11-07-2013, 12:34 AM | #51 |
Re: "Mable" 1959 Apache Build On A S-10 Frame
What app is that. I have to get it, thats killer looking.
Larry Brown North Texas My 1956 Build - Huff Truck http://67-72chevytrucks.com/vboard/s...48#post6308448 |
11-19-2013, 03:01 PM | #52 | |
But yes lots of updates!! It went from just frame swapping it and bagging it, to hey lets semi restore this beast. So there's been tons of sheetmetal repair to the cab. Bedsides are next. Almost got the front suspension done. Etc etc.... Progress has been slower but some progress is better than no progress!! Soon as I get a few minutes I'll post up all the pics I have since the last time I updated!
WWW.TASKFORCEERA.COM '47-'59 Chevrolet Truck Clothing |
11-19-2013, 10:34 PM | #53 |
This is a sweet build you got going! Starting to really dig the 55-59 trucks. Keep up the great work!
11-20-2013, 11:24 AM | #54 |
semi-restore? you'll be able to drive it a lot sooner that way
is the chicken shed your shop?
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-20-2013, 12:02 PM | #55 |
I'm REALLY looking forward to seeing some updates on this truck because we plan on doing the same frame swap on our 58 in the spring. Any shots of how the body got mounted to the S10 frame would be a huge plus it's going to look so cool bagged and scraping the ground
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
11-21-2013, 05:36 PM | #56 |
Thanks man!
11-21-2013, 05:41 PM | #57 | |
That's my good homie Nates shop. He's done all the fabricating on my truck. He's got a 68 laying doors
02-10-2014, 03:20 PM | #58 |
any updates on this build?
04-14-2014, 12:15 PM | #59 |
Had to go back to my photobucket and fix all my pictures since I made an album for all the truck pics. So all my pics disappeared. But I got it right!
But there's been alot done and I've been slacking on pics so lets do this!! Some of the fab work and rust repair....
04-14-2014, 12:20 PM | #60 |
Got the bedsides blasted and epoxied and did a little wishful future planning on how it's gonna look laid out! Ha!!
04-14-2014, 12:35 PM | #61 |
04-14-2014, 12:38 PM | #62 |
04-14-2014, 12:44 PM | #63 |
And finally, where we're currently at. After months and months of rust repair, dent pulling, sand blasting, stripping, grinding and sanding we got the cab in epoxy! Inside and out. Made it all worth it though! Looks 10 times better already!!
04-14-2014, 12:46 PM | #64 |
Alright, so now I caught up the build I believe. Somewhere in the last few months it's turned into a full restoration project instead of the original plan of just frame swapping it, fixing a few things, bag it and drive it. But the end result will be much better!!
04-14-2014, 02:06 PM | #65 |
looking good, real good
04-14-2014, 03:33 PM | #66 |
I like!! dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
04-14-2014, 06:01 PM | #67 |
Looks rel nice.
Kim |
04-25-2014, 02:20 PM | #68 |
how did you get your front tires to fill the space so well? Did you swap your A arms or just run a wheel spacer?
05-01-2014, 11:25 AM | #69 |
looks awesome!!
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
05-04-2014, 08:40 PM | #70 |
looking real good. you made that frame swap look easy
06-27-2014, 04:22 PM | #71 |
We actually added an inch and a half to the stock control arms. Turned out pretty solid. Then I got 8 inch wide wheels plus the 235/75's helped it out too!
10-14-2014, 10:24 AM | #72 |
What mods were required to the rad support area?
Looks like everything fit really nice
10-21-2014, 03:07 PM | #73 |
We cut the frame horns off of the stock 59 frame and just welded it to the front of the s-10 frame. With some cutting and trimming on the s-10 frame horns of course. But everything bolts up and lines up perfect!
02-12-2015, 07:59 PM | #74 |
Diggin up another thread from the dead here... any updates?
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
02-13-2015, 02:30 PM | #75 |
Updates!!!!
