02-24-2013, 04:27 PM | #51 |
Re: Gauge cluster trouble
SUCCESS!!!!!!!
it appears that by having some bad lamps in the cluster, it caused some bad grounds. all is well and working now!!!! thanks for all the help and support, hopefully this thread becomes useful for someone else in the future that may experience the same gremlins!
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
02-24-2013, 05:48 PM | #52 | ||
Msgt USAF Ret
I saw this thread a couple days ago and it looked like you all had it figured out with the bad grounds so I didn't pay much attention to it until today. Some good advice given by all and it's hard to make a diagnosis until the tests get done.
It would appear that bad grounds are not the main problem from what I gather by reading some threads like this one. Quote:
Another clue is the bolded sentence in this post. Quote:
The following prints show these tees and the path of the positive wiring through the firewall block. Follow the large red wire to the firewall block. This is the inside cab print again follow the large red wire. Ignore the arrows they are for the accessory feed from the key switch. The horn relay is on the left center and the fuse panel is bottom right. The inside of the firewall block is on the left lower. Notice the two pink wires going into the fuse block. The vertical one is from the key switch and feeds the fuse panel with key on power. The horizontal one goes over to the dash cluster and feeds the no. 3 terminal on the cluster plug. The next print will show this as well as the headlight switch. This diagram is mainly for the idiot light cluster but the gauge cluster plug connections are on the top of the diagram. Your plug should compare with that one. Also notice the gray wires off the fuse panel are for the dash cluster lights which are fed from the headlight switch via the dark green wire. A poor connection at the firewall block will affect all the positive feeds inside the cab and they may be intermittent as well which, is very frustrating. Even if there is a connection to the light switch, if it is not a good one will result in high resistance to current flow to ground through any loads. The voltage and current will follow the least path of resistance to ground which will leave less power for the higher resistances to ground. I hope this makes sense. What you need to do is test for battery voltage at The firewall block on the red wire and at the horn relay or the key switch inside the cab with the key off and then test the pink wire at the key switch or the ignition unfused terminal on the fuse panel and at the number 3 pin on the cluster plug. I have to leave it here for now, The boss wants to go to the store so check the voltages and maybe pull the fire wall block apart and clean it thoroughly and see if things don't improve.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-24-2013, 07:38 PM | #53 |
Thanks vette. Seems like I am headed in the right direction.
03-31-2013, 07:42 PM | #54 |
I need to see what was taken apart and blown with air. My two bulbs for the gas guage do not light and they are closest to the plug. The two that light the speedo work fine. Go figure. I have grapples with this for a year to no avail. Everything else electronic works fine!
Eddie |
03-31-2013, 09:12 PM | #55 | |
**If this did not make them light, you know the problem is one of the 3 following: (a)the section of original wire from jumper to socket is bad, or(b)the socket is bad, or(c)the bulb is bad--you will now know what it would take to correct the problem; hint: you know you now have both voltage and ground available at the jumper-wiring-connections: repair from there out! In the end, should you choose the working (1) alternative, you have not found the original defect; however, what difference does that really make?--you have achieved your ultimate goal: getting the 2 gas-gauge bulbs to burn. Might save you from "grappling with this for another year--maybe to no additional avail". HTH, Sam |
03-31-2013, 10:59 PM | #56 | |
RAT1968 '68 Cab/'71 Parts
Cool approach to a fix, Sam. But too tricky for me with a P.C. But that's just me.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
