#51 |
![]() Join Date: Aug 2007
Re: Chevelle Gas Tank Swap
I am curious as to what straps you have holding the tank on? I got 2 straps with mine and they aren't going to work....
#52 |
![]() Join Date: May 2011
I bought some flat stock steel at the hardware store; they are 2"x36" I paid $7 a piece, and I also bought two 1" angle iron $5 a piece
And I used the ones that came with the tank |
#53 |
finished the tank install, I painted the gas tank with POR15 silver color paint
#54 |
filler neck
#55 |
So about how far is the tank from the bumper?
#56 |
I assume that those who go this route that you will not be using a hitch? I love this idea of filling behind the license place but on the off chance I end up getting a hitch I may be hindered.
'72 GMC Super Custom 1500 350 V8 w/AC |
#57 |
Does anyone know how he connected the flat stock to the frame? I see 2 bolts holding each piece of flat stock to the frame, but I can't tell if he welded them to the flat stock, or used a bolt through the flat stock. I feel like a bolt through the flat stock would cause an indention or possibly puncture the top of the tank.
#58 | |
![]() Join Date: Dec 2010
#59 |
Thanks. As I mentioned in my post, I can see that he used flat stock and that he used bolts to connect the flat stock to the truck frame. What is unclear from the pictures is if the bolt head is under the flat stock or if it is welded to to the top of the flat stock.
#60 |
![]() Join Date: Jun 2014
Any pictures of how low the tank hangs down? Can't really tell from the pictures.
Do the Chevelle come with baffles? |
#61 |
Sorry I took some time off,
I used flat stock and drilled it, to keep the bolt from rubbing on the tank I used foam weather strip. I've got 7 3/4 inches of clearance under the tank, it does come baffled and I've put 3k miles on my truck without any problems. |
#62 |
I'll take a better picture later
#63 |
This is not a very good one
#64 | |
I am thinking of swapping my Camaro tank for the Chevelle tank to eliminate the 3" spacers and gain 3" of ground clearance for my bags. Will your tank actually hold the ~19 gallon capacity? My Camaro tank only seems to take around 14 gallons from empty possibly because of the built in rake of the Camaro floor pan that isn't there on the truck. |
#65 |
Can't remember the thickness of the flat stock, I'll check. And it's a 20 gallon tank, and it does hold 20 gallons.
#66 | |
#67 |
I used both pieces of angle iron, the other is a few inches behind back crossmember.
I thick it's a good setup for the money. I've had no problems with it. The only thing I would have done differently is to have painted the tank flat black. |
#68 |
I painted my Camaro tank black. The black hides it pretty well, the only reason I am considering the swap to a Chevelle tank is because I only have 3" of ground clearance when fully aired out on bags, without a notch. Once I add a small C-notch to the frame, the tank will sit on the ground. Moving to the Chevelle tank should net around 3" of ground clearance.
#69 |
Any word on the thickness? I checked some big box hardware stores and about the thinnest flat stock I could find was 1/8". Seemed a little heavy and difficult to bend.
#70 |
Thats what i Used 1/8 it bends pretty easy using a vise or just pliers
#71 |
How difficult is it to get to the 4 rear most bed bolts for installation and removal of the bed? Can it be done with the tank installed or do you have to drop the tank for bed removal/installation?
#72 |
#73 |
I can easily access all the bed bolts. Disconnecting the wire harness is a bit challenging.
#74 |
I have been reading about this conversion and this has been a very helpful post! Thanks!
My question is...Do you have to remove the bed to do this install? Would it be possible to do it with the bed on? I had no intentions on removing my bed, but I can if needed. Thanks for any help! ![]()
1971 C10 SWB 2WD Driver 350/TH400 2003 Silverado 2WD NBS EC-Daily Driver "Life is not easy for a boy named Sue."-Johnny Cash |
#75 |
IMO, the little amount of effort it takes to remove the bed, makes this project much easier.
