#51 |
Re: 71/72 Bucket Seat Foam
#52 |
Price quote for a 70 bench top&bottom. Shipped to 94585. Your price seems good just curious on how much shipping is going to be :/
#53 |
Looking for foam on a bench seat that has bottom springs, I'm unsure if it was the original seat for my truck (a 1972) but going to use it. Quote for both top and bottom shipped to 73078.
Thank you kind sir.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel |
#54 |
#55 | |
Thanks for your patience. I have been on vacation. |
#56 | |
Tim, seems that the Blazer/Jimmy foam sold by LMC is actually the truck seat foam and they are unable to answer any install questions. Hopefully you have the answers so I can get this ordered from you. 1. Is the truck bench seat foam the same thickness as the Blazer/Jimmy rear seat? Or does it require adding or removing foam to make it the same thickness? 2. Will the truck bench seat foam only require the trimming of the sides to match the width of the Blazer/Jimmy bench seat? I don't know if you've ever done this before, but if you have and have any specific info it would be appreciated. If I can, I would like to get the foam from the same vendor so the foam is the same in consistency, firmness etc. But if I have to add foam to the truck seat or worse, remove foam, to get the correct thickness I'll go with a local re-upholstery guy.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
#57 |
GobbleStalker Calls
![]() Join Date: Aug 2010
I am interested in 72 bench foam. Price shipped to 13601 plz.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
#58 |
Guys I would buy the cheaper foam kit for the bench. The good stuff is WAY to firm and has me looking at the blue strip across the top of my window. I'm 6'1 and used to see fine. Now I need to have my seat redone because of the firmness. Just my two cents.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
#59 | |
Sorry for the delay. I missed this somehow. I have never removed the foam on a rear Blazer seat before to be able to compare for you or to be able to answer your question with confidence. All the rear benches I have had and do have all have nice foam on them. Maybe somebody can chime in on this one. Thanks |
#60 | |
#61 |
#62 |
![]() Join Date: Jul 2013
OK here is question for the bucket seat gurus. If I bought OEM buckets from a 70 blazer and put 69-70 truck foam and removed the backs will it work and then have OEM truck bucket seats. Are the frames the same dimensions. I know all about the difference of the mounting tracks. This a seat only question.
#63 |
Hey your local! I will need some down the road.
72 CST Blazer 4x4 (Revival in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=430968 |
#64 | |
#65 |
#66 |
![]() Join Date: Sep 2000
I need seat foam for Buddy Buckets
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
#67 |
#68 |
ttt
#69 |
How much for back/bottom foam for '70 C10 bench seat?
#70 |
#71 |
ttt
#72 |
![]() Join Date: Sep 2010
I would like a price for buddy buckets. Thank you
#73 |
#74 |
Hi can i get a price on green/parchment highlander for a 72 C10. And the foam. Shipped to 87124.
Thanks |
#75 |
