shot should bring down well into the 11s
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#67 |
Should do one mid at a Tim for us so we can see what starts making the biggest difference. Other than tho nos fogger...
#68 | |
#69 | |
#70 | |
#71 |
6.0 powered square
i could see 500hp with cam and heads, a 2500stall would be way to small
#72 |
A 3000 with lockup would be just right lol
#73 | |
#74 |
I went 11.82 in the truck in my avatar. Its a 496 with a set of mild ported 781's with, stock valves. It has 10.3 comp with a solid flat tappet cam and a gasket matched 70's torkerII and a 950hp. It also has Hooker super comps and 3" side exit exhaust with 40 series flowmasters. I'm running a TH375 with an ATI manual valvebody and a Jeg's 10" 3400 stall converter. On that pass I was running a 10 bolt with 3.73's and a rebuilt stock posi. I'm getting a 9" together with 4.11's a detriot locker for 35 spline axles. I have 275/60/15 BFG drag radials on it. With the 9", I'm going to put 325/50/15 M/T drag radials. I've also got Camaro coils in the front and, I cut out 4 of the 6 plies on the leaf springs. I also made up my own caltracs too as well as, Comp Engineering drag shocks at all four corners. I don't understand why some of the guys in this thread are saying that, faster than 12's in these trucks is crazy. My truck was very stable on all of the passes I made that day.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
#75 |
6.0 powered square
ls motors like loose stalls
