#51 |
![]() Join Date: Oct 2012
Re: My 71 custom10 deluxe
Looks real good.
#52 |
![]() Join Date: Sep 2012
Thanks Jarrod
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
#53 |
Lovin' it Brian. Can't wait to see her done.
#54 |
wow thats nice
#55 |
Thanks Stuntman and Smoothride,Lowering it a few more inches from 3/5 to 5.5/7 made a huge difference in the look.
#56 |
Wow, that color really pops! I like it!
#57 |
Is that an MB7100/MB7200 MAC toolbox from the 80's sitting back there? Nice truck btw
project: "my happy mess" |
#58 |
You truck is looking very nice. Like the two tone paint
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project |
#59 |
Thanks Securityguy,Redbaron and Litew8 been working on it a lot lately.Litew8 yeah those are older Mac toolboxes from the 80's was given to me by one of the boats I do work for.
Installed the radiator this weekend it's an aluminum 3 core and radiator support from board member Joeelutz(Hotroddynamics). Installed two 12 inch Zirgo electric fans in shroud.
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 Last edited by brian1971; 10-26-2015 at 11:17 PM. |
#60 |
Been awhile since I posted to thread,I pulled out procharged efi sbc and started to install a 6.2 ls motor.Has BTR stage 4 LS3 cam kit along with 4l85e w/3600 stall from a 2007 HD3500 express van.Parts used for swap are StreetRays adapter plates w/gbody clamshells and 1985 3500 pickup frame stands.Exhaust is TruRam stainless manifolds.I will be running Holley Dominator efi and oil pan is from a 2004 CTS-V.
Also accessory drive will be Holley along with LS3 water pump.
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 Last edited by brian1971; 06-30-2017 at 10:43 PM. |
#61 |
More pics
#62 |
Installed 2006+up police crown vic aluminum driveshaft needed it shortened 1 1/4".These driveshafts take the big 1350 u-joints.Also started to install Wilwood master cylinder.Mounted up Holley accessory drive and installed Lokar shift linkage for the 4L80E.Got a lot done this week put in a few late nights on truck.
#63 |
More pictures and also installed 2006-11 Honda Civic 2dr door weatherstripping fits real nice didn't even need to trim gaskets.
#64 |
Good choice on the ls...you'll never build anything else...except maybe a monster BBC. They just sound too good.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#65 |
![]() Join Date: Nov 2013
Really nice and tidy power steering lines. Custom? Part numbers? I really like the frame rail straps, nice work!
#66 |
Thanks Boynton and uxdesigner.
The power steering lines are factory with a swedgelok adapter to hose and a 6an 90 on end.Then on Corvette power steering pump i just used a adapter to 6an fitting.The only thing with this setup is you have to use bigger power steering pulley that came on the 97-98 models not the open face one that came on later c5 and c6's or the 6an adapter on pump would hit pulley.
#67 |
Installed the Holley R4 compressor brackets over the weekend.Ended up using a 6pk970 belt.
#68 |
![]() Join Date: Feb 2011
Nice, Nice truck!! Like the direction you're going! Keeping an eye on this one!!
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#69 |
I like the swap you're doing. Keep posting pictures, we all love seeing pictures of what you're working on.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#70 |
Thanks Rustytruck50 bad Knomadd for the encouragement.I'll keep posting up pics been moving along pretty good lately.Been a long project but also have a 56 f100 I've been getting back on the road.
Brian
#71 |
Finished up running fuel lines and regulator for second time.I had already did this before for procgarged sbc.I also mounted transmission cooler underneath truck below passenger seat.Still don't know what im going to do for tranny lines yet.Oh I got brakes working again stops on its own first time in four years !!
#72 |
More transmission cooler pics
#73 |
Installed this battery box a few months ago.I mounted it on passenger frame rail in front of rear tire.It's a auxiliary box from early 2000's Ford E350 diesel.Had it powder coated black.Used a Odyssey battery.Was hard to get a real good pic with truck on ground.
#74 |
Went buy the local Aeroquip store yesterday picked up some hydraulic crimp 3/8 jic 6an fittings and Eaton Aeroquip matchmate hose.It's a little overkill but won't have to worry about them again.I will go back Monday and have them crimp the ends on.
#75 |
