Old 02-26-2014, 11:54 PM   #51
Hardesty454
Hardesty454's Avatar
Re: Project "Full Circle" 66 C10
This is looking great! How do you like the C4 dropmember? everything go together well? I have a line on one and curious about how others like it.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 02-27-2014, 10:09 AM   #52
timmytimm3
Thanks! Everything went together fine. Other than that, I can't comment on the ride or handling yet.
I know Porterbuilt stopped making them. Mine was a one-off part that took a while to get done.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 05-13-2014, 11:19 AM   #53
timmytimm3
Small update before some bigger ones. I scraped and wire wheeled the whole underside of the cab in preparation for welding in all the new parts. Years ago my father made these lift pucks for doing body mounts and floor work. I plan on pulling out one at a time and replacing the cab mounts, then replace the drivers side floor, both inner and outer rockers and cab corners.
timmytimm3 on IG
Old 05-13-2014, 12:02 PM   #54
1963c-10
1963c-10's Avatar
Cool idea on the cab lifts!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-22-2014, 10:20 AM   #55
timmytimm3
Cab braced up
I started patching some rust holes in the firewall
These two cab braces weren't welded together from the factory. Normal?
Some minor fitment required. I had to narrow the rear cab mount and change the angle quite a bit.
Starting to come together
timmytimm3 on IG
Old 06-04-2014, 02:37 PM   #56
Bomp
Bomp's Avatar
Wow!
You're making great progress.
Looking good looking reeeeal gooood.
Bomp is offline   Reply With Quote
Old 08-01-2014, 11:44 PM   #57
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice build, the PB parts are amazing! What are the spec's on your Dad's 57 tires and wheels?
ChuckDriver is offline   Reply With Quote
Old 08-05-2014, 12:41 PM   #58
timmytimm3
Thanks.
17x7 and 18x11, 215-55 and 30x12 Mickey Thompsons (MTT-6672)
timmytimm3 on IG
Old 08-05-2014, 07:07 PM   #59
ChuckDriver
Thanks! Are they Team III, ET's?
Old 08-06-2014, 09:39 AM   #60
timmytimm3
ET III.
Life has been really crazy lately so there hasn't been much work done. My brother bought a house so I had to buy him out of his 1/2 of our current house. At work, we had to move our office twice in two weeks because the new office wasn't ready for us and I was unable to get internet access installed in time. I had to move the servers and phone system to a temporary office for a week where a skeleton crew worked, then move everything again when the new office was ready. I worked something like 20 straight days, it sucked and I'm glad it's over.
I've been working on fitting the driver side floor and finally got my high hump trans tunnel shipped from a not to be named company.
I have off next week and plan to hit it hard.
timmytimm3 on IG
Old 08-07-2014, 09:40 AM   #61
timmytimm3
For some reason I can't edit my original post, but here are some pics:
timmytimm3 on IG
Old 08-07-2014, 09:45 AM   #62
1963c-10
1963c-10's Avatar
How did the doors come out?
Old 08-07-2014, 09:58 AM   #63
timmytimm3
I forgot to take pics of them done, but they came out great. Butt welding the seam took a long time and I planished them to prevent warping. It should take a skim coat of filler to make them nice.
timmytimm3 on IG
Old 09-05-2014, 11:15 AM   #64
timmytimm3
Here's a better picture of the door skin I found
My brother has make some good progress on his mud truck.
I'm getting there on my cab. Hopefully another couple weeks and I'll be able to get it in epoxy primer.
Pass side inner rocker mocked up
timmytimm3 on IG
Old 09-09-2014, 09:02 AM   #65
timmytimm3
My father helped me hang the door and made sure the rockers look good. I should be buttoning up this side soon.
timmytimm3 on IG
Old 09-17-2014, 12:05 PM   #66
timmytimm3
timmytimm3 on IG
Old 11-14-2014, 12:23 PM   #67
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Great Build!! Love your Jeep and your dads show plow!! Thanks for posting pictures of replacing your door skins. I just ordered full doors skins and the inner panels to repair my doors. Going to be my first time so your pictures are a help!
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 02-17-2015, 04:06 PM   #68
timmytimm3
I've been redoing my bathroom (gutted to the studs) so I haven't gotten much done on my truck. Here are some updates from my brothers build:
timmytimm3 on IG
Old 05-02-2015, 08:15 PM   #69
Gary V
Active Member
Gary V's Avatar
Fantastic work! Hope to see those vehicles in person some day. Subscribed!
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 03-28-2016, 10:06 AM   #70
timmytimm3
I should have some good updates on my truck soon. I got a flywheel, clutch, Boyd's welding tank, and have my Ridetech coilovers on the way. I started popping the bondo off my bedside and pulled the trim off. I need to chop it down to a shortbed and do a ton of hammer work. FUN
Meanwhile, my brother has been killing it on his mud truck. Fresh paint, the fender and door are not completely adjusted yet.
timmytimm3 on IG
Old 06-20-2016, 03:28 PM   #71
timmytimm3
Some more updates. I got my coilovers assembled
and realized I'm going to need to cut (2) passenger side bedsides in half to make one good one, then shorten them. Big project but I don't have the funds for new ones.
Good rear half
Bad front half
timmytimm3 on IG
Old 06-21-2016, 08:37 AM   #72
timmytimm3
and a Boyd's Tank
timmytimm3 on IG
Old 06-21-2016, 12:04 PM   #73
Bomp
Bomp's Avatar
Making great progress.
The bed side shouldn't be too difficult for you since you killed it on your door.
I hacked out large areas and replaced with new on mine.
Should be easy peezy for you.
Old 06-26-2016, 11:02 AM   #74
step65
Awesome project looking forward to seeing your progress. Your metal work is really good.
step65 is offline   Reply With Quote
Old 06-28-2016, 10:40 AM   #75
timmytimm3
After looking more closely at the 2 passenger side bedsides they're not worth fixing. I found on one this website and it should be here by Thursday. I'll probably keep the other parts and make a bench or something eventually.
Pics to come.
timmytimm3 on IG
