Old 11-19-2013, 01:16 AM   #51
tlorber
tlorber's Avatar
Re: LSX swappers what ya got?!?!
This is a great thread. I hope to be able to contribute to it soon.
tlorber is offline   Reply With Quote
Old 12-03-2013, 12:48 PM   #52
Hart_Rod
Hart_Rod's Avatar
I guess I can add my 68 since I have it kinda running now, .
Model: 1968 C10 SWB
Motor/transmission: 2013 LS3 6.2 + 6L80 factory stall (CTSV pan)
Fuel tank: Custom aluminum
Motor mounts: CPP stands/Dirty Dingo slider mounts, Poly mounts
Oil pan: 2007 Cadillac CTSV
Tranny mount: Custom Crossmember, Poly Mount
Radiator: Stock Replacement 4-Row, dual electric puller fans
Shift linkage: LOKAR 1801
Exhaust manifolds: Doug Thorley 1 7/8" 323Ys/50 series Flowmasters
Gears: 4.11 Yukon gears
Rear End: 12 bolt/Eaton Posi/Moser axles/CPP 12" Discs
Tire size: Front: 28x8-18 MTs & Rear: 31x16-20 MTs
Bagged: No - static drop 5.5/8
Running: Finally!
Build thread: In my siggy
Fuel Injection: Factory GM -Holley fuel rails/Aeromotive 1000 fuel pump/LS9 map sensor
Go Fast: TVS1900 Magnacharger/219 135 113 LSA CompCam/Springs/Pushrods, 80 Siemens SD injectors/ShrifterSix paddle shifters
Hart_Rod is offline   Reply With Quote
Old 12-08-2013, 07:13 AM   #53
47 Fasttoys
47 Fasttoys's Avatar
OK, so I'm just getting started, I have started the cab work, got the donor, got some of the parts, got the cash. Now all I need is to get my ass back on American soil.
Rob
Model: 1947 Chevy C.O.E.
Motor/transmission: 4.8/4L60E
Fuel tank: Custom (under floor)
Motor mounts: Custom (mid mount)
Oil pan: F Body
Radiator: CUSTOM
Shift linkage: CUSTOM
Exhaust manifolds: 2003 1500 Silverado
Gears:3.42
Rear End:2003 1500 Silverado
Tire size: ?
Bagged: only if needed to get in the shop
Running: Ha,ha,ha,ha
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=596551
Carb or FI: FI
Go Fast: Got a FFR Cobra for that.
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 12-08-2013, 09:21 AM   #54
solidaxel
solidaxel's Avatar
Originally Posted by mrhurt73 View Post
figured i better update this, got 22mpg at 80mph with a/c on
What are you using for a speedometer, odometer?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-13-2013, 12:58 AM   #55
Critter
Future TOTM Winner
Critter's Avatar
Model: 1972 C10 SWB Stepper
Motor: 2006 6.0 LQ4 form 2500 Silverado converted to drive-by-cable
Transmission: Mid 80s 200-4r
Oil pan: Stock LQ4
Motor mounts: Hooker engine swap mounts (stock location)
Tranny mount: relocated stock 1972
Tranny Tunnel: Low hump
Radiator: 1972 style 4 core with dual electric fans
Fuel tank: Custom built fuel cell under bed
Shift linkage: Stock 72 column
Exhaust manifolds: OEM LS2 manifolds from Trailblazer SS
Gears: Soon to be 3.73
Tire size: 29"
Carb or EFI: EFI
Bagged: No
Running: Yes but still a work in progress
Go Fast: Future plans await...
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=605661
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-14-2013, 09:34 PM   #56
cafetony
lq4
cafetony is offline   Reply With Quote
Old 01-19-2014, 07:58 PM   #57
EightiesOnly
EightiesOnly's Avatar
model: 1986 silverado single cab short bed
motor/transmission: 2001 5.3l / 4l60e
fuel tank: Original dual tanks
motor mounts: Custom made from template
Tranny mount: Original modified
oil pan: Original truck
radiator: OEM from '80s
shift linkage: Original from truck
exhaust manifolds: TBSS
gears: 2.73:1
rear end: Original in truck
tire size: 225/55/18
bagged: No
running: Daily driver
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=356697
carb or fi: Fi
go fast: Factory tune
lc
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
Old 02-01-2014, 04:28 AM   #58
Andy4639
Old member
Andy4639's Avatar
Talking Re: LSX swappers what ya got?!?!
Model: 1971 C-10 LWB
Motor/transmission: 2003 HD2500 6.0/4l80e
Fuel tank: 93 Sub 42 gallon in tank pump
Motor mounts: Hawks
Tranny mount: 71 Chevy truck with 4l80 perch
Oil pan: stock 6.0 truck
Radiator: 71 4 core
Shift linkage: B&M for now
Exhaust manifolds: Stainless works Headers
Gears: 4:10
Rear End: Factory 12 bolt
Tire size: 20" 338's Boss wheels
Bagged: No static drop
Running: yes
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=597993
Carb or FI: FI
Go Fast: Yes!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-15-2014, 02:35 AM   #59
ivorton74
ivorton74's Avatar
Model: 1974 C-10 LWB
Motor/transmission: 99 LM7 5.3/4L60E
Fuel tank: Stock w/external pump setup
Motor mounts: Ebay Cutthroat Adjustable Mounts
Tranny mount: Stock w/x-member moved back
Oil pan: Stock 5.3 pan
Radiator: Stock SBC
Shift linkage: Stock with B&M Hammer floor shifter
Exhaust manifolds: Stock 98 Camaro manifolds
Gears: 3.08(for now)
Rear End: Stock 12 Bolt
Tire size: 235/75/15
Bagged: No...static drop 4.5/6
Running: Not yet...swap starting soon
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=614122
Carb or FI: Stock EFI
Go Fast: Eventually I hope
ivorton74 is offline   Reply With Quote
Old 02-18-2014, 03:26 AM   #60
fastpace
Model: 1972 C10 Highlander LWB
Motor: 2011 Taho 5.3
Transmission: 2011 Tahoe 6L80e
Oil pan: LS1 FBody
Motor mounts: Energy Suspension 72 replacement with Dirty Dingo Sliders
Tranny mount: not finished yet, but will probably be 2011 Tahoe mount on stock crossmember
Tranny Tunnel: High hump swap (didn't test fit low hump)
Radiator: Griffin LS swap with spal fans
Fuel tank: Boyd Welding EFI tank
Shift linkage: Not done yet, planning on factory or custom straight linkage
Exhaust manifolds: Doug Thorley 324Ys
Gears: I should probably check
Tire size: TBD
Carb or EFI: EFI
Bagged: Porterbuilt stage 1 front with tubular arms, stage 2 rear, and Accuair e-level
Running: Not yet
Go Fast: BTR Stage 1 cam
Build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=610992
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 02-18-2014, 04:16 AM   #61
jamesjones
Freakin Awesome!
jamesjones's Avatar
Model: 1972 K5 Blazer
Motor/transmission: '05 LQ4/TH350/NP205
Fuel tank: 1987 Blazer
Motor mounts: Custom by Fabworks
Tranny mount: Stock
Oil pan: F-Body
Radiator: Griffin
Exhaust manifolds: 2010 Camaro
Gears: 3.73
Rear End: 12 Bolt
Tire size: 35"
Bagged: Custom Long Travel by BMS Offroad
Running: No
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=145147
Carb or FI: FI
Go Fast: N/A
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 02-22-2014, 01:29 AM   #62
ivorton74
ivorton74's Avatar
Radiator: Stock SBC
Update...Using 2002 4l60e trans
Old 03-05-2014, 05:50 AM   #63
c10seconds
c10seconds's Avatar
Model: 1967 c10
Motor: 6.2 LS3 huge blower cam,heads, Lunati forged rods,pistons, ARP bolts
Engine accessories: C6 LS3 corvette
Transmission: 4L80/Yank converter
Gauges: Dakota digital VHX
Fuel tank: Boyds Fuel tank/ external Aeromotive fuel pump
Motor mounts: Porterbuilt
Tranny mount: Porterbuilt
Oil pan: F-Body
Radiator: Griffin
Shift linkage: Lokar, column shift
Exhaust manifolds: SS trailblazer Kooks stainless Longtubes
Gears: 3.73
Rear End: shortened 12 Bolt/ Detroit locker, moser axles
Tire size: 405/25/24
Bagged: Porterbuilt bagged but soon to be coilover
Running: No
Carb or FI: FI
Go Fast: 2.9L polished whipple supercharger
I cant wait to wire this monster up!!!
1967 C10 SWB 6.8L/4L80
c10seconds is offline   Reply With Quote
Old 03-19-2014, 12:31 AM   #64
Hatzman
Hatzman's Avatar
I'm still in the infancy stage; The truck is gutted and fitting starts this week. Truck goes to the body shop in the next 2 weeks!
Model: 1970 C10 short bed/AC cab
Motor: 2004 6.0 LQ9 (Escalade)
Transmission: 2004 4L60E (Escalade)
Oil pan: stock (at the moment)
Motor mounts: CCP
Tranny mount: Stock
Radiator: stock
Fuel tank: blazer tank installed at the rear, custom filler door on driver side
Shift linkage: unk
Exhaust manifolds: Doug Thorley headers
Gears: 2:56 (1979 Cadillac Seville 10 bolt with disc brakes)
Tire size:
Carb or EFI: EFI
Bagged: no
Running: not yet...
Go Fast: That's the plan!
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 03-28-2014, 12:41 PM   #65
First c10
First c10's Avatar
Model: 1970 CST LWB
Motor/transmission: 2011 LC9-6L80E
Fuel tank: Blazer in rear with filler in side marker light
Motor mounts: ECE
Tranny mount: ECE
Oil pan: Stock 2011
Radiator: Champion Aluminum with 2 electric fans
Exhaust manifolds: SS Shorty headers
Gears: 3.08
Rear End: 12 Bolt
Tire size: 245/60R15 on 8" front- 275/60R15 on 10" rears
Bagged: no static drop 3-1/2"/5"
Running: yes amazing these motors are!!!
Build thread: sorry no
Carb or FI: stock EFI
Go Fast: When I close my Eyes!!!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-30-2014, 09:33 AM   #66
Matt Cramer
Model: 1972 Chevy C10 longbed.
Motor/transmission: 2007 4.8 van motor / TH350 using Advance Adapters flexplate.
Fuel tank: Stock 1972 with in tank pump conversion.
Motor mounts: Homemade. I've posted PDF templates if you want to copy them. Used the '72 engine stands set back to the six cylinder position. They had the "bumps" cut out, flipped side to side and upside down, and welded back in to clear exhaust manifolds.
Tranny mount: Stock.
Oil pan: Stock truck pan.
Radiator: Stock '72. Used 2005 Silverado hoses with about 2" cut off each end of the lower
Shift linkage:
Exhaust manifolds:
Gears: Stock, haven't checked what ratio.
Rear End: Stock '72.
Bagged: No.
Running: Yes.
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=592021
Carb or FI: EFI. Stock injectors with MS3-Pro ECU.
Throttle setup Earlier cable operated throttle using a 3' mountain bike brake cable.
Go Fast: Motor is stock.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 05-08-2014, 12:48 PM   #67
akdg87
akdg87's Avatar
Model:1956 Chevy Cameo on 72 c10 Frame
Motor/transmission: 2004 5.3 with th350
Fuel tank: Summit 16 Gallon, Bosch 044 inline pump and 8 AN feed
Motor mounts:Stock 72 c10 perches with transdapt ls swap mounts
Tranny mount: CPP tubular mount
Oil pan: stock truck oil pan
Radiator: 3 Row aluminum
Exhaust manifolds: Stock truck manifolds with v-bands
Gears: haven't checked
Rear End:12 bolt
Tire size: 265/45/r20 (rear) and 245/35/r20 (front)
Bagged: NO
Running: Runs, needs driveline and tuning
Build thread: in sig below
Carb or FI:EFI
Go Fast: Turbo, LS6 Cam, built transmission 3000 RPM Converter
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 05-21-2014, 12:42 AM   #68
uxdesigner
Model: 1970 C10 Truck
Motor: 2001 Vortec 5.3 (Silverado)
Transmission: 2001 4L60E
Oil pan: Stock 2001 5.3
Motor mounts: CPP Sliders w/ stock V8 perches and mounts
Tranny mount: CPP Poly Mount on stock crossmember
Fuel tank: Stock
Shift linkage: Column
Exhaust manifolds: 2007 Trailblazer SS
Gears: 3.73
Tire size: F:255/35/20 R:275/35/20
Carb or EFI: EFI
Bagged: No
Running: Yes
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=611232
First Start Video
uxdesigner is offline   Reply With Quote
Old 06-12-2014, 01:44 PM   #69
Windsma
Model: 1972 C10 SWB
Motor: 2001 5.3L Copart Donor 115k miles
Transmission: 2001 4l60E from donor
Oil pan: Stock LM7
Motor mounts: 2in back plates with stock mounts
Tranny mount: relocated stock 1972 crossmember
Radiator: BeCool 4 core with dual electric fans
Fuel tank: Boyd tank, i splurged but im sure there's a better solution.
Shift linkage: Lokar 4l60e kit
Exhaust manifolds: Speedway tight fit. Muffler shop had to get creative. Use stock manifolds if you have them.
Gears: stock
Tire size: 295/50 15
Carb or EFI: EFI
Bagged: No
Running: Yes, Daily M3 needs tires so ive been driving it 100 miles a day for 3 weeks. LOVE IT!
Go Fast: Yes, it goes fast.
Windsma is offline   Reply With Quote
Old 06-12-2014, 04:21 PM   #70
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
Model: 1969 swb fleetside
Motor/transmission: 2004 LQ4/700R4/yank 3400 stall
Harness: Heavily modified factory harness
Fuel tank: sumped 15 gal cell
Motor mounts: CPP tubular perches and poly mounts
Oil pan: factory lq4, ported LS6 oil pump
Tranny mount: porterbuilt with poly mount
Radiator: CSR dual pass aluminum with 2 11" electric fans & shrouds
Shift linkage: Bowtie Overdrives cable
Exhaust manifolds: Edelbrock 1 7/8 shortys... Need TBSS LTs!
Gears: 3.73
Rear End: Built/shortened 12 bolt in the works
Bagged: Yes... and tubbed for wide hides
Running: No....dammit
Build thread: A dormant one that will be brought back to life one day.. http://67-72chevytrucks.com/vboard/s...d.php?t=554810
Fuel Injection: factory controlled EFI through Edelbrock rails pumping E85, Aeromotive A1000
Go Fast: Edelbrock Pro-Flo Intake, FAST 92mm TB, Meziere HD electric WP, Custom ground Ed Curtis 224/228 .62x/.62x 110lsa, BTR valvetrain on 243 heads, compression- ?.?:1
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 07-18-2014, 07:21 PM   #71
pwradder
pwradder's Avatar
Model: 1980 c10
Motor/transmission: 2000 tahoe 5.3, chevy van 700r4
Fuel tank: original with an external fuel pump.
Motor mounts: stock with transdapt plates- be aware, they move the engine and trans forward 1''.
Tranny mount: stock, relocated.
Oil pan: same tahoe
Radiator: original 1980 c10
Shift linkage: stock
Exhaust manifolds: tahoe
Gears: 3:42?
Rear End: 10 bolt open diff (for now)
Tire size: 255/60/15
Bagged: nope-static
Running: put almost 2k miles on it so far-loving it!
Build thread: maybe later
Carb or FI: factory efi, self tuned
Go Fast: just the custom cold air setup and tune,toying with the idea of spraying it...
______
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 07-21-2014, 12:12 AM   #72
Wswheel
Model: 70 c10 fleet side long box
Motor/transmission: 6.0l tci 700r4
Fuel tank: aluminum under the bed
Motor mounts: 73-87 c10
Tranny mount: custom
Oil pan: Ctsv
Radiator:aluminum
Shift linkage:
Exhaust manifolds: g-body mid length
Gears: 3:73 posi
Rear End: 12
Tire size:
Bagged:
Running:
Build thread:
Carb or FI: Model: carb for now
Wswheel is offline   Reply With Quote
Old 07-28-2014, 07:04 PM   #73
ivorton74
ivorton74's Avatar
Motor/transmission: 1999 LM7 5.3, 2002 4L60E
Tranny mount: Stock
Radiator: New stock replacement SBC
Running: YES!!!!
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
Old 10-10-2014, 02:03 PM   #74
LS1Impala
Model: 1968 C10 single cab/shortbed
Motor: 2005 5.3 (Silverado) w/LS6 cam
Transmission: 2002 4L60E (Camaro)
Oil pan: CTS-V
Motor mounts: CPP perch and dirty dingo sliders
Tranny mount: Stock modified crossmember
Radiator: Aluminum 4 core, aftermarket from unknown source
Fuel tank: Stock tank behind seat with external pump
Shift linkage: Column/Lokar
Exhaust manifolds: LS3
Gears: 3.50
Tire size: 295/35/20 in the rear and 245/40/20 in the front
Carb or EFI: EFI
Bagged: rear only
Running: Yes
Go Fast: A little nitrous...
1968 C10 5.3/4L60E LS6 cam and a 3600 stall
1968 Camaro 6.0/4L65E T76 turbo 9"
1960 Impala LS1/4L60E all stock cruiser
LS1Impala is offline   Reply With Quote
Old 11-06-2014, 05:58 PM   #75
Benlugchev
Benlugchev's Avatar
Model: 1971 C10 LWB
Motor: 2005 6.0L
Transmission: Stock 4l80e
Oil pan:Stock 6.0L
Tranny Tunnel: Stock
Radiator: Stock with ls1 fans
Fuel tank: 2000 F-body plastic tank under bed
Shift linkage: B&M
Exhaust manifolds: Stock manifolds
Gears: 3.73
Tire size: 28.5
Carb or EFI: EFI
Bagged: NO
Running: Yes very good
Go Fast: Yes very fast!
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs)
00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs)
Benlugchev is offline   Reply With Quote
