Old 01-18-2013, 05:11 PM   #51
67cheby
67cheby
67cheby's Avatar
Re: 71 C10 ground up restoration "my first build EVER"
nice
67cheby is offline   Reply With Quote
Old 01-18-2013, 07:53 PM   #52
Steve-W
Steve-W's Avatar
Thant painless wiring harness looks good, let us know how you got on with installing it. I'm going with EZ which I haven't gotten yet (shipping to the Netherlands takes a while) and I hope it looks like your painless set
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 01-19-2013, 11:04 PM   #53
Chev71
Chev71's Avatar
The painless kit is easy as pie man, all wiring diagram and coded wires. I wired up just the engine to start up the motor but my starter is bad so need a new one. Just want to start this up and remove everything going to go with a serpentine belt system with all new pulleys n brackets. And painting the block.
And need to have time to mock up all the sweet PB stuff, going snowboarding tomorrow so ima have to make time during the week
Chev71 is offline   Reply With Quote
Old 01-28-2013, 06:43 PM   #54
Chev71
Chev71's Avatar
Today I went to my boys shop and he was bout to primer/seal my doors and rear bed humps. All the little crevices nice n CLEAN!!!
Old 02-05-2013, 12:54 PM   #55
Chev71
Chev71's Avatar
So my buddy sent me pics yesterday of the paint on the cab and the X-Liner under the cab, he sprayed it with a candy orange but that orange isn't my cup of tea so that's coming off lol, but the X-Liner looks great!!
Not sure on the color yet? I want a two tone with original moldings for sure....
Also got the bed humps and doors all sealed up, just waiting on my 1 piece window set up from brothers
Old 02-05-2013, 12:56 PM   #56
67cheby
67cheby
67cheby's Avatar
everything looks great, nice job stripping the doors did he chemical dip them or just strip by hand ??
Old 02-05-2013, 04:28 PM   #57
Chev71
Chev71's Avatar
Wink Re: 71 C10 ground up restoration "my first build EVER"
Everything was stripped by hand. My guess allot of time was put into the doors lol
Old 02-13-2013, 05:04 PM   #58
Chev71
Chev71's Avatar
Just got off working a 12hr shift and seen this on my driveway =)
I wonder what it is lol
I opened the box but when I opened it I was a little bit upset I was expecting a hello kitty blanket haha Jk Jk
Thanks Mike Losh
Got me my Slosh Tubz
Old 03-04-2013, 04:53 PM   #59
Chev71
Chev71's Avatar
So haven't really done any progress to my chasis/frame haven't had time to go all out on it yet but I had purchased a serpentine belt system from a local swap meet and I put that on.
I also just bolted up all the front drop member cause I was bored haha but man ohh man can't wait to actually have it on, just don't know exactly how ima do it lol.
Also went to my friends shop he had welded the two gaps that the cab had up top where the door seals when looks way nicer
Old 04-26-2013, 05:32 PM   #60
Chev71
Chev71's Avatar
So I'm trying to put the Porterbuilt Stage 2 Rear, the frame was a leaf spring frame and I removed the leaf springs and lowered the frame on the rear differential, once I put the trailing arms, the U-Bolt holes and C-Notch doesn't add up. Idk if I need to move the diff back more, does any1 have specs of how it all goes I don't want the rear end to be top far back or too forward??
Thanks.
Old 04-26-2013, 06:01 PM   #61
Xeen
Xeen's Avatar
Bolt the axle to the trailing arms then let the frame sit on the axle and see if it lines up then.
Edit: Can you take a picture of where the trailing arms bolt to the crossmember? I need to see something.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 04-26-2013, 06:24 PM   #62
Chev71
Chev71's Avatar
One thing, my diff doesn't have the U-Bolt bracket because it was leaf spring ima have to go borrow one.
I'm not home at the moment but here's the only pic I have, I bolted the trailing arms to the second from the bottom hole.
Old 04-26-2013, 09:46 PM   #63
Hardesty454
Hardesty454's Avatar
Nice build! Whos doing your work for you? Youre not too far away from me.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 04-27-2013, 01:16 AM   #64
Xeen
Xeen's Avatar
Since it is a custom crossmember it is likely that it's mounting location is going to be slightly different than the stock one it just needs moved.
I would recommend moving the trailing arms to the top mounting position before you move the crossmember.
Yeah it might be a good idea to buy some U-Bolts
You need to bolt everything together so you can see it, one thing I can tell you is it never lines up in your head like it does for real.
If you don't have a custom Trac-bar you need to buy one from porterbuilt since your axle doesn't have the stock mounting location.
Old 04-27-2013, 05:55 AM   #65
Chev71
Chev71's Avatar
Thanks. I'm doing it all myself lol, learning as I go
Xeen it's all Porterbuilt Stage 2 rear on the website it says the second from bottom hole. I followed the installation instructions. The kit came with the U-Bolts but my rear differential doesn't have the holes on it for U-Bolt since its leaf springs. Ima give Nate at Porterbuilt Monday see if he can help me out their really good when it comes to assistance. Also my kit comes with the trac bar I just haven't installed it yet.
Old 04-27-2013, 12:44 PM   #66
Xeen
Xeen's Avatar
My advice is not wrong you need to be able to bolt everything together before you can say things don't fit, untill you can bolt the trailing arms to the axle and instal the trac-bar you won't know anything.
Also the trailing arm attachment point is a guideline not a rule, the angle your trailing arms end up when the truck is laid out is impacted by the starting position of the trailing arms.
You will probably have to move your crossmember to get the trailing arms to be in the right position when the truck is laid out.
Old 04-27-2013, 04:15 PM   #67
Chev71
Chev71's Avatar
Gotcha xeen thanks allot man I appreciate your advice )
Ill keep you guys posted on my build
