11-02-2014, 01:23 AM | #51 |
Re: Do you run a fire extinguisher in your truck?
When i was a little sh!& my grampa had a 71 cheyanne with all the bells and whistles. Including an extinguisher on The pass. Kick panal. I remember that latch chingalinging everytime he would hit a bump or something. Ahhh memories
In 2007 my alternator started throwing sparks in My 67 longbed and i started an oily rag i had in the fendercup on fire. I was fortunate and pulled into work, grabbed an extinguisher and sprayed the fire, freaking out all the customers watching. ( i worked at a bmw dealership at the time)
1967custom |
11-05-2014, 12:56 PM | #52 |
When I was 20 I had a 50 chevy . After doing some work on it one afternoon . I saw the paint on my hood start bubbling as I was driving down the road at 40 mph on a country road . Long story short , I got watch as my beauty of a 50 chevy truck melted before my eyes
I have always and I mean always put a fire extinguisher in every vehicle I have ever owned for the past 30 years since that happened. I have never had another fire in a vehicle (knock on wood ) But you can bet your butt ,I am prepared if and/or when it happens to me or someone else. You never know you might save someone else's dream Better to have it and not ever use it Than to be that person watching it melt ... trust me |
11-05-2014, 05:07 PM | #53 |
This one tucks up nicely for me and its handy.
Figure out what you want--then figure out what you are willing to give up to get it. |
11-05-2014, 06:22 PM | #54 |
Keep it on the R kick panel. Never needed it for myself, and never fired it but have had it re-filled/recharged over the years.
I did come upon a car wreck where the driver was trapped in the car with moderate injuries and drunk. Did not want to even attempt to get him out, but would have if the car burst into flames. There was smoke coming out from under the hood and steaming sounds (likely coolant or refrigerant but scary nonetheless). I was somewhat relieved to have my extinguisher at the ready standing guard until the fire department/paramedics showed up and said they had it. Great to have and not need. |
11-05-2014, 07:29 PM | #55 |
Absolutely, Like they say; Don't leave Home without it. I'm retired firefighter and arson investigator, of the car fires I've been on, 1 outta 50 had a working extinguisher with them.
Here's a guy in Florida's LS1Miata. It was on it's 1st test drive with an LS1 V8 in it and NO Extinguisher. It was driving it's First 4 miles, when this happened.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
11-05-2014, 08:56 PM | #56 |
11-05-2014, 09:06 PM | #57 |
11-05-2014, 09:18 PM | #58 |
11-05-2014, 09:24 PM | #59 |
I'm wondering how I should mount one. I really don't want to drill into the body; I have a 1981 Silverado and its rust-free. Could mount it to the seat perhaps, depending on how large the FE is.
There is a local company that can order 2.5lb, 5lb and 13lb Halon 1211 extinguishers. I think the size for the 2.5lb is around 5" width and 14" height. |
11-05-2014, 10:30 PM | #60 |
RAT1968 '68 Cab/'71 Parts
Looks like Lou and I may be running the same FE.
Mine came with a spring-loaded bracket that I screwed to the floor on the hump.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
11-06-2014, 12:14 AM | #61 |
I need to get one for ole dollor , I have one in the other two vehicles , and I need to mount all of them where it would be easy to get to them..
11-06-2014, 12:28 AM | #62 |
"Better Safe Than Sorry!"
I just hope it's never needed but it is comforting to have along for the ride.
11-06-2014, 12:59 AM | #63 |
Re: "Better Safe Than Sorry!"
Not quite the same truck but the same idea. For offroad rigs it's essential. I have one small and one large, but planning to add another small one. The mounts are from DIY4x.com and are super easy to remove FAST. (not to mention way cheaper than the Jeep crowd pays) Once the '68 hits the road, it will see a small one some place inside the cab.
I run a soft top on the blazer, so the back one is always accessible. Even if I'm on my lid, someone can grab the back one.
'68 C10 SWB '85 K30 Blazer |
11-06-2014, 01:18 AM | #64 |
So Kidde is not a good company to use?
11-06-2014, 01:28 AM | #65 |
Anything with a steel neck is maintainable and strong. The plastic ones are not rechargeable, tend to leak sooner, and also not as strong. Mine are Badger and Amerex. It should also be at minimum a type ABC.
11-06-2014, 01:33 AM | #66 |
You can mount one outboard of the driver's seat where the floor angles up or in front of the driver's seat. Either way make sure it's somewhere you can grab it within reach of the driver's door. Most times you'll be grabbing it from outside.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
11-06-2014, 05:37 PM | #67 |
Yup. that's the one. Found it at an off-road shop.
11-07-2014, 10:55 AM | #68 |
I have one in my '59
1971 GMC Sierra 1959 GMC 100 |
11-07-2014, 11:38 AM | #69 |
I don't have one...but after reading some of the positive responses here supporting it, I might look into it.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
11-07-2014, 02:13 PM | #70 |
Halon if available is the way to go ! They are becoming hard to find !
71 C-20 07 Magnum RT AWD |
11-07-2014, 02:44 PM | #71 |
im definitely putting one in my truck when i get ir running again. i have a 06 ram that caught on fire and i got had to run inside a store and borrow one
11-07-2014, 08:14 PM | #72 | |
Let me ask you fellows, if a fire extinguisher is past its warranty yet indicates a "green zone" on the gauge, what does one need to do with it? |
11-07-2014, 10:17 PM | #73 |
11-08-2014, 01:37 AM | #74 | |
11-11-2014, 06:10 PM | #75 |
So HOW are you guys mounting your extinguishers exactly.
After reading this thread, and the ones linked below, I would like to understand in detail how to go about attaching it. I'd really hate to have to drill/screw into the body/floor. Maybe I can rig it to the seat somehow? My seats are vinyl so I would have to protect it from any tearing too. http://67-72chevytrucks.com/vboard/s...d.php?t=526250 http://forum.73-87chevytrucks.com/sm...?topic=29338.0 |
