Old 04-16-2013, 07:22 AM   #51
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Originally Posted by solidaxel View Post
I see no reason why you should not guarantee that truck for the next 50 years!!!
It might be hard to do warranty work at 120 years old but I'll try.....
dwcsr is offline   Reply With Quote
Old 04-16-2013, 02:35 PM   #52
98layinframe
98layinframe's Avatar
Re: 1949-50 3100
Sorry double post..
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 04-16-2013, 02:36 PM   #53
98layinframe
Re: 1949-50 3100
Southern folks are getting a taste for what every single northern rust belt cab looks like up here! This is why we drive south or west for 2 strait days to get parts. Are you guys sure the last body shop did that work cause it looks like something farmers up here would do over years of trying to keep it from going flinstone style, maybe the previous restoration was more like a sand, bondo and paint kinda deal?
Either way, feel bad the owner got ripped off and look forward to seeing you guys save this one
Old 04-16-2013, 09:25 PM   #54
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Here are some pictures of the front and where its rusty under the A pillar jackets. Once these are sand blasted there will be no rust left on this truck at all.
Old 04-16-2013, 09:35 PM   #55
Denee007
Denee007's Avatar
Re: 1949-50 3100
omg! An image of a very large big back window comes to mind, or a convertible! How much time do you think will go into this build?
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 04-21-2013, 08:20 PM   #56
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
I originally wanted to be done in 90 days but my part suppliers seem to have a different idea on how long its going to take. I'm busy making some removeable jigs that I can bolt into the door hinge pockets and to line up the cowl and hood hinge holes. I'll post some pictures of them for those that plan on doing similar repairs. During my research I found some really good videos on building a cab from scratch.
They make is look so easy
Old 04-22-2013, 10:29 PM   #57
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
We made up a jig to make sure the new cowl is in the proper place when its replaced. It has a plate bolted to the upper door hinge pocket and just runs up to make a guide point for the belt line where it meets the door. The other part goes to the from and bolts in the hood hinge holes so the firewall is in the same place it is now. The other guide points are the dash lip and the pinch weld for the top of the window. Since we are not removing the dash and upper window support all that should line up nicely. The tube we used is very heavy wall DOM, I think its about 3/16 wall. Not much flex in at all.
Old 04-25-2013, 07:51 PM   #58
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
I was told I'm getting sheet metal tomorrow or Monday so we are getting all the spot weld areas ready and the rot we found under the floor fixed. This cab dolly worked out perfectly. Its just the right height for sitting and doing a corner, rocker or standing and fixing the upper cowl area.
Old 04-25-2013, 07:54 PM   #59
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
One more. we also will be treating the areas we sandblasted yesterday. The areas that are covered by the A pillars, roof skin and so on.
Old 04-26-2013, 01:17 PM   #60
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
We are working on the front floor area and the rotted cab mount. First I welded some bracing in place and tacked the good section of the cab mount to the frame part of the cab mount. This way its all in position to replace the cab mount end and the rocker end without the cab getting out of shape.
Old 04-26-2013, 01:49 PM   #61
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Here we are cutting out the mount end and as you can see it rotted which is typical of these trucks. I cut the rocker inside of the first pillar so I had a good place to weld in the rocker end. Once its trimmed up we weld it in.
Old 04-26-2013, 02:26 PM   #62
Larry Lindley
Re: 1949-50 3100
Dam a new after market cab may have been a faster build.
Larry Lindley is offline   Reply With Quote
Old 04-26-2013, 03:02 PM   #63
Denee007
Denee007's Avatar
Re: 1949-50 3100
"We have the technology, we can rebuild it!" kind of from The Six Million Dollar Man! (and apparently a customer with deep pockets. I would think the challenge and the ability to do a task like this would be quite rewarding
Old 04-26-2013, 05:50 PM   #64
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
A new cab is $8500 plus shipping and crating. I can make 3 of these cabs for that price with all new metal.
The challenge is most of this so I don't mind and the customer ends up saving money.
We fixed the rocker end and just need to cut the hole in it like it was. We just cut back to good metal and welded in the new pieces.
Tomorrow we start on the back of the can lip where it meets the outer shell and floor.
Old 04-26-2013, 07:29 PM   #65
FarmerSid
FarmerSid's Avatar
Re: 1949-50 3100
Awesome work man! The hours ................. Good job showing us all what and how you are dong it Dave.
FarmerSid is offline   Reply With Quote
Old 04-27-2013, 03:42 PM   #66
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Thanks farmer,
We fit and welded in the right inner panel leaving as much old metal as we could around the vent hole. The holes up near the cowl are hinge bolt holes and this is what will help us line up the outer cowl when we get that far so I wanted to leave it intact.
Old 04-27-2013, 03:52 PM   #67
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
We decide to add a hinge to the front of the dolly to make it easier to work on the back side. The can lifts surprisingly easy. Later hinges will be put on the back of the dolly.
Old 04-28-2013, 03:11 PM   #68
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Today Jacob my helper made and replaced the left rocker end. This is a tricky part because at the pillar its curved with a flare and the rest is completely flat where the foot brake assembly mounts to it. We ended up making it all curved and then about an inch from the pillar we slit it vertically and flattened the front part of it and then used hammer and dolly to give it the flare then welded it back together so we ended up with the curved flared part at the pillar and the flat part at the brake assembly.
Old 05-02-2013, 10:45 AM   #69
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Finally got a pallet of parts in and we are now fitting, adjusting cleaning up trouble spots. Because these parts are "Rust Panels" they don't fit as if they were new OEM panels. Some have extra length to them to compensate for another rusted parts or are wider so you can trim to fit. None fit like a puzzle piece so don't expect them to.
We have started fitting the left lower cowl, wheel house and inner kick panel and working on the floor fit so all the panels in that lower cowl area fit nicely. Once fitted everything gets clamped up and we do the other side. When all looks right we tack it all in place making adjustments as we go and start the finish weld.
Old 05-02-2013, 11:02 AM   #70
Denee007
Denee007's Avatar
Re: 1949-50 3100
That's exciting news! That should give a boost in progress! I love new parts; nice and clean
Old 05-02-2013, 11:12 AM   #71
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Its like christmas in the middle of the year. Stop by Friday if you have time . I'll show you what we are doing.
Old 05-02-2013, 11:16 AM   #72
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Just an FYI I'm using a product called Jasco Quart Prep & Primer for the bare metal and rust conversion. Its similar to Ospho and costs a little less maybe $3 a quart cheaper. It converts iron oxide (rust) to iron phosphate. I like it because its at almost any home center and usually readily available. It is acid so you have to wear protection for the face and hands. Cuz it burns like the dickens when it gets on your face. Here's a link
http://www.wmbarr.com/product.aspx?catid=103&prodid=221
Old 05-03-2013, 05:00 PM   #73
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
We are still working on the left front cab area. From what we can tell the cab due to all the rust was shifted a bit and when I welded it into position to replace the cab mount it was off by a half inch so we had to spend half a day jacking it back into position and lining up the other work we did. We have the floor, wheel house , inner panel and rocker end all lined up now so it just a matter of fitting the lower cowl and tacking it all in place.
Old 05-03-2013, 05:15 PM   #74
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Here are a few more pictures. The old mount was narrower than the new one so it doesn't fit as well as I would have liked. next time I'll just replace the complete mount. Next it the lower cowl fit up.
Old 05-03-2013, 11:17 PM   #75
solidaxel
solidaxel's Avatar
Re: 1949-50 3100
Is the new sheet metal the same gauge and weight as the piece being replaced?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
