Old 01-14-2013, 02:19 PM   #51
hydrojunkie
hydrojunkie's Avatar
Re: project "call of duty" 72 c10
Sooooo I borrow my work truck and brought home 48 ft of 2x4 box. It's time to get busy.
Magic happens with a welder and a grinder.
My custom tubular c10 laying rockers.
http://67-72chevytrucks.com/vboard/s...78#post5970778
hydrojunkie is offline   Reply With Quote
Old 01-14-2013, 02:24 PM   #52
hydrojunkie
Old 01-14-2013, 10:28 PM   #53
hydrojunkie
Got a lot done in a few hours. I had to use my plasma cutter to miter my cuts and then grind them. What a pain in the ass. Basically I keep the oem geometry but lowered it 2 inches so all will lay right. Tommorow I am going to start the front. Now I'm happy. Lol
Old 01-14-2013, 10:30 PM   #54
hydrojunkie
Few more.
Old 01-14-2013, 10:31 PM   #55
hydrojunkie
Everything is dead on level.
Old 01-15-2013, 02:18 AM   #56
Zoomin
Man of Mini-Talents
Zoomin's Avatar
What happened to the curves on the steps?
Zoomin is offline   Reply With Quote
Old 01-15-2013, 06:51 AM   #57
hydrojunkie
I'm not sure what you mean bud, If you're talking about the C notch's there is no reason to have the curves in them anymore because I can put the bed mounts wherever I want
Old 01-15-2013, 04:44 PM   #58
TchncnDen
Seems like if you want a ton of followers you have to throw a bunch of money at a project, I like the DIY stuff better myself. I'm sure there are plenty of others that do more following than posting so just keep on updating for us. Can't believe you did all that work just to start over again! Keep on it.
TchncnDen is offline   Reply With Quote
Old 01-15-2013, 09:18 PM   #59
Rochlow
I've been following along.. Although, I do have a bunch of PB stuff.
Rochlow is offline   Reply With Quote
Old 01-15-2013, 09:25 PM   #60
hydrojunkie
I here you on the big money projects. I am just a normal joe and if I can do it anybody can do it. That's what I try to get out there.
I wasn't happy with the stock frame so I wanted to make a new one. My buddy and I spent 2 hours tonight figuring out the angles and measurements to create a new front end. All the miter cuts and angles. Lot of planning.
Old 01-15-2013, 09:27 PM   #61
hydrojunkie
There is nothing wrong with your stuff. It's a beautiful work of art there product. Your lucky.
Old 01-16-2013, 10:09 PM   #62
hydrojunkie
So a few days later. Hours of scetching this is what we came up with. I'm going to build a cross member. Went back to original frame height.
I'm going to widen the front up like the mid section so there is no clearance issues from the headers when I put them on. Also hopefully won't have to tunnel the cab out for the tranny. One thing at a time. Lol
Old 01-16-2013, 10:12 PM   #63
hydrojunkie
Not sure if I will use these but. Will try
Old 01-16-2013, 10:31 PM   #64
Rochlow
Nice work.
Old 01-16-2013, 10:44 PM   #65
LEX
LEX's Avatar
Dedication. You go, boy! Looking good.
LEX is offline   Reply With Quote
Old 01-16-2013, 10:45 PM   #66
sduckworth13
sduckworth13's Avatar
Nice build definitely, my girlfriends brother is a Asplundh Regional supervisor or something of that nature his name is Anthony Herrera figure you might know him.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-16-2013, 10:47 PM   #67
sduckworth13
let me know if you don't use the control arms I might pick them up from you if when you decided that your not going to use them and I have some cash set back.
Scott
Old 01-16-2013, 10:59 PM   #68
hydrojunkie
Thanks guys. It really means a lot to me. I know it looks like a piece of steel on the floor but to get that far was hard. Hopefully if my wife doesn't flip out on me I will get the other side done. Then it will start to look like a frame.
Old 01-19-2013, 04:47 PM   #69
hydrojunkie
I am so happy how the frame is coming out. I ran out of argon mix so all is tacked on the cross member. The engine will sit lower hopefully enough so I don't have to tunnel for my trans. I need to order new upper and lower a arms.
Old 01-19-2013, 04:51 PM   #70
hydrojunkie
One more
Old 01-19-2013, 06:10 PM   #71
sduckworth13
Looks pretty good, what control arms did you figure out is going to work for your track width?
Scott
Old 01-19-2013, 06:12 PM   #72
sduckworth13
If you have a green welding bottle instead of the maroon bottle you can take it to one of the farm supply stores and they will fill it for you,
Scott
Old 01-19-2013, 07:05 PM   #73
hydrojunkie
I have a feeling that I will end up using mustang 2 uppers and lowers. My buddy has a 80's corvette front end so tomm I'm going to pick it up and see what I can do with that.
I wish there was a farm place to have my tank filled around here. Only place to get it filled is a welding supply house. Or I can borrow my friends. Lol
Old 01-19-2013, 07:13 PM   #74
sduckworth13
Cool, your project is looking good.
Scott
Old 01-20-2013, 04:17 PM   #75
hydrojunkie
For some more work done. I raised the cross member up 2" and tack up some brackets. What do you think?
