Closed Thread
Old 01-17-2014, 08:41 AM   #51
c20pickup
Re: 1967 king cab info please
Steel floor or make up a metal plate for the wood bed and use stainless carriage bolts. If it were me id go with a steel bed
c20pickup is offline
Old 03-08-2014, 08:58 PM   #52
jpmanyhearts
frankenstien Fabrications
hey guys been a while been working on my crew cab but I was wandering if I could get a little help ?? the 98 that i'm using the front pumpkin is on the drivers side the 68 the front pumpkin is on the passengers side, any ideas on how to fix this ? also I have been told that the nv4500 that I have bolts to the transfer case differently that in the 68 any ideas on this as well ??? thank you guys for everything
frankenstein Fabrications
jpmanyhearts is offline
Old 03-08-2014, 09:46 PM   #53
SS Tim
SS Tim's Avatar
"any ideas on how to fix this ?"
Research and planning are the place to start. Finding parts and trying to "make" them work is time consuming and expensive at best.
"98 Chevy 3/4 ton 5.7 350 with a factory 5 speed"
The GMT400/400 platform trucks went to an independent front end starting in 88. Are you trying to adapt an independent front end into your 67?
As far as bolting an NV4500 to a T221, it isn't going to happen without a custom adaptor.
If you have a need for a left drop t-case find a Ford NP205 or a later chain case suited to your use.
Towing
Are you wanting a true R/V fifth wheel or a gooseneck?
Consider you driveline and braking choices carefully if the trailer is very heavy.
SS Tim is offline
Old 03-09-2014, 01:36 AM   #54
mrolds88
Check out a NP208 or early NP241 (they came in the square body Suburbans in 90 and 91) The 241's also had the electronic speedo setup too if you need it.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline
Old 03-09-2014, 12:36 PM   #55
jpmanyhearts
Size:  81.5 KBSS TIM IM APALLED USUING FORD AND CHEVY IN THE SAME SENTENCE......................UUUGGGHHH PUTS A BAD TASTE IN MY MOUTH HERES WHAT I HAVE SO FAR GUYS
Old 03-09-2014, 12:40 PM   #56
jpmanyhearts
Old 03-09-2014, 12:43 PM   #57
jpmanyhearts
Heres the frame splice
Old 03-09-2014, 12:54 PM   #58
jpmanyhearts
My friend has a suburban he hauled to pacific it an late 80's early 90's but hes saying that I should trade with him the short frame here for his then everything will pretty much bolt up but will need to put 10 inches in the frame but the front pumpkins will be on the same side and im going to use it for cruzing some off road not much mainly just back roads and the accasional run through the mud doing doughnuts lol so im trying to plan ahead and get ideas but my main focus is getting the motor out and on the ground, oh and the gas tank will be between the frame rails as well on the suburban so I don't know what do you guys think ???
Old 03-10-2014, 03:04 PM   #59
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
These bodies on different frames look like crap IMO. I'd use your frame and find a 241 or 208 from a chevy. Dodges had 241d's in them in half ton gas trucks as well.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline
Old 03-13-2014, 11:23 AM   #60
jpmanyhearts
http://www.advanceadapters.com/produ...ter-replth400/
heres what ive found
sstim im very seriously thinking of grafting the ifs to the front
Old 03-13-2014, 11:27 AM   #61
jpmanyhearts
like this one sstim http://www.advanceadapters.com/produ...ter-replth400/ to exspensive for my blood lol
Towing
to expensive for my blood
Closed Thread
